I have been attempting to get the CAN up and running on the Xavier NX, currently running Ubuntu 20.04, and it has not been successful. I know messages are getting to the transceiver and that that transceiver is working (I have two nodes and swapped the two transceivers around to make sure they were working).
Setup:
- SN65HVD230 Transceiver board x 2
- Teensy 3.2 Spouting CAN messages at the 50000bps Rate
- Xavier NX with J17 connected to the transceiver as follows:
pin 31 → CAN TX
pin 29 → CAN RX
pin 17 → 3.3V
pin 39 → GND
Procedure and Tests
- On a clean boot (of Ubuntu 20.04 - may be a possible cause) I run the following commands:
sudo busybox devmem 0x0c303020 32 0x0000C458
sudo busybox devmem 0x0c303018 32 0x0000C400
sudo modprobe can
sudo modprobe can_raw
sudo modprobe mttcan
sudo ip link set can0 type can bitrate 50000 restart-ms 1000 loopback off
sudo ip link set up can0
candump -d can0 - I power on the teensy and no messages appear.
- I take the voltage of the CAN0_DOUT pin and it is sitting at around 0V stopping the teensy publishing onto the CAN. As soon as I remove the connection of the CAN0_DOUT pin on the transceiver, messages are clearly visible on the CAN RX pin of the transceiver, but nothing is shown on candump.
- Ouput of ip -s -d link show can0:
6: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UP mode DEFAULT group default qlen 10
link/can promiscuity 0
can state ERROR-ACTIVE (berr-counter tx 0 rx 0) restart-ms 1000
bitrate 50000 sample-point 0.875
tq 147 prop-seg 59 phase-seg1 59 phase-seg2 17 sjw 1
mttcan: tseg1 2…255 tseg2 0…127 sjw 1…127 brp 1…511 brp-inc 1
mttcan: dtseg1 1…31 dtseg2 0…15 dsjw 1…15 dbrp 1…15 dbrp-inc 1
clock 34000000
re-started bus-errors arbit-lost error-warn error-pass bus-off
0 0 0 0 0 0 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
RX: bytes packets errors dropped overrun mcast
0 0 0 0 0 0
TX: bytes packets errors dropped carrier collsns
0 0 0 0 0 0
5. I take can0 down and turn on loopback, run cangen can0 and messages appear on candump.
I have tried using multiple different memory addresses, but so far nothing has worked. The ones I am currently using I obtained from here: https://docs.nvidia.com/jetson/l4t/#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/hw_setup_jetson_can.html#wwpID0E02D0HA
I had a look at the kernel and it appears that there is no mttcan_ivc in the /lib/modules directory, could this be the cause? I have no experience of building kernels so I am hoping that this isn’t the issue.
