Can Jetson Orin Nano handle four network camera streams and perform object detection?
For my application I am planning to use Jetson Orin Nano 8GB variant, will it support 4 network camera stream of (1280 x 720) resolution 60 FPS.
I have custom camera setup which usages Arducam B0348 2MP Global Shutter 120 FPS and RPI 4. This stream over ethernet network. On receiving end 60 FPS I am getting from each camera.
Please response quickly, so that I can place order
The hardware decoder is capable of decoding 4x 720p60. For more information, please look at module data sheet:
https://developer.nvidia.com/downloads/assets/embedded/secure/jetson/orin_nano/docs/jetson_orin_nano_ds
Please note there is no hardware encoder in Orin Nano. If you need hardware encoder, please consider use Orin NX or Xavier NX.
