• Hardware Platform (Jetson / GPU) dGPU, ubuntu 18.04
• DeepStream Version 6.0.1
• TensorRT Version 8.1
• NVIDIA GPU Driver Version (valid for GPU only) 470
I installed Nvidia-Driver, CUDA, TensorRT, DeepStream sdk by following the normal steps of guide.
After installation, when running the deepstream application as following command, it was working well.
deepstream-app -c <path_to_config_file>
Then I intended to run the default python sample apps. so I installed python-bindings, and after that, I tried to run deepstream-nvdsanalytics samle, but I got the following issue.
Now playing…
1 : /media/main/Data/Task/PyTorchYoloTrainer/sample_1080p_h264.mp4
Starting pipeline
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
~~ CLOG[include/modules/NvMultiObjectTracker/NvTrackerParams.hpp, getConfigRoot() @line 54]: [NvTrackerParams::getConfigRoot()] !!![WARNING] Invalid low-level config file caused an exception, but will go ahead with the default config values
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
[NvMultiObjectTracker] Initialized
0:00:00.168387914 24478 0x3503c40 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1161> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1484 Deserialize engine failed because file path: /media/main/Data/Task/PyTorchYoloTrainer/deepstream_src/configs/models/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:00.327292587 24478 0x3503c40 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/media/main/Data/Task/PyTorchYoloTrainer/deepstream_src/configs/models/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:00.327324359 24478 0x3503c40 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/media/main/Data/Task/PyTorchYoloTrainer/deepstream_src/configs/models/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:00.327332955 24478 0x3503c40 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
ERROR: [TRT]: 4: [standardEngineBuilder.cpp::initCalibrationParams::2050] Error Code 4: Internal Error (Calibration failure occurred with no scaling factors detected. This could be due to no int8 calibrator or insufficient custom scales for network layers. Please see int8 sample to setup calibration correctly.)
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1119 Build engine failed from config file
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:811 failed to build trt engine.
0:00:01.150574455 24478 0x3503c40 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 1]: build engine file failed
0:00:01.150740926 24478 0x3503c40 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2020> [UID = 1]: build backend context failed
0:00:01.150754702 24478 0x3503c40 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1257> [UID = 1]: generate backend failed, check config file settings
0:00:01.150778039 24478 0x3503c40 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:01.150784342 24478 0x3503c40 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start: error: Config file path: configs/dsnvanalytics_pgie_config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
[NvMultiObjectTracker] De-initialized
Exiting app
Error: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): gstnvinfer.cpp(841): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
I guess this is concerned with int8 callibration, but I am not sure.
Or these python apps don’t work on deepstream 6.0?
I am looking forward to your help.
Regards
