Segmentation Fault: Running nvidia deepstream 5.0 SDK on Ubuntu
Hardware Platform (Jetson / GPU)=GPU NVIDIA GEFORCE RTX 2060
TensorRT Version=7.0
NVIDIA GPU Driver Version (valid for GPU only):450.102
Issue Type( questions, new requirements, bugs)=bugs
• GCC=7.5
• PYTHON 3.7
• CUDNN 7.6.5
• CUDA 10.2
1
Trying to run nvidia’s deepstream5.0 sdk (sample program) on ubuntu 18.04 by following the document (NVIDIA DeepStream SDK Developer Guide — DeepStream 6.1.1 Release documentation).
The application is installed in the path: “/opt/nvidia/deepstream/deepstream-5.0/”.
The execution command is "deepstream-app -c <config file>"
Example:
"deepstream-app -c /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt"
However got segmentation fault just after opening a blank screen and closing suddenly
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1523 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:00:01.788894483 9829 0x5594636fc490 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 6]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:01.788911328 9829 0x5594636fc490 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 6]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:01.788917862 9829 0x5594636fc490 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 6]: Trying to create engine from model files
Warning: Flatten layer ignored. TensorRT implicitly flattens input to FullyConnected layers, but in other circumstances this will result in undefined behavior.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Reading Calibration Cache for calibrator: EntropyCalibration2
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 1 output network tensors.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1495 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine opened error
0:00:11.045161759 9829 0x5594636fc490 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 6]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
WARNING: …/nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 20x1x1
0:00:11.054222978 9829 0x5594636fc490 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary_gie_2> [UID 6]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_secondary_carmake.txt sucessfully
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1523 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:00:11.054352982 9829 0x5594636fc490 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 5]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:11.054360902 9829 0x5594636fc490 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 5]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:11.054365641 9829 0x5594636fc490 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 5]: Trying to create engine from model files
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1495 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine opened error
0:00:19.492522201 9829 0x5594636fc490 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 5]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 12x1x1
0:00:19.497783953 9829 0x5594636fc490 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary_gie_1> [UID 5]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_secondary_carcolor.txt sucessfully
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1523 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:00:19.497944601 9829 0x5594636fc490 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 4]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:19.497954066 9829 0x5594636fc490 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 4]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:19.497959157 9829 0x5594636fc490 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 4]: Trying to create engine from model files
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1495 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine opened error
0:00:27.394531547 9829 0x5594636fc490 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 4]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 6x1x1
0:00:27.401846636 9829 0x5594636fc490 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary_gie_0> [UID 4]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
gstnvtracker: Past frame output is OFF
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1523 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine open error
0:00:27.405130601 9829 0x5594636fc490 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine failed
0:00:27.405139410 9829 0x5594636fc490 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine failed, try rebuild
0:00:27.405144384 9829 0x5594636fc490 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 2 output network tensors.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1495 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine opened error
0:00:32.442386732 9829 0x5594636fc490 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:32.447113083 9829 0x5594636fc490 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:181>: Pipeline ready
** INFO: <bus_callback:167>: Pipeline running
My nvidia driver and cuda version shown below:
How about you run with sink type 1 Fakesink, is same, please try to clear the cache, and see how it goes,
rm -rf ~/.cache/gstreamer-1.0/
I have reinstalled deepstream and is working fine now
Thank you!
