Can I run "tlt lprnet train" command inside a docker container
Hi.
I have been learning how to use TLT 3.0 with the tlt_cv_samples_v1.1.0/lprnet Jupyer notebook. I’m running the notebook in a container of the nvcr.io/nvidia/tlt-streamanalytics:v3.0-py3 image. Is it possible to run the TLT traininig inside a docker container?
I have the following error at the notebook cell of tlt lprnet train. It seems that the error was from the spec file mounting fail for the nest of containers. Thanks.
print("For multi-GPU, change --gpus based on your machine.")
!tlt lprnet train --gpus=1 --gpu_index=$GPU_INDEX \
                  -e $SPECS_DIR/tutorial_spec.txt \
                  -r $USER_EXPERIMENT_DIR/experiment_dir_unpruned \
                  -k $KEY \
                  -m $USER_EXPERIMENT_DIR/pretrained_lprnet_baseline18/tlt_lprnet_vtrainable_v1.0/us_lprnet_baseline18_trainable.tlt
2021-07-07 07:13:38,923 [INFO] root: Registry: ['nvcr.io']
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-07-07 07:13:45,963 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-07-07 07:13:45,964 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:57: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2021-07-07 07:13:46,112 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:57: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:60: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2021-07-07 07:13:46,113 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:60: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:61: The name tf.keras.backend.set_session is deprecated. Please use tf.compat.v1.keras.backend.set_session instead.
2021-07-07 07:13:46,479 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:61: The name tf.keras.backend.set_session is deprecated. Please use tf.compat.v1.keras.backend.set_session instead.
2021-07-07 07:13:46,479 [INFO] iva.lprnet.utils.spec_loader: Merging specification from /workspace/tlt-experiments/lprnet/specs/tutorial_spec.txt
  File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py", line 277, in <module>
  File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py", line 273, in main
  File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py", line 64, in run_experiment
  File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/utils/spec_loader.py", line 126, in load_experiment_spec
  File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/utils/spec_loader.py", line 106, in load_proto
  File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/utils/spec_loader.py", line 91, in _load_from_file
FileNotFoundError: [Errno 2] No such file or directory: '/workspace/tlt-experiments/lprnet/specs/tutorial_spec.txt'
2021-07-07 07:13:47,540 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
Yes. You can login the docker and run commands.
Please check your ~/tlt_mounts.json file. I am afraid there is something wrong in the path to spec.txt file inside docker.
Thank you for your reply.
I understand that TLT 3.0 works inside docker container. So I assume that TLT container can be “docker in docker”.
I checked my .tlt_mounts.json but I could not find any wrong setting.
Here is my .tlt_mounts.json
# cat ~/.tlt_mounts.json
    "Mounts": [
            "source": "/data/tlt-experiments",
            "destination": "/workspace/tlt-experiments"
            "source": "/workspace/tlt_cv_samples_v1.1.0/lprnet/specs",
            "destination": "/workspace/tlt-experiments/lprnet/specs"
    "DockerOptions": {
        "user": "0:0"
I understand that the above mount definition results in the following path translation.
TLT container path: /workspace/tlt-experiments/lprnet/specs/tutorial_spec.txt
Host path (my container path): /workspace/tlt_cv_samples_v1.1.0/lprnet/specs/tutorial_spec.txt
I confirmed that the training spec file exists at the path I expected.
# cat /workspace/tlt_cv_samples_v1.1.0/lprnet/specs/tutorial_spec.txt
random_seed: 42
lpr_config {
  hidden_units: 512
  max_label_length: 8
  arch: "baseline"
  nlayers: 18 #setting nlayers to be 10 to use baseline10 model
training_config {
  batch_size_per_gpu: 32
  num_epochs: 24
  learning_rate {
  soft_start_annealing_schedule {
    min_learning_rate: 1e-6
    max_learning_rate: 1e-5
    soft_start: 0.001
    annealing: 0.5
  regularizer {
    type: L2
    weight: 5e-4
eval_config {
  validation_period_during_training: 5
  batch_size: 1
augmentation_config {
    output_width: 96
    output_height: 48
    output_channel: 3
    max_rotate_degree: 5
    rotate_prob: 0.5
    gaussian_kernel_size: 5
    gaussian_kernel_size: 7
    gaussian_kernel_size: 15
    blur_prob: 0.5
    reverse_color_prob: 0.5
    keep_original_prob: 0.3
dataset_config {
  data_sources: {
    label_directory_path: "/workspace/tlt-experiments/data/openalpr/train/label"
    image_directory_path: "/workspace/tlt-experiments/data/openalpr/train/image"
  characters_list_file: "/workspace/examples/lprnet/specs/us_lp_characters.txt"
  validation_data_sources: {
    label_directory_path: "/workspace/tlt-experiments/data/openalpr/val/label"
    image_directory_path: "/workspace/tlt-experiments/data/openalpr/val/image"
