I install the deepstream below command
sudo apt install deepstream-7.1
and then I entry DIR , follow the README
Search and Download 3D and 2D RGB based tao_iva_action_recognition_pretrained
models from NGC Action Recognition Net | NVIDIA NGC
into this folder. The 2 TAO models are
resnet18_3d_rgb_hmdb5_32.onnx
resnet18_2d_rgb_hmdb5_32.onnx
But I can not find out the 2 TAO models, I can only download resnet18_3d_rgb_hmdb5_32.tlt
Could you please help to check this issue?
This depends on your device’s capabilities. Do you run this model on dGPU or a Jetson? What model is it? For dGPU, you can use nvidia-smi. For Jetson, you can use jtop to check GPU usage.
