**• Hardware Platform (Jetson)
**• DeepStream Version 6.3
**• JetPack Version - # R35 (release), REVISION: 5.0, GCID: 35550185, BOARD: t186ref, EABI: aarch64, DATE: Tue Feb 20 04:46:31 UTC 2024
**• TensorRT Version
glueck@ubuntu:~$ dpkg -l | grep TensorRT
ii graphsurgeon-tf 8.5.2-1+cuda11.4 arm64 GraphSurgeon for TensorRT package
ii libnvinfer-bin 8.5.2-1+cuda11.4 arm64 TensorRT binaries
ii libnvinfer-dev 8.5.2-1+cuda11.4 arm64 TensorRT development libraries and headers
ii libnvinfer-plugin-dev 8.5.2-1+cuda11.4 arm64 TensorRT plugin libraries
ii libnvinfer-plugin8 8.5.2-1+cuda11.4 arm64 TensorRT plugin libraries
ii libnvinfer-samples 8.5.2-1+cuda11.4 all TensorRT samples
ii libnvinfer8 8.5.2-1+cuda11.4 arm64 TensorRT runtime libraries
ii libnvonnxparsers-dev 8.5.2-1+cuda11.4 arm64 TensorRT ONNX libraries
ii libnvonnxparsers8 8.5.2-1+cuda11.4 arm64 TensorRT ONNX libraries
ii libnvparsers-dev 8.5.2-1+cuda11.4 arm64 TensorRT parsers libraries
ii libnvparsers8 8.5.2-1+cuda11.4 arm64 TensorRT parsers libraries
ii onnx-graphsurgeon 8.5.2-1+cuda11.4 arm64 ONNX GraphSurgeon for TensorRT package
ii python3-libnvinfer 8.5.2-1+cuda11.4 arm64 Python 3 bindings for TensorRT
ii python3-libnvinfer-dev 8.5.2-1+cuda11.4 arm64 Python 3 development package for TensorRT
ii tensorrt 8.5.2.2-1+cuda11.4 arm64 Meta package for TensorRT
ii tensorrt-libs 8.5.2.2-1+cuda11.4 arm64 Meta package for TensorRT runtime libraries
ii uff-converter-tf 8.5.2-1+cuda11.4 arm64 UFF converter for TensorRT package
glueck@ubuntu:~$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX Open Kernel Module for aarch64 35.5.0 Release Build (buildbrain@mobile-u64-6519-d7000) Mon Feb 19 20:34:12 PST 2024
GCC version: gcc version 9.3.0 (Buildroot 2020.08)
glueck@ubuntu:/opt/nvidia/deepstream/deepstream-6.3/samples/configs/tao_pretrained_models/deepstream_reference_apps/deepstream_app_tao_configs$ sudo deepstream-app -c deepstream_app_source1_peoplenet.txt
** WARN: <parse_tracker:1604>: Unknown key ‘enable-batch-process’ for group [tracker]
** WARN: <parse_tracker:1604>: Unknown key ‘enable-past-frame’ for group [tracker]
Warning: ‘input-dims’ parameter has been deprecated. Use ‘infer-dims’ instead.
ERROR: [TRT]: 1: [stdArchiveReader.cpp::StdArchiveReader::32] Error Code 1: Serialization (Serialization assertion magicTagRead == kMAGIC_TAG failed.Magic tag does not match)
ERROR: [TRT]: 4: [runtime.cpp::deserializeCudaEngine::65] Error Code 4: Internal Error (Engine deserialization failed.)
ERROR: Deserialize engine failed from file: /home/glueck/Downloads/pcp-gce-pcp-gce-v1.3@2c41f1f8df8/assets/glueck-ce/glueck-ce-services/model/gender-model-caffe-v2.0/gender.caffemodel
0:00:05.662980820 7478 0xaaaad6b7bd00 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1976> [UID = 2]: deserialize engine from file :/home/glueck/Downloads/pcp-gce-pcp-gce-v1.3@2c41f1f8df8/assets/glueck-ce/glueck-ce-services/model/gender-model-caffe-v2.0/gender.caffemodel failed
0:00:05.866090648 7478 0xaaaad6b7bd00 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2081> [UID = 2]: deserialize backend context from engine from file :/home/glueck/Downloads/pcp-gce-pcp-gce-v1.3@2c41f1f8df8/assets/glueck-ce/glueck-ce-services/model/gender-model-caffe-v2.0/gender.caffemodel failed, try rebuild
0:00:05.866219162 7478 0xaaaad6b7bd00 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2002> [UID = 2]: Trying to create engine from model files
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
ERROR: Could not find output layer ‘prob’
ERROR: failed to build network since parsing model errors.
ERROR: failed to build network.
0:00:08.194638220 7478 0xaaaad6b7bd00 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2022> [UID = 2]: build engine file failed
0:00:08.404800203 7478 0xaaaad6b7bd00 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2108> [UID = 2]: build backend context failed
0:00:08.404868461 7478 0xaaaad6b7bd00 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1282> [UID = 2]: generate backend failed, check config file settings
0:00:08.404928974 7478 0xaaaad6b7bd00 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start:<secondary_gie_0> error: Failed to create NvDsInferContext instance
0:00:08.404947054 7478 0xaaaad6b7bd00 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start:<secondary_gie_0> error: Config file path: /home/glueck/Downloads/gce-deepstream-master@d60d0d171d5/gce-deepstream/configs/tlt_pretrained_models/config_infer_gender_classifier.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
** ERROR: main:716: Failed to set pipeline to PAUSED
Quitting
nvstreammux: Successfully handled EOS for source_id=0
ERROR from secondary_gie_0: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(898): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:secondary_gie_bin/GstNvInfer:secondary_gie_0:
App run failed
config_infer_gender_classifier.txt (3.8 KB)
deepstream_app_source1_peoplenet.txt (5.9 KB)
the secondary gie is not loading the model and running, can i know what is the error, ive given the config files