  1. No, by default TLT container is not running “docker in docker”. TLT 3.0 is a docker only.
  2. By default, in tlt 3.0 docker, there is no /workspace/examples/lprnet/specs/us_lp_characters.txt inside. This is a minor issue in lprnet spec file. You can run below to check.
    $ tlt lprnet run ls /workspace/examples/lprnet/specs/us_lp_characters.txt
    So, please download us_lp_characters.txt from deepstream_tao_apps/us_lp_characters.txt at master · NVIDIA-AI-IOT/deepstream_tao_apps · GitHub
    And modify the training spec file. Thanks.
Thank you for your advice.
I assume that my environment has the structure as shown in the below diagram. So I assume that the container launched from TLT is “docker in docker”.
I found us_lp_characters.txt in the /workspace/tlt_cv_samples_v1.1.0/lprnet/specs directory.
So I modified dataset_config in tutorial_spec.txt as follows. But I still have the same error as I already reported.
dataset_config {
  data_sources: {
  characters_list_file: " /workspace/tlt-experiments/lprnet/specs/us_lp_characters.txt"
According to part of your ~/.tlt_mounts.json file, could you run below command and share the result?
$ tlt lprnet run ls /workspace/tlt-experiments/lprnet/specs
No file found.
# tlt lprnet run ls /workspace/tlt-experiments/lprnet/specs
2021-07-08 09:22:51,490 [INFO] root: Registry: ['nvcr.io']
2021-07-08 09:22:52,970 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
Are the files available in your local directory?
$ ls /workspace/tlt_cv_samples_v1.1.0/lprnet/specs
Yes, I have them.
# ls /workspace/tlt_cv_samples_v1.1.0/lprnet/specs
tutorial_spec.txt  tutorial_spec_scratch.txt  us_lp_characters.txt
Please note the above ls command was not executed on the real local but on my container I described as the blue rounded rectangle in my diagram I posted yesterday.
With Google search, I found that many people are saying the volude mount for “docker in docker” does not work as they expected. Some people are saying that the inner docker container does not mount the volume on the outer docker container but the volume on the real host (shown as the orange rectangle in my diagram).
Because I’m not a system administrator, I cannot inspect the file systems on the real host.
So, can you modify you ~/.tlt_mounts.json ?
Change from
to
        "source": "your-local-path-to-lprnet-specs",
I got how to use TLT 3.0 inside a docker container.
I needed to run TLT with just the lprnet command. No “tlt” preceeding “lprnet”.
Then I needed to give the local directories to the lprnet command.
!lprnet train --gpus=1 --gpu_index=$GPU_INDEX \
                  -e $LOCAL_SPECS_DIR/tutorial_spec.txt \
                  -r $LOCAL_EXPERIMENT_DIR/experiment_dir_unpruned \
                  -k $KEY \
                  -m $LOCAL_EXPERIMENT_DIR/pretrained_lprnet_baseline18/tlt_lprnet_vtrainable_v1.0/us_lprnet_baseline18_trainable.tlt
I also modified the data path in the spec file.
dataset_config {
  data_sources: {
    label_directory_path: "/data/tlt-experiments/data/openalpr/train/label"
    image_directory_path: "/data/tlt-experiments/data/openalpr/train/image"
  characters_list_file: "/workspace/tlt_cv_samples_v1.1.0/lprnet_debug/specs/us_lp_characters.txt"
    label_directory_path: "/data/tlt-experiments/data/openalpr/val/label"
    image_directory_path: "/data/tlt-experiments/data/openalpr/val/image"
It seemed that the h5py version in TLT 3.0 container was not good in my environment. So I reinstalled the h5py.
