• Hardware (T4/V100/Xavier/Nano/etc)
T4
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
Yolo_v4
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
docker_tag: v3.21.08-py3
• Training spec file(If have, please share here)
Problem: I would like to use transfer learning and retrain the yolo_v4 for my custom dataset. and I am receiving an error regarding the mapping issue to docker.
the training image and labels are in the following directory:
~/cv_samples_v1.2.0/data/training
The Yolo_v4 ipython notebook is on :
:~/cv_samples_v1.2.0/yolo_v4
The training images and labels have got the shared id but they are not ordered ( ex. image 0, image 3, image5 and image 0.txt, image 3.txt) in a sequence form of the kitti format.
Does the input image size is important? the images all are in the same sizes
random_seed: 42
yolov4_config {
big_anchor_shape: “[(65.58, 144.56),(167.02, 91.94),(281.86, 179.56)]”
mid_anchor_shape: “[(49.35, 40.93),(74.40, 28.85),(96.41, 56.22) ]”
small_anchor_shape: “[(16.79, 15.72),(33.54, 23.51),(23.51, 59.22)]”
box_matching_iou: 0.25
matching_neutral_box_iou: 0.5
arch: “resnet”
nlayers: 18
arch_conv_blocks: 2
loss_loc_weight: 0.8
loss_neg_obj_weights: 100.0
loss_class_weights: 0.5
label_smoothing: 0.0
big_grid_xy_extend: 0.05
mid_grid_xy_extend: 0.1
small_grid_xy_extend: 0.2
freeze_bn: false
#freeze_blocks: 0
force_relu: false
training_config {
batch_size_per_gpu: 8
num_epochs: 80
enable_qat: true
checkpoint_interval: 10
learning_rate {
soft_start_cosine_annealing_schedule {
min_learning_rate: 1e-7
max_learning_rate: 1e-4
soft_start: 0.3
regularizer {
type: L1
weight: 3e-5
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
pretrain_model_path: “~/cv_samples_v1.2.0/experiment/pretrained_resnet18/pretrained_object_detection_vresnet18/resnet_18.hdf5”
eval_config {
average_precision_mode: SAMPLE
batch_size: 8
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.001
clustering_iou_threshold: 0.5
top_k: 200
augmentation_config {
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0
horizontal_flip: 0.5
jitter: 0.3
output_width: 1248
output_height: 384
output_channel: 3
randomize_input_shape_period: 0
mosaic_prob: 0.5
mosaic_min_ratio:0.2
dataset_config {
data_sources: {
label_directory_path: “/home/ubuntu/cv_samples_v1.2.0/training/data/labels”
image_directory_path: “/home/ubuntu/cv_samples_v1.2.0/training/data/images”
include_difficult_in_training: true
target_class_mapping {
key: “car”
value: “car”
key: “pedestrian”
value: “pedestrian”
key: “cyclist”
value: “cyclist”
key: “Car”
value: “car”
key: “person_sitting”
value: “pedestrian”
key: “HVAC Unit”
value: “HVAC Unit”
key: “Person”
value: “Person”
validation_data_sources: {
label_directory_path: “/workspace/tao-experiments/data/val/label”
image_directory_path: “/workspace/tao-experiments/data/val/image”
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
print(“To run with multigpu, please change --gpus based on the number of available GPUs in your machine.”)
print("To run with multigpu, please change --gpus based on the number of available GPUs in your machine.")
