Deepstream 6.1 python test1 aborts (GstNvInfer:primary-inference: streaming stopped, reason not-negotiated (-4))
RTX3060
• DeepStream Version
6.1
510
I’m using the Deepstream 6.1 container with python bindings added.
I’m launching deepstream-test1, and it quickly aborts (although it seems to have done some inference)
The display window (EGL) appears but closes immedietly.
I have DISPLAY=:1, and called xhost + on the host.
root@dsp-video-c4:/opt/nvidia/deepstream/deepstream-6.1/sources/deepstream_python_apps/apps/deepstream-test1# python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_720p.h264
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file /opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_720p.h264
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
libEGL warning: DRI2: failed to authenticate
0:00:01.721992059   591      0x3825c30 WARN                 nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1161> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:03.600051340   591      0x3825c30 INFO                 nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x368x640
1   OUTPUT kFLOAT conv2d_bbox     16x23x40
2   OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:03.616887177   591      0x3825c30 INFO                 nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2003> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:03.617545445   591      0x3825c30 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
Frame Number=0 Number of Objects=13 Vehicle_count=9 Person_count=4
0:00:03.858995369   591      0x26632a0 WARN                 nvinfer gstnvinfer.cpp:2299:gst_nvinfer_output_loop:<primary-inference> error: Internal data stream error.
0:00:03.859027097   591      0x26632a0 WARN                 nvinfer gstnvinfer.cpp:2299:gst_nvinfer_output_loop:<primary-inference> error: streaming stopped, reason not-negotiated (-4)
Error: gst-stream-error-quark: Internal data stream error. (1): gstnvinfer.cpp(2299): gst_nvinfer_output_loop (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
Frame Number=1 Number of Objects=11 Vehicle_count=8 Person_count=3
Frame Number=2 Number of Objects=11 Vehicle_count=7 Person_count=4
Frame Number=3 Number of Objects=11 Vehicle_count=7 Person_count=4
Frame Number=4 Number of Objects=11 Vehicle_count=8 Person_count=3
Frame Number=5 Number of Objects=12 Vehicle_count=8 Person_count=4
Frame Number=6 Number of Objects=11 Vehicle_count=7 Person_count=4
#Execution terminated here
CUDA_ERROR_INVALID_GRAPHICS_CONTEXT = 219
This indicates an error with OpenGL or DirectX context.
do this, prime-select nvidia and try again.