!pip3 show h5py
!pip3 uninstall h5py -y
!pip3 install h5py==2.10.0
2021-07-09 05:36:27,971 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-07-09 05:36:27,971 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-07-09 05:36:28,111 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:57: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2021-07-09 05:36:28,111 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:60: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2021-07-09 05:36:28,438 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:61: The name tf.keras.backend.set_session is deprecated. Please use tf.compat.v1.keras.backend.set_session instead.
2021-07-09 05:36:28,438 [INFO] iva.lprnet.utils.spec_loader: Merging specification from /workspace/tlt_cv_samples_v1.1.0/lprnet_debug/specs/tutorial_spec.txt
2021-07-09 05:36:28,439 [INFO] __main__: Loading pretrained weights. This may take a while...
Initialize optimizer
Model: "lpnet_baseline_18"
__________________________________________________________________________________________________
Layer (type)                    Output Shape         Param #     Connected to
image_input (InputLayer)        [(None, 3, 48, 96)]  0
tf_op_layer_Sum (TensorFlowOpLa [(None, 1, 48, 96)]  0           image_input[0][0]
conv1 (Conv2D)                  (None, 64, 48, 96)   640         tf_op_layer_Sum[0][0]
bn_conv1 (BatchNormalization)   (None, 64, 48, 96)   256         conv1[0][0]
re_lu (ReLU)                    (None, 64, 48, 96)   0           bn_conv1[0][0]
max_pooling2d (MaxPooling2D)    (None, 64, 48, 96)   0           re_lu[0][0]
res2a_branch2a (Conv2D)         (None, 64, 48, 96)   36928       max_pooling2d[0][0]
bn2a_branch2a (BatchNormalizati (None, 64, 48, 96)   256         res2a_branch2a[0][0]
re_lu_1 (ReLU)                  (None, 64, 48, 96)   0           bn2a_branch2a[0][0]
res2a_branch1 (Conv2D)          (None, 64, 48, 96)   4160        max_pooling2d[0][0]
res2a_branch2b (Conv2D)         (None, 64, 48, 96)   36928       re_lu_1[0][0]
bn2a_branch1 (BatchNormalizatio (None, 64, 48, 96)   256         res2a_branch1[0][0]
bn2a_branch2b (BatchNormalizati (None, 64, 48, 96)   256         res2a_branch2b[0][0]
tf_op_layer_add (TensorFlowOpLa [(None, 64, 48, 96)] 0           bn2a_branch1[0][0]
        bn2a_branch2b[0][0]
re_lu_2 (ReLU)                  (None, 64, 48, 96)   0           tf_op_layer_add[0][0]
res2b_branch2a (Conv2D)         (None, 64, 48, 96)   36928       re_lu_2[0][0]
bn2b_branch2a (BatchNormalizati (None, 64, 48, 96)   256         res2b_branch2a[0][0]
re_lu_3 (ReLU)                  (None, 64, 48, 96)   0           bn2b_branch2a[0][0]
res2b_branch2b (Conv2D)         (None, 64, 48, 96)   36928       re_lu_3[0][0]
bn2b_branch2b (BatchNormalizati (None, 64, 48, 96)   256         res2b_branch2b[0][0]
tf_op_layer_add_1 (TensorFlowOp [(None, 64, 48, 96)] 0           re_lu_2[0][0]
        bn2b_branch2b[0][0]
re_lu_4 (ReLU)                  (None, 64, 48, 96)   0           tf_op_layer_add_1[0][0]
res3a_branch2a (Conv2D)         (None, 128, 24, 48)  73856       re_lu_4[0][0]
bn3a_branch2a (BatchNormalizati (None, 128, 24, 48)  512         res3a_branch2a[0][0]
re_lu_5 (ReLU)                  (None, 128, 24, 48)  0           bn3a_branch2a[0][0]
res3a_branch1 (Conv2D)          (None, 128, 24, 48)  8320        re_lu_4[0][0]
res3a_branch2b (Conv2D)         (None, 128, 24, 48)  147584      re_lu_5[0][0]
bn3a_branch1 (BatchNormalizatio (None, 128, 24, 48)  512         res3a_branch1[0][0]
bn3a_branch2b (BatchNormalizati (None, 128, 24, 48)  512         res3a_branch2b[0][0]
tf_op_layer_add_2 (TensorFlowOp [(None, 128, 24, 48) 0           bn3a_branch1[0][0]
        bn3a_branch2b[0][0]
re_lu_6 (ReLU)                  (None, 128, 24, 48)  0           tf_op_layer_add_2[0][0]
res3b_branch2a (Conv2D)         (None, 128, 24, 48)  147584      re_lu_6[0][0]
bn3b_branch2a (BatchNormalizati (None, 128, 24, 48)  512         res3b_branch2a[0][0]
re_lu_7 (ReLU)                  (None, 128, 24, 48)  0           bn3b_branch2a[0][0]
res3b_branch2b (Conv2D)         (None, 128, 24, 48)  147584      re_lu_7[0][0]
bn3b_branch2b (BatchNormalizati (None, 128, 24, 48)  512         res3b_branch2b[0][0]
tf_op_layer_add_3 (TensorFlowOp [(None, 128, 24, 48) 0           re_lu_6[0][0]
        bn3b_branch2b[0][0]
re_lu_8 (ReLU)                  (None, 128, 24, 48)  0           tf_op_layer_add_3[0][0]
res4a_branch2a (Conv2D)         (None, 256, 12, 24)  295168      re_lu_8[0][0]
