Problem in deepstream-app
Jetson Nano
• DeepStream Version
DeepStream 5.0
JetPack 4.4.1 [L4T 32.4.4]
• TensorRT Version
TensorRT 7.1.3.0
Smaple DeepStream-app
I am a beginner on DeepStream.
I modified my config file and ran the pre-built Deepstream-app, but the process ends with the following error.
Why am I getting this error?
Seems your device don’t have enough memory, can you run deepstream-test1 successfully?
After making deepstream-test1, the output is as follows. This did not run well.
$ ./deepstream-test1-app source_test.txt
Now playing: source_test.txt
Using winsys: x11
Opening in BLOCKING MODE
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:01.608860802 4033 0x55977c7520 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:01.608947054 4033 0x55977c7520 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:01.608981117 4033 0x55977c7520 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
WARNING: INT8 not supported by platform. Trying FP16 mode.
INFO: [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: [TRT]: Detected 1 inputs and 2 output network tensors.
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine opened error
0:00:29.526124832 4033 0x55977c7520 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:29.576644798 4033 0x55977c7520 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Running…
ERROR from element h264-parser: No valid frames found before end of stream
Error details: gstbaseparse.c(3603): gst_base_parse_loop (): /GstPipeline:dstest1-pipeline/GstH264Parse:h264-parser
Returned, stopping playback
Deleting pipeline
./deepstream-test1-app only receive h264 stream, please check NVIDIA DeepStream SDK Developer Guide — DeepStream 6.1.1 Release documentation
