Can NVAPI expose Desktop hue setting?
I am trying to automate a changing over-time hue value programatically without having to access Nvidia’s Control Panel. Is that a parameter that is exposed using NVAPI that could be programatically set using modern programming languages?
If NVAPI doesn’t have that functionality, is there another approach that could be suggested that exposes Nvidia Control Panel’s Hue setting for desktop colours?
Dear @eimantasben
Thank you for contacting the NVIDIA developer forum.
Our technical team has received your query and we will get back to you after an initial investigation.
Thanks,
NVAPI Forum Moderator
Dear @eimantasben ,
Currently, there is no support available in NVAPI SDK for setting Hue. We have noted your request and we will let you know if the support for the same is added in NVAPI SDK.
Thank you.
