I downloaded and installed deepstream5.0 and want to try tun deepstream-test1.
This is my device information:
Hardware Platform:Jetson nano 4GB
deepstream-app version 5.0.0
DeepStreamSDK 5.0.0
CUDA Driver Version: 10.2
CUDA Runtime Version: 10.2
TensorRT Version: 7.1
cuDNN Version: 8.0
libNVWarp360 Version: 2.0.1d3
But when I exeute “./deepstream-test1-app /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.h264”,the systm prompts as follows:
Using winsys: x11
Opening in BLOCKING MODE
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:06.981267158 22962 0x558d452e30 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:06.981386640 22962 0x558d452e30 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:06.981428464 22962 0x558d452e30 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
WARNING: INT8 not supported by platform. Trying FP16 mode.
INFO: [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: [TRT]: Detected 1 inputs and 2 output network tensors.
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine opened error
0:00:56.737295446 22962 0x558d452e30 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:56.932605208 22962 0x558d452e30 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Running…
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Frame Number = 0 Number of objects = 5 Vehicle Count = 3 Person Count = 2
0:00:57.845265639 22962 0x558d44a370 WARN nvinfer gstnvinfer.cpp:1975:gst_nvinfer_output_loop: error: Internal data stream error.
0:00:57.845313244 22962 0x558d44a370 WARN nvinfer gstnvinfer.cpp:1975:gst_nvinfer_output_loop: error: streaming stopped, reason error (-5)
ERROR from element primary-nvinference-engine: Internal data stream error.
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1975): gst_nvinfer_output_loop (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
Deleting pipeline
Who can give me a favor? Thank you !
