• Hardware Platform (Jetson / GPU) Jetson Nano • DeepStream Version 5.1 • JetPack Version (valid for Jetson only) 4.5.1 • TensorRT Version 7.1.3.0 • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) bugs • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) python3 deepstream_test1_rtsp_out.py -i /opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_1080p_h264.mp4 • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
When I tried to test the sample of python deepstrem it give me this :
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
nvbuf_utils: Could not get EGL display connection
Unable to create NvStreamMux
Unable to create pgie
Unable to create nvvidconv
Unable to create nvosd
Unable to create nvvidconv_postosd
Creating H264 Encoder
Creating H264 rtppay
Playing file /opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_1080p_h264.mp4
File “deepstream_test1_rtsp_out.py”, line 334, in
sys.exit(main(sys.argv))
File “deepstream_test1_rtsp_out.py”, line 225, in main
streammux.set_property(‘width’, 1920)
AttributeError: ‘NoneType’ object has no attribute ‘set_property’
Does anyone know why ?
Thanks by advance.
Please check if you can run it. Or try deepstream-app. We are able to run the samples successfully. A bit strange you hit the issue. Suggest try other samples.
So like you said I tried to execute the test and it give me this error : One element could not be created. Exiting.
With some debugg I discovered that this line cause the issue :
streammux = gst_element_factory_make (“nvstreammux”, “stream-muxer”);
If it still does not work, we suggest re-flash the system and re-install DeepStream SDK. The default samples should work fine. You would need to have a valid system to run the default samples without any issue.
So after some more test. The c sample works but the python not. For example this is the error I get from deepstream_test_1.py :
python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_720p.h264
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file /opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_720p.h264
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
Using winsys: x11
Opening in BLOCKING MODE
ERROR: Deserialize engine failed because file path: /home/jet/Desktop/deepstream_python_apps/apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:06.079083418 7836 0x34e6c30 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1691> [UID = 1]: deserialize engine from file :/home/jet/Desktop/deepstream_python_apps/apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:06.079180346 7836 0x34e6c30 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1798> [UID = 1]: deserialize backend context from engine from file :/home/jet/Desktop/deepstream_python_apps/apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:06.079214930 7836 0x34e6c30 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 1]: Trying to create engine from model files
ERROR: Cannot access prototxt file ‘/home/jet/Desktop/deepstream_python_apps/apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet10.prototxt’
ERROR: failed to build network since parsing model errors.
ERROR: failed to build network.
0:00:06.079483266 7836 0x34e6c30 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1736> [UID = 1]: build engine file failed
0:00:06.079516860 7836 0x34e6c30 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1822> [UID = 1]: build backend context failed
0:00:06.079545975 7836 0x34e6c30 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1149> [UID = 1]: generate backend failed, check config file settings
0:00:06.079588215 7836 0x34e6c30 WARN nvinfer gstnvinfer.cpp:812:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:06.079611653 7836 0x34e6c30 WARN nvinfer gstnvinfer.cpp:812:gst_nvinfer_start: error: Config file path: dstest1_pgie_config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Error: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(812): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
Thank you so much it finally works !!! To sum up the issue was that the python example was not in the right directory and that you can’t use ssh -Y to launch the test. Is that will be available in the future ? Because it’s a bit annoying…
