Warning: ‘input-dims’ parameter has been deprecated. Use ‘infer-dims’ instead.
** ERROR: main:1451: Failed to set pipeline to PAUSED
Quitting
ERROR from sink_sub_bin_sink1: Could not configure supporting library.
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmsgbroker/gstnvmsgbroker.c(388): legacy_gst_nvmsgbroker_start (): /GstPipeline:pipeline/GstBin:sink_sub_bin1/GstNvMsgBroker:sink_sub_bin_sink1:
unable to connect to broker library
ERROR from sink_sub_bin_sink1: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debug info: gstbasesink.c(5265): gst_base_sink_change_state (): /GstPipeline:pipeline/GstBin:sink_sub_bin1/GstNvMsgBroker:sink_sub_bin_sink1:
Failed to start
App run failed
HI,
If your purpose is for person counting, you do not need to use test5 sample, which is for message conversion/message broker sending. sample sources/apps/sample_apps/deepstream-infer-tensor-meta-test also have function of person counting, check this, deepstream_infer_tensor_meta_test.cpp::osd_sink_pad_buffer_probe
I built the application following your advice , using deepstream_infer_tensor_meta_test.cpp::osd_sink_pad_buffer_probe, but it does not return anything output, here is the output
deepstream-infer-tensor-meta-app -t infer sample_1080p_h265.mp4
With tracker
Now playing...
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1523 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/../../../../samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:00:00.362509777 5652 0x55e64bd5d300 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary3-nvinference-engine> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 4]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/../../../../samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:00.362530850 5652 0x55e64bd5d300 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary3-nvinference-engine> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 4]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/../../../../samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:00.362539130 5652 0x55e64bd5d300 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary3-nvinference-engine> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 4]: Trying to create engine from model files
Warning: Flatten layer ignored. TensorRT implicitly flattens input to FullyConnected layers, but in other circumstances this will result in undefined behavior.
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Reading Calibration Cache for calibrator: EntropyCalibration2
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 1 output network tensors.
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1495 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine opened error
0:00:09.604348153 5652 0x55e64bd5d300 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary3-nvinference-engine> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 4]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
WARNING: ../nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 6x1x1
0:00:09.614640321 5652 0x55e64bd5d300 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary3-nvinference-engine> [UID 4]: Load new model:dstensor_sgie3_config.txt sucessfully
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1523 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/../../../../samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:00:09.614886090 5652 0x55e64bd5d300 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 3]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/../../../../samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:09.614898128 5652 0x55e64bd5d300 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 3]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/../../../../samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:09.614905552 5652 0x55e64bd5d300 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 3]: Trying to create engine from model files
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1495 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine opened error
0:00:18.714756243 5652 0x55e64bd5d300 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 3]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 20x1x1
0:00:18.719793793 5652 0x55e64bd5d300 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary2-nvinference-engine> [UID 3]: Load new model:dstensor_sgie2_config.txt sucessfully
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1523 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/../../../../samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:00:18.720020856 5652 0x55e64bd5d300 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 2]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/../../../../samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:18.720032163 5652 0x55e64bd5d300 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 2]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/../../../../samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:18.720039042 5652 0x55e64bd5d300 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 2]: Trying to create engine from model files
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1495 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine opened error
0:00:27.464669075 5652 0x55e64bd5d300 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 2]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 12x1x1
0:00:27.471882893 5652 0x55e64bd5d300 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary1-nvinference-engine> [UID 2]: Load new model:dstensor_sgie1_config.txt sucessfully
0:00:27.471981955 5652 0x55e64bd5d300 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 2 output network tensors.
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1495 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine opened error
0:00:34.010691375 5652 0x55e64bd5d300 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:34.016935831 5652 0x55e64bd5d300 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:dstensor_pgie_config.txt sucessfully
Running...
Returned, stopping playback
Deleting pipeline
How can i get bounding box and counter ?, please, there 's no documentation for this.
You make some changes, correct? can you run success with original sample? you can see the counter on the left top corner of the output, also you can see the log,
g_print ("Frame Number = %d Number of objects = %d "
“Vehicle Count = %d Person Count = %d\n”,
frame_number, num_rects, vehicle_count, person_count);
Yes, I made changes, same when running the original sample it’s still the same output, no counter in the upper left corner of the output, nothing in the log ?
