What is the cause of the Unknown embedded device detected error when running the Deepstream example?
Platform
- HW : xavier NX module & custom carrier board
- jetpack 4.6.1
- deepstream 6.0.1
Command
deepstream-app -c source1_csi_dec_infer_resnet_int8.txt
(gst-plugin-scanner:29367): GStreamer-WARNING **: 17:27:30.572: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:29367): GStreamer-WARNING **: 17:27:30.716: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine open error
0:00:06.027952602 29366 0x20e16870 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed
0:00:06.057529459 29366 0x20e16870 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed, try rebuild
0:00:06.057635727 29366 0x20e16870 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
ERROR: [TRT]: 2: [utils.cpp::checkMemLimit::380] Error Code 2: Internal Error (Assertion upperBound != 0 failed. Unknown embedded device detected. Please update the table with the entry: {{1794, 6, 16}, 12653},)
ERROR: Build engine failed from config file
ERROR: failed to build trt engine.
0:00:09.948913595 29366 0x20e16870 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 1]: build engine file failed
0:00:09.974432385 29366 0x20e16870 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2020> [UID = 1]: build backend context failed
0:00:09.974562716 29366 0x20e16870 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1257> [UID = 1]: generate backend failed, check config file settings
0:00:09.974657624 29366 0x20e16870 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
0:00:09.974729814 29366 0x20e16870 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Config file path: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/config_infer_primary.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
** ERROR: <main:707>: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(841): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
If it is a problem with the custom carrier board, what actions can the custom carrier board manufacturer take to solve it?
Thank you.