bn4a_branch2a (BatchNormalizati (None, 256, 12, 24)  1024        res4a_branch2a[0][0]
re_lu_9 (ReLU)                  (None, 256, 12, 24)  0           bn4a_branch2a[0][0]
res4a_branch1 (Conv2D)          (None, 256, 12, 24)  33024       re_lu_8[0][0]
res4a_branch2b (Conv2D)         (None, 256, 12, 24)  590080      re_lu_9[0][0]
bn4a_branch1 (BatchNormalizatio (None, 256, 12, 24)  1024        res4a_branch1[0][0]
bn4a_branch2b (BatchNormalizati (None, 256, 12, 24)  1024        res4a_branch2b[0][0]
tf_op_layer_add_4 (TensorFlowOp [(None, 256, 12, 24) 0           bn4a_branch1[0][0]
        bn4a_branch2b[0][0]
re_lu_10 (ReLU)                 (None, 256, 12, 24)  0           tf_op_layer_add_4[0][0]
res4b_branch2a (Conv2D)         (None, 256, 12, 24)  590080      re_lu_10[0][0]
bn4b_branch2a (BatchNormalizati (None, 256, 12, 24)  1024        res4b_branch2a[0][0]
re_lu_11 (ReLU)                 (None, 256, 12, 24)  0           bn4b_branch2a[0][0]
res4b_branch2b (Conv2D)         (None, 256, 12, 24)  590080      re_lu_11[0][0]
bn4b_branch2b (BatchNormalizati (None, 256, 12, 24)  1024        res4b_branch2b[0][0]
tf_op_layer_add_5 (TensorFlowOp [(None, 256, 12, 24) 0           re_lu_10[0][0]
        bn4b_branch2b[0][0]
re_lu_12 (ReLU)                 (None, 256, 12, 24)  0           tf_op_layer_add_5[0][0]
res5a_branch2a (Conv2D)         (None, 300, 12, 24)  691500      re_lu_12[0][0]
bn5a_branch2a (BatchNormalizati (None, 300, 12, 24)  1200        res5a_branch2a[0][0]
re_lu_13 (ReLU)                 (None, 300, 12, 24)  0           bn5a_branch2a[0][0]
res5a_branch1 (Conv2D)          (None, 300, 12, 24)  77100       re_lu_12[0][0]
res5a_branch2b (Conv2D)         (None, 300, 12, 24)  810300      re_lu_13[0][0]
bn5a_branch1 (BatchNormalizatio (None, 300, 12, 24)  1200        res5a_branch1[0][0]
bn5a_branch2b (BatchNormalizati (None, 300, 12, 24)  1200        res5a_branch2b[0][0]
tf_op_layer_add_6 (TensorFlowOp [(None, 300, 12, 24) 0           bn5a_branch1[0][0]
        bn5a_branch2b[0][0]
re_lu_14 (ReLU)                 (None, 300, 12, 24)  0           tf_op_layer_add_6[0][0]
res5b_branch2a (Conv2D)         (None, 300, 12, 24)  810300      re_lu_14[0][0]
bn5b_branch2a (BatchNormalizati (None, 300, 12, 24)  1200        res5b_branch2a[0][0]
re_lu_15 (ReLU)                 (None, 300, 12, 24)  0           bn5b_branch2a[0][0]
res5b_branch2b (Conv2D)         (None, 300, 12, 24)  810300      re_lu_15[0][0]
bn5b_branch2b (BatchNormalizati (None, 300, 12, 24)  1200        res5b_branch2b[0][0]
tf_op_layer_add_7 (TensorFlowOp [(None, 300, 12, 24) 0           re_lu_14[0][0]
        bn5b_branch2b[0][0]
re_lu_16 (ReLU)                 (None, 300, 12, 24)  0           tf_op_layer_add_7[0][0]
permute_feature (Permute)       (None, 24, 12, 300)  0           re_lu_16[0][0]
flatten_feature (Reshape)       (None, 24, 3600)     0           permute_feature[0][0]
lstm (LSTM)                     (None, 24, 512)      8423424     flatten_feature[0][0]
td_dense (TimeDistributed)      (None, 24, 36)       18468       lstm[0][0]
softmax (Softmax)               (None, 24, 36)       0           td_dense[0][0]
Total params: 14,432,480
Trainable params: 14,424,872
Non-trainable params: 7,608
2021-07-09 05:36:50,237 [INFO] __main__: Number of images in the training dataset:	   111
2021-07-09 05:36:50,237 [INFO] __main__: Number of images in the validation dataset:	   110
Epoch 1/24
1/4 [======>.......................] - ETA: 21s - loss: 1.2432WARNING:tensorflow:Method (on_train_batch_end) is slow compared to the batch update (0.829507). Check your callbacks.
2021-07-09 05:36:58,377 [WARNING] tensorflow: Method (on_train_batch_end) is slow compared to the batch update (0.829507). Check your callbacks.
3/4 [=====================>........] - ETA: 2s - loss: 0.8570tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Bootstrap : Using [0]lo:127.0.0.1<0> [1]eth0:10.244.58.228<0>
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO NET/Plugin : No plugin found (libnccl-net.so), using internal implementation
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO NET/IB : No device found.
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO NET/Socket : Using [0]lo:127.0.0.1<0> [1]eth0:10.244.58.228<0>
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Using network Socket
NCCL version 2.7.8+cuda11.1
