Deepstream sample code error in jetson xavier NX
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1.1
• TensorRT Version TensorRT 8.5.2
• Issue Type( questions, new requirements, bugs) questions
I was trying to run deepstream sample code in jetson xavier NX (jetpack 5.1.1).
but I met some error codes, and I don’t know how to fix.
I need help. Please let me know what was the reason.
deepstream-app -c configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
WARNING: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:00:14.982404198 7323 0xaaab06286460 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1897> [UID = 6]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:15.065878690 7323 0xaaab06286460 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2002> [UID = 6]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:15.066518022 7323 0xaaab06286460 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 6]: Trying to create engine from model files
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
Warning: Flatten layer ignored. TensorRT implicitly flattens input to FullyConnected layers, but in other circumstances this will result in undefined behavior.
WARNING: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-6.2/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine opened error
0:02:12.221101900 7323 0xaaab06286460 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1950> [UID = 6]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.2/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 20x1x1
nvbufsurface: Failed to create EGLImage.
0:02:12.480478906 7323 0xaaab06286460 WARN nvinfer gstnvinfer.cpp:985:gst_nvinfer_start:<secondary_gie_2> error: Failed to set buffer pool to active
** ERROR: main:716: Failed to set pipeline to PAUSED
Quitting
nvstreammux: Successfully handled EOS for source_id=0
nvstreammux: Successfully handled EOS for source_id=1
nvstreammux: Successfully handled EOS for source_id=2
nvstreammux: Successfully handled EOS for source_id=3
ERROR from secondary_gie_2: Failed to set buffer pool to active
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(985): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:secondary_gie_bin/GstNvInfer:secondary_gie_2
App run failed
Could you attach the log with GST_DEBUG=3 deepstream-app -c configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt?
this is the log
deepstream-app -c configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt --gst-debug=3
0:00:02.957140924 104162 0xaaaae74c1010 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1897> [UID = 6]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:03.016659389 104162 0xaaaae74c1010 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2002> [UID = 6]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:03.016779934 104162 0xaaaae74c1010 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 6]: Trying to create engine from model files
0:01:31.702450364 104162 0xaaaae74c1010 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1950> [UID = 6]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.2/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
0:01:31.860789128 104162 0xaaaae74c1010 ERROR nvinferallocator gstnvinfer_allocator.cpp:102:gst_nvinfer_allocator_alloc: Error: Could not map EglImage from NvBufSurface for nvinfer
0:01:31.860855625 104162 0xaaaae74c1010 WARN GST_BUFFER gstbuffer.c:951:gst_buffer_new_allocate: failed to allocate 88 bytes
0:01:31.860907882 104162 0xaaaae74c1010 WARN bufferpool gstbufferpool.c:305:do_alloc_buffer: alloc function failed
0:01:31.860939210 104162 0xaaaae74c1010 WARN bufferpool gstbufferpool.c:338:default_start: failed to allocate buffer
0:01:31.861006059 104162 0xaaaae74c1010 ERROR bufferpool gstbufferpool.c:559:gst_buffer_pool_set_active: start failed
0:01:31.861063820 104162 0xaaaae74c1010 WARN nvinfer gstnvinfer.cpp:985:gst_nvinfer_start:<secondary_gie_2> error: Failed to set buffer pool to active
0:01:31.869265658 104162 0xaaaae74c1010 WARN GST_PADS gstpad.c:1142:gst_pad_set_active:<secondary_gie_2:sink> Failed to activate pad
Quitting
App run failed
Is your platform connected to a monitor? It shows your display env has problems.
Or you can choose the fakesink or filesink type to run the app.
The monitor is connected to the jetson and resolved Thank you.
