Hi,Mat,
can I use PGI accelerator compiler for programming without GPU card?
I try to install PGI accelerator compiler in one computer without GPU card,and run pgaccelinfo -v ,the result is :
libcuda.so not found
libamdcalcl.so not found
No accelerators found.
Check that you have installed the CUDA or CAL libraries properly
Check that your LD_LIBRARY_PATH environment variable points to the CUDA or CAL runtime installation directory
Is that mean that I could not use PGI accelerator compiler ?
I’m looking forward your reply
