Description
I have an AI module including 2 docker containers: the first container has 2 CNN models, the second one has 3 CNN models. It works well with native TensorFlow. But when I convert all CNN models to tf-trt format, I only run one of two containers, second containers with message:
I tensorflow/core/common_runtime/gpu/gpu_device.cc:1510] Created device /job:localhost/replica:0/task:0/device:GPU:0 with 6043 MB memory: -> device: 0, name: Tesla T4, pci bus id: 0000:00:1e.0, compute capability: 7.5
I tensorflow/compiler/mlir/mlir_graph_optimization_pass.cc:185] None of the MLIR Optimization Passes are enabled (registered 2)
E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:42] DefaultLogger coreReadArchive.cpp (41) - Serialization Error in verifyHeader: 0 (Version tag does not match. Note: Current Version: 96, Serialized Engine Version: 97)
E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:42] DefaultLogger INVALID_STATE: std::exception
E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:42] DefaultLogger INVALID_CONFIG: Deserialize the cuda engine failed.
Environment
TensorRT Version: nvcr.io/nvidia/tensorrt:20.09
GPU Type: T4
TensorFlow Version: 2.4.2