!tao yolo_v4 train -e $SPECS_DIR/yolo_v4_train_resnet18_kitti_seq.txt \
-r $USER_EXPERIMENT_DIR/experiment_dir_unpruned \
-k $KEY \
--gpus 1
2021-09-29 22:10:10,448 [INFO] root: Registry: [‘nvcr.io’]
2021-09-29 22:10:10,524 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the “/home/ubuntu/.tao_mounts.json” file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-09-29 22:10:16,690 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-09-29 22:10:16,691 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:40: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2021-09-29 22:10:16,744 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:40: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:43: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2021-09-29 22:10:16,745 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:43: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-09-29 22:10:17,197 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-09-29 22:10:17,199 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-09-29 22:10:17,217 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
2021-09-29 22:10:17,806 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2021-09-29 22:10:18,031 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2021-09-29 22:10:18,394 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2021-09-29 22:10:18,394 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2021-09-29 22:10:18,786 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 110, in
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py”, line 494, in return_func
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py”, line 482, in return_func
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 106, in main
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 58, in run_experiment
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/models/utils.py”, line 57, in build_training_pipeline
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/dataio/data_sequence.py”, line 18, in init
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/dataio/detection_data_sequence.py”, line 52, in init
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/dataio/detection_data_sequence.py”, line 73, in _add_source
FileNotFoundError: [Errno 2] No such file or directory: ‘/home/ubuntu/cv_samples_v1.2.0/training/data/images’
2021-09-29 22:11:21,462 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
#------------ ----------- defenition of environmental variable and mapping to docker
# Setting up env variables for cleaner command line commands.
import os
print("Please replace the variable with your key.")
%env KEY=nvidia_tlt
# %env USER_EXPERIMENT_DIR=/workspace/tao-experiments/yolo_v4
# %env DATA_DOWNLOAD_DIR=/workspace/tao-experiments/data
%env USER_EXPERIMENT_DIR=/home/ubuntu/cv_samples_v1.2.0/experiment
%env DATA_DOWNLOAD_DIR=/home/ubuntu/cv_samples_v1.2.0/data
# Set this path if you don't run the notebook from the samples directory.
#%env NOTEBOOK_ROOT=~/cv_samples_v1.2.0/yolo_v4
# Please define this local project directory that needs to be mapped to the TAO docker session.
# The dataset expected to be present in $LOCAL_PROJECT_DIR/data, while the results for the steps
# in this notebook will be stored at $LOCAL_PROJECT_DIR/yolo_v4
# %env LOCAL_PROJECT_DIR=YOUR_LOCAL_PROJECT_DIR_PATH
%env LOCAL_PROJECT_DIR=/home/ubuntu/cv_samples_v1.2.0
os.environ["LOCAL_DATA_DIR"] = os.path.join(os.getenv("LOCAL_PROJECT_DIR", os.getcwd()), "data")
os.environ["LOCAL_EXPERIMENT_DIR"] = os.path.join(os.getenv("LOCAL_PROJECT_DIR", os.getcwd()), "yolo_v4")
# The sample spec files are present in the same path as the downloaded samples.
os.environ["LOCAL_SPECS_DIR"] = os.path.join(
os.getenv("NOTEBOOK_ROOT", os.getcwd()),
"specs"
#%env SPECS_DIR=/workspace/tao-experiments/yolo_v4/specs
%env SPECS_DIR=/home/ubuntu/cv_samples_v1.2.0/yolo_v4/specs
# Showing list of specification files.
!ls -rlt $LOCAL_SPECS_DIR
# Mapping up the local directories to the TAO docker.
import json
mounts_file = os.path.expanduser("~/.tao_mounts.json")
# Define the dictionary with the mapped drives
drive_map = {
"Mounts": [
# Mapping the data directory
"source": os.environ["LOCAL_PROJECT_DIR"],
"destination": os.environ["LOCAL_PROJECT_DIR"]
# Mapping the specs directory.
"source": os.environ["LOCAL_SPECS_DIR"],
"destination": os.environ["LOCAL_SPECS_DIR"]
# Writing the mounts file.
with open(mounts_file, "w") as mfile:
json.dump(drive_map, mfile, indent=4)
#-------- the out put --------------------------
“Mounts”: [
“source”: “/home/ubuntu/cv_samples_v1.2.0”,
“destination”: “/home/ubuntu/cv_samples_v1.2.0”
“source”: “/home/ubuntu/cv_samples_v1.2.0/yolo_v4/specs”,
“destination”: “/home/ubuntu/cv_samples_v1.2.0/yolo_v4/specs”
