I have been trying to use CAN-BUS on the JETSON NX development board. The transceiver I am using is TJA1050 with the S pin to ground VCC at 5V (given externally through a buck) my question is:-
Are the CAN pin (RX and TX) on the NX capable of handling 5V, as I was not able to gain much information from the datasheet where it says its voltage is CMOS-3.3V
Also, What if the CAN pin gets a very high spike can it damage the NX, in a way where the system gets overheated and also does not allow the bootup.
Thanks a lot for the help in advance.