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 00/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 01/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 02/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 03/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 04/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 05/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 06/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 07/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 08/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 09/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 10/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 11/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 12/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 13/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 14/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 15/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 16/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 17/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 18/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 19/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 20/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 21/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 22/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 23/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 24/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 25/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 26/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 27/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 28/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 29/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 30/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Channel 31/32 :    0
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Trees [0] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [1] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [2] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [3] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [4] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [5] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [6] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [7] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [8] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [9] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [10] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [11] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [12] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [13] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [14] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [15] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [16] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [17] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [18] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [19] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [20] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [21] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [22] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [23] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [24] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [25] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [26] -1/-1/-1
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO Setting affinity for GPU 0 to ffffff00,0000ffff,ff000000
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO 32 coll channels, 32 p2p channels, 32 p2p channels per peer
tlt-furuse-7bc99fc9f4-mzqtk:5760:5892 [0] NCCL INFO comm 0x7fdd36f61a50 rank 0 nranks 1 cudaDev 0 busId e1000 - Init COMPLETE
Epoch 00001: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-01.tlt
4/4 [==============================] - 18s 5s/step - loss: 0.7808
Epoch 2/24
3/4 [=====================>........] - ETA: 0s - loss: 0.9575
Epoch 00002: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-02.tlt
4/4 [==============================] - 2s 459ms/step - loss: 0.7885
Epoch 3/24
3/4 [=====================>........] - ETA: 0s - loss: 0.9168
Epoch 00003: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-03.tlt
4/4 [==============================] - 1s 333ms/step - loss: 1.0077
Epoch 4/24
3/4 [=====================>........] - ETA: 0s - loss: 0.9096
Epoch 00004: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-04.tlt
4/4 [==============================] - 1s 341ms/step - loss: 0.8356
