Hi everyone,
I used the featureDisk Encryptionto encryp the root file system.
And Now i need to flash existed rootfs from NX board, i used the command
sudo ROOTFS_ENC=1 ./flash.sh -r -G app_enc.img -k APP_ENC jetson-xavier-nx-devkit-emmc mmcblk0p1
And flash
cp app_enc.img bootloader/system_root_encrypted.img
sudo ROOTFS_ENC=1 ./flash.sh -r -k APP_ENC jetson-xavier-nx-devkit-emmc mmcblk0p1
When i flashed over, the NX cannot boot normally. The log is
hvc_sysfs: hypervisor is not present
[ 6.804799] ALSA device list:
[ 6.804905] No soundcards found.
[ 6.806131] Freeing unused kernel memory: 3968K
[ 6.818040] Run /init as init process
��WARNING: clock_disable: clk_power_ungate on gated domain 27 for gpcclk
Root device found: UUID=b4c2f670-3c0d-489a-80be-b309c530a96d
[ 7.137969] tegra_cec 3960000.tegra_cec: Can't find physical address.
[ 7.138144] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 7.221342] random: ld-linux-aarch6: uninitialized urandom read (4 bytes read)
[ 7.274966] random: ld-linux-aarch6: uninitialized urandom read (4 bytes read)
[ 8.614626] tegra-xusb 3610000.xhci: entering ELPG done
[ 8.860531] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
[ 8.860771] CPU: 5 PID: 1 Comm: bash Not tainted 5.10.104-tegra #1
[ 8.860906] Hardware name: Unknown NVIDIA Jetson Xavier NX Developer Kit/NVIDIA Jetson Xavier NX Developer Kit, BIOS 3.1-32827747 03/19/2023
[ 8.861161] Call trace:
[ 8.861245] dump_backtrace+0x0/0x1d0
[ 8.861322] show_stack+0x30/0x40
[ 8.861395] dump_stack+0xd8/0x138
[ 8.861468] panic+0x17c/0x384
[ 8.861556] do_exit+0xaa8/0xab0
[ 8.861640] do_group_exit+0x4c/0xb0
[ 8.861715] __arm64_sys_exit_group+0x28/0x30
[ 8.861810] el0_svc_common.constprop.0+0x80/0x1d0
[ 8.861910] do_el0_svc+0x38/0xb0
[ 8.861984] el0_svc+0x1c/0x30
[ 8.862051] el0_sync_handler+0xa8/0xb0
[ 8.862131] el0_sync+0x16c/0x180
[ 8.862204] SMP: stopping secondary CPUs
[ 8.862313] Kernel Offset: 0x2326486c0000 from 0xffff800010000000
[ 8.862577] PHYS_OFFSET: 0xffffbd12c0000000
[ 8.862879] CPU features: 0x8240002,03802a30
[ 8.863180] Memory Limit: none
[ 8.863752] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00 ]---
So what do i need to do next?
Thank you,
Best Regards,
Ultwcz1997
hello ultwcz1997,
did you test clone/restore on the same board?
had you update the EKS image since user_key is specified in eks.img.
BTW, please gather the complete console logs for reference,
thanks
Hi, @JerryChang
Not, because i worry about data loss.
i have tried to flash all partitions.
sudo ROOTFS_ENC=1 ./flash.sh -r jetson-xavier-nx-devkit-emmc mmcblk0p1, but it still boot successfully.
The whole console logs
console-log (56.6 KB)
Thank you.
ultwcz1997:
sudo ROOTFS_ENC=1
since you’ve enable Disk Encryption, you’ll also need to update eks.img, and given --use_key options to specify the user_key into flash command-line.
for example,
Usage: sudo ./flash.sh [options] <target_board> <rootdev>
Where,
target board: Valid target board name.
rootdev: Proper root device.
-i <enc rfs key file>-- key for disk encryption support.
--user_key <key_file> User provided key file (16-byte) to encrypt user images,
like kernel, kernel-dtb and initrd.
If user_key is specified, SBK key (-v) has to be specified.
For now, user_key file must contain all 0's.
please refer to developer guide, Disk Encryption — Jetson Linux Developer Guide documentation .
Hi @JerryChang
Thanks for your reply,
I used option -i to generate image to flash Jetson device
sudo ROOTFS_ENC=1 ./flash.sh -i “./ekb.key” jetson-xavier-nx-devkit-emmc mmcblk0p1
But i can not use --user_key before, So what value should i set?
Thank you. ^_^
hello ultwcz1997,
may I double confirm the release version you’re working with?
FYI,
the option --user_key is only supported in JP-4 to encrypt/decrypt user images, such as kernel/kernel-dtb. however, this is removed in JP-5.
you cannot use --user_key options in the JP-5, or it may cause unexpected issues.
Hi
JetPack5.1.1
R35 (release), REVISION: 3.1, GCID: 32827747, BOARD: t186ref, EABI: aarch64, DATE: Sun Mar 19 15:19:21 UTC 2023
Hi @JerryChang
The same board can flash clone Image successfully, but when i changed to another board, it failed to boot.
Hi @JerryChang ,
Now i don’t know how to reflash a cloned image with disk encryption.
Could you please give me some pieces of advice?
Thank you.
Hi @JerryChang ,
I found a post in the forums:
as you can see from the developer guide,
The Jetson Linux reference implementation only generates per-device encrypted disk images.
Does this mean we can not flash an APP_ENC clone image from NX to another NX? Because ECID is unique.
Oh, it’s no good.
How to flash mass production with disk encryption?
it’s only possible for per-device flashing with disk encryption enabled.
Thank you for your reply.
So it can not clone images using -k APP_ENC with disk encryption enabled like -G APP with disk encryption disabled and flash another device.
system
Closed
August 1, 2023, 2:43pm
17
