TX2 NX
Jetpack 4.6
deepstream-app version 6.0.1
DeepStreamSDK 6.0.1
CUDA Driver Version: 10.2
CUDA Runtime Version: 10.2
TensorRT Version: 8.0
cuDNN Version: 8.2
libNVWarp360 Version: 2.0.1d3
DeepStream_Python_Apps_Bindings_v1.1.1
python 3.6.9
I try to run :python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
, there is an error :
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
Using winsys: x11
Opening in BLOCKING MODE
0:00:00.865597155 11036 0x1c22aed0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1161> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps-1.1.1/apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:02.592227394 11036 0x1c22aed0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps-1.1.1/apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:02.592437131 11036 0x1c22aed0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps-1.1.1/apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:02.592544801 11036 0x1c22aed0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: INT8 not supported by platform. Trying FP16 mode.
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine opened error
0:01:00.543486947 11036 0x1c22aed0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1942> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:01:00.795921420 11036 0x1c22aed0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Frame Number=0 Number of Objects=8 Vehicle_count=5 Person_count=3
0:01:01.181565217 11036 0x1bd83e80 WARN nvinfer gstnvinfer.cpp:2288:gst_nvinfer_output_loop: error: Internal data stream error.
0:01:01.181620572 11036 0x1bd83e80 WARN nvinfer gstnvinfer.cpp:2288:gst_nvinfer_output_loop: error: streaming stopped, reason error (-5)
Error: gst-stream-error-quark: Internal data stream error. (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(2288): gst_nvinfer_output_loop (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
Frame Number=1 Number of Objects=9 Vehicle_count=6 Person_count=3
How can I fix this ?
