• Hardware Platform (Jetson / GPU): Jetson Orin Nano
• DeepStream Version: deepstream-6.4
• JetPack Version (valid for Jetson only) : Version: 6.0-b52
• TensorRT Version : Version: 8.6.2
• NVIDIA GPU Driver Version (valid for GPU only) : NA
I simply tried to run
python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-6.4/samples/streams/sample_720p.h264
I got the following error :
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating nv3dsink
Playing file /opt/nvidia/deepstream/deepstream-6.4/samples/streams/sample_720p.h264
Adding elements to Pipeline
Linking elements in the Pipeline
/home/t-tech/DeepStreamPythonApp/deepstream_python_apps/apps/deepstream-test1/deepstream_test_1.py:220: DeprecationWarning: Gst.Element.get_request_pad is deprecated
sinkpad = streammux.get_request_pad(“sink_0”)
Starting pipeline
Opening in BLOCKING MODE
WARNING: Deserialize engine failed because file path: /home/t-tech/DeepStreamPythonApp/deepstream_python_apps/apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b1_gpu0_int8.engine open error
0:00:25.415393661 5332 0xaaaafc2d0a40 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2080> [UID = 1]: deserialize engine from file :/home/t-tech/DeepStreamPythonApp/deepstream_python_apps/apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b1_gpu0_int8.engine failed
0:00:25.830701547 5332 0xaaaafc2d0a40 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2185> [UID = 1]: deserialize backend context from engine from file :/home/t-tech/DeepStreamPythonApp/deepstream_python_apps/apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b1_gpu0_int8.engine failed, try rebuild
0:00:25.830787852 5332 0xaaaafc2d0a40 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2106> [UID = 1]: Trying to create engine from model files
WARNING: INT8 calibration file not specified/accessible. INT8 calibration can be done through setDynamicRange API in ‘NvDsInferCreateNetwork’ implementation
NvDsInferCudaEngineGetFromTltModel: Failed to open TLT encoded model file /home/t-tech/DeepStreamPythonApp/deepstream_python_apps/apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt
ERROR: Failed to create network using custom network creation function
ERROR: Failed to get cuda engine from custom library API
0:00:32.265909785 5332 0xaaaafc2d0a40 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2126> [UID = 1]: build engine file failed
double free or corruption (fasttop)
Aborted (core dumped)
Can anyone help me, I am trying to learn deepstream SDK. Thanks in advance.