Epoch 5/24
3/4 [=====================>........] - ETA: 0s - loss: 0.4920
Epoch 00005: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-05.tlt
Accuracy: 98 / 110  0.8909090909090909
4/4 [==============================] - 6s 2s/step - loss: 0.6113
Epoch 6/24
3/4 [=====================>........] - ETA: 0s - loss: 0.7390
Epoch 00006: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-06.tlt
4/4 [==============================] - 1s 357ms/step - loss: 0.7515
Epoch 7/24
3/4 [=====================>........] - ETA: 0s - loss: 0.3931
Epoch 00007: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-07.tlt
4/4 [==============================] - 1s 345ms/step - loss: 0.3741
Epoch 8/24
3/4 [=====================>........] - ETA: 0s - loss: 0.4324
Epoch 00008: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-08.tlt
4/4 [==============================] - 1s 344ms/step - loss: 0.4426
Epoch 9/24
3/4 [=====================>........] - ETA: 0s - loss: 0.3006
Epoch 00009: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-09.tlt
4/4 [==============================] - 1s 355ms/step - loss: 0.2792
Epoch 10/24
3/4 [=====================>........] - ETA: 0s - loss: 0.5126
Epoch 00010: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-10.tlt
Accuracy: 100 / 110  0.9090909090909091
4/4 [==============================] - 4s 1s/step - loss: 0.4461
Epoch 11/24
3/4 [=====================>........] - ETA: 0s - loss: 0.4042
Epoch 00011: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-11.tlt
4/4 [==============================] - 1s 327ms/step - loss: 0.3477
Epoch 12/24
3/4 [=====================>........] - ETA: 0s - loss: 0.3892
Epoch 00012: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-12.tlt
4/4 [==============================] - 1s 329ms/step - loss: 0.3544
Epoch 13/24
3/4 [=====================>........] - ETA: 0s - loss: 0.4416
Epoch 00013: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-13.tlt
4/4 [==============================] - 1s 334ms/step - loss: 0.3674
Epoch 14/24
3/4 [=====================>........] - ETA: 0s - loss: 0.2404
Epoch 00014: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-14.tlt
4/4 [==============================] - 1s 334ms/step - loss: 0.2857
Epoch 15/24
3/4 [=====================>........] - ETA: 0s - loss: 0.6028
Epoch 00015: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-15.tlt
4/4 [==============================] - 4s 1s/step - loss: 0.4996
Epoch 16/24
3/4 [=====================>........] - ETA: 0s - loss: 0.3446
Epoch 00016: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-16.tlt
4/4 [==============================] - 1s 348ms/step - loss: 0.3084
Epoch 17/24
3/4 [=====================>........] - ETA: 0s - loss: 0.1858
Epoch 00017: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-17.tlt
4/4 [==============================] - 1s 339ms/step - loss: 0.2053
Epoch 18/24
3/4 [=====================>........] - ETA: 0s - loss: 0.8404
Epoch 00018: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-18.tlt
4/4 [==============================] - 1s 335ms/step - loss: 0.7287
Epoch 19/24
3/4 [=====================>........] - ETA: 0s - loss: 0.2634
Epoch 00019: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-19.tlt
4/4 [==============================] - 1s 332ms/step - loss: 0.2422
Epoch 20/24
3/4 [=====================>........] - ETA: 0s - loss: 0.5270
Epoch 00020: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-20.tlt
4/4 [==============================] - 4s 1s/step - loss: 0.4482
Epoch 21/24
3/4 [=====================>........] - ETA: 0s - loss: 0.4593
Epoch 00021: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-21.tlt
4/4 [==============================] - 1s 340ms/step - loss: 0.3884
Epoch 22/24
3/4 [=====================>........] - ETA: 0s - loss: 0.2618
Epoch 00022: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-22.tlt
4/4 [==============================] - 1s 334ms/step - loss: 0.2449
Epoch 23/24
3/4 [=====================>........] - ETA: 0s - loss: 0.2673
Epoch 00023: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-23.tlt
4/4 [==============================] - 1s 334ms/step - loss: 0.2799
Epoch 24/24
3/4 [=====================>........] - ETA: 0s - loss: 0.2546
Epoch 00024: saving model to /data/tlt-experiments/lprnet/experiment_dir_unpruned/weights/lprnet_epoch-24.tlt
4/4 [==============================] - 1s 333ms/step - loss: 0.2980
Accuracy: 101 / 110  0.9181818181818182
