Deepstream engine files not generated
I followed this link and installed deepstream on nvidia jetson nano. https://docs.nvidia.com/metropolis/deepstream/dev-guide/index.html#page/DeepStream_Development_Guide/deepstream_quick_start.html#
after successful installation when i tried to run the app, it actually works but engine files are not loaded. I think it’s loading the actual caffe models and system throttled as temperature goes up.
any help in this regard will be highly appreciated.
command:
deepstream-app -c /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
output console:
Using winsys: x11
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:00:04.518552142 11656 0x31725630 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 6]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:04.518666258 11656 0x31725630 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 6]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:04.518699540 11656 0x31725630 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 6]: Trying to create engine from model files
Warning: Flatten layer ignored. TensorRT implicitly flattens input to FullyConnected layers, but in other circumstances this will result in undefined behavior.
WARNING: INT8 not supported by platform. Trying FP16 mode.
INFO: [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: [TRT]: Detected 1 inputs and 1 output network tensors.
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_fp16.engine opened error
0:01:10.455837500 11656 0x31725630 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 6]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 20x1x1
0:01:10.624943639 11656 0x31725630 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary_gie_2> [UID 6]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_secondary_carmake.txt sucessfully
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:01:10.636087664 11656 0x31725630 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 5]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:01:10.636139488 11656 0x31725630 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 5]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:01:10.636173655 11656 0x31725630 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 5]: Trying to create engine from model files
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_fp16.engine opened error
0:01:56.870545745 11656 0x31725630 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 5]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_fp16.engine
1 OUTPUT kFLOAT predictions/Softmax 12x1x1
0:01:56.932025174 11656 0x31725630 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary_gie_1> [UID 5]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_secondary_carcolor.txt sucessfully
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:01:56.935079856 11656 0x31725630 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 4]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:01:56.935137722 11656 0x31725630 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 4]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:01:56.935175118 11656 0x31725630 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 4]: Trying to create engine from model files
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_fp16.engine opened error
0:02:35.055697947 11656 0x31725630 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 4]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_fp16.engine
1 OUTPUT kFLOAT predictions/Softmax 6x1x1
0:02:35.128324939 11656 0x31725630 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary_gie_0> [UID 4]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
gstnvtracker: Past frame output is OFF
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine open error
0:02:35.693682668 11656 0x31725630 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine failed
0:02:35.693736106 11656 0x31725630 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine failed, try rebuild
0:02:35.693764596 11656 0x31725630 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
INFO: [TRT]: Detected 1 inputs and 2 output network tensors.
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_fp16.engine opened error
0:03:12.950248727 11656 0x31725630 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:03:13.007251989 11656 0x31725630 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:181>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
KLT Tracker Init
KLT Tracker Init
KLT Tracker Init
KLT Tracker Init
** INFO: <bus_callback:167>: Pipeline running
**PERF: 12.75 (12.61) 13.11 (12.97) 12.75 (12.61) 13.11 (12.97)
**PERF: 8.66 (10.03) 8.66 (10.16) 8.66 (10.03) 8.66 (10.16)
WARNING from sink_sub_bin_sink1: A lot of buffers are being dropped.
Debug info: gstbasesink.c(2902): gst_base_sink_is_too_late (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/GstEglGlesSink:sink_sub_bin_sink1:
There may be a timestamping problem, or this computer is too slow.
**PERF: 8.00 (9.24) 8.00 (9.31) 8.00 (9.24) 8.00 (9.31)
**PERF: 8.90 (9.11) 8.90 (9.17) 8.90 (9.11) 8.90 (9.17)
I’m finding this issue as well after updating to 5.0GA from 5.0dp. It seems that the directories are not writable by the user via the standard install.
Please noted below announcements from official websites:
JetPack 4.4 supports DeepStream 5.0 General Availability release
  • DeepStream 5.0 Developer Preview is only supported with JetPack 4.4 Developer Preview.
Can you provide below info:
• DeepStream Version
• TensorRT Version
Hardware Platform: Jetson Nano
DeepStream Version: 5.0 latest version
JetPack Version: 4.4 latest [L4T 32.4.3]
TensorRT Version: 7.1.3.0
NVIDIA GPU Driver Version: CUDA 10.2
@Amycao any other details ?
How about run sample using super power, add sudo before the command
I tried sudo as well, some times engine file generated but when running the same test again it says something like:
Hi @muhammadabdullah34907, @jasonpgf2a,
Under “To install the DeepStream SDK” , there are three methods to install DS5.0, which method did you use?
Method 2: Using the DeepStream tar package
1.Download the DeepStream 5.0 Jetson tar package deepstream_sdk_v5.0.0_jetson.tbz2, to the Jetson device.
2.Enter the following commands to extract and install DeepStream SDK:
$ sudo tar -xvf deepstream_sdk_v5.0.0_jetson.tbz2 -C /
$ cd /opt/nvidia/deepstream/deepstream-5.0
$ sudo ./install.sh
$ sudo ldconfig
I flashed JP4.4GA, and use Method#2 to install DS5.0, then run below command, I don’t see any failure,
$ deepstream-app -c /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
Hi!
Have you solved the problem?
I am a beginner and I am facing the same problem.
solved!
