DeepStream
DeepStream 3D Action Recognition App
by link :
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_3D_Action.html
Report the following error:
WARNING: …/nvdsinfer/nvdsinfer_model_builder.cpp:1487 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/deepstream-3d-action-recognition/./resnet18_3d_rgb_hmdb5_32.etlt_b4_gpu0_fp16.engine open error
0:00:05.697836411 6426 0x55f4c657ed00 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2080> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/deepstream-3d-action-recognition/./resnet18_3d_rgb_hmdb5_32.etlt_b4_gpu0_fp16.engine failed
0:00:05.851469165 6426 0x55f4c657ed00 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2185> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/deepstream-3d-action-recognition/./resnet18_3d_rgb_hmdb5_32.etlt_b4_gpu0_fp16.engine failed, try rebuild
0:00:05.851497026 6426 0x55f4c657ed00 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2106> [UID = 1]: Trying to create engine from model files
NvDsInferCudaEngineGetFromTltModel: Failed to open TLT encoded model file /opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/deepstream-3d-action-recognition/./resnet18_3d_rgb_hmdb5_32.etlt
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:728 Failed to create network using custom network creation function
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:794 Failed to get cuda engine from custom library API
0:00:11.000593381 6426 0x55f4c657ed00 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2126> [UID = 1]: build engine file failed
free(): double free detected in tcache 2
已中止 (核心已转储)
• DeepStream Version
• TensorRT Version
• The pipeline being used
This sample needs to download the corresponding model file. You can refer to the link mentioned in the README.
Search and Download 3D and 2D RGB based tao_iva_action_recognition_pretrained
models from NGC https://ngc.nvidia.com/catalog/models/nvidia:tao:actionrecognitionnet
into this folder. The 2 TAO models are
  resnet18_2d_rgb_hmdb5_32.etlt
sudo unzip files.zip
Archive: files.zip
inflating: resnet18 2d of hmdb5 32 a100.etlt
inflating: resnet18 2d of hmdb5 32 xavier.etlt
inflating: resnet18 3d of hmdb5 32 a100.etlt
inflating:resnet18 3d of hmdb5 32 xavier.etlt
resnet18_3d_rgb_hmdb5_32.etlt does not exist
problem was solved
