Can only see SGIE inferences inside the PGIE inferences. Not sure if SGIE is acting on full frame
Jetson Orin
• DeepStream Version
6.1
5
• TensorRT Version
8.1
II) NVIDIA dlloader X Driver 34.1.1 Release Build
I have two detectors, A primary GIE and a Secondary GIE. I can only see the inferences of the secondary model inside the bounding boxes of the primary.
This seems to suggest maybe the Secondary GIE is not running on full frame like I want (I set process-mode = 1 for this reason) but instead is running on downstream inferences.
But I’m not sure
APP
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
# output display details
[tiled-display]
enable=1
rows=1
columns=1
width=1920
height=1080
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
# mp4 video source
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=2
uri=file:///videos-test/swiss_leopards.mp4
num-sources=1
gpu-id=0
cudadec-memtype=0
source-id=0
camera-width=1920
camera-height=1080
# rtsp video source
[source1]
enable=0
type=4
uri=None
cudadec-memtype=0
source-id=0
# rtsp video out
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
##encoder type 0=Hardware 1=Software
enc-type=0
sync=0
bitrate=2700000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
# set below properties in case of RTSPStreaming
rtsp-port=8556
udp-port=5400
#source-id=0
# mp4 out
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
## only SW mpeg4 is supported right now.
codec=1
sync=0
bitrate=2700000
output-file=/videos-output/15092023_091023/swiss_leopards.mp4
source-id=0
# on screen display
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
# stream mux - forms batches of frames from multiple input sources
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
# primary gpu inference engine (model)
[primary-gie]
enable=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;1;1;1
bbox-border-color3=0;1;0;1
nvbuf-memory-type=0
gie-unique-id=1
config-file=/models_configs/pgie_copy.txt
[tracker]
enable=1
# For NvDCF and DeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=320
tracker-height=256
ll-lib-file=/opt/nvidia/deepstream/deepstream-6.1/lib/libnvds_nvmultiobjecttracker.so
# ll-config-file required to set different tracker types
# ll-config-file=/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/config_tracker_IOU.yml
ll-config-file=/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml
# ll-config-file=/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/config_tracker_NvDCF_accuracy.yml
# ll-config-file=/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/config_tracker_DeepSORT.yml
gpu-id=0
enable-batch-process=1
enable-past-frame=1
display-tracking-id=1
# secondary gpu inference engine (model)
[secondary-gie1]
enable=1
gpu-id=0
batch-size=1
## 0=FP32, 1=INT8, 2=FP16 mode
nvbuf-memory-type=0
config-file=/models_configs/sgie_copy.txt
gie-unique-id=2
operate-on-gie-id=1
[tests]
file-loop=0
PGIE
[property]
gpu-id=0
onnx-file=/models/yolov4_military.onnx
model-engine-file=/models/yolov4_military_orin.engine
batch-size=1
gie-unique-id=1
maintain-aspect-ratio=0
symmetric-padding=0
network-mode=2
process-mode=1
network-type=0
interval=4
engine-create-func-name=NvDsInferYoloCudaEngineGet
# from models.json
net-scale-factor=1
labelfile-path=/labels/military.txt
num-detected-classes=2
cluster-mode=3
parse-bbox-func-name=NvDsInferParseCustomBatchedNMSTLT
custom-lib-path=/DeepStream-Yolo/deepstream_tlt_apps/post_processor/libnvds_infercustomparser_tlt.so
model-color-format=1
offsets=103.939;116.779;123.68
[class-attrs-all]
topk=20
nms-iou-threshold=0.5
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
# from models.json
pre-cluster-threshold=0.5
SGIE
[property]
gpu-id=0
onnx-file=/models/yolov8_optical.onnx
model-engine-file=/models/yolov8_optical_orin.engine
batch-size=1
gie-unique-id=2
symmetric-padding=0
network-mode=2
process-mode=1
network-type=0
interval=4
# from models.json
net-scale-factor=0.003921569790691137
labelfile-path=/labels/coco.txt
num-detected-classes=80
cluster-mode=2
parse-bbox-func-name=NvDsInferParseYoloCuda
custom-lib-path=/DeepStream-Yolo/nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
model-color-format=0
input-object-min-width=50
input-object-min-height=50
[class-attrs-all]
topk=20
pre-cluster-threshold=0.25
You can refer to our demo: back-to-back-detectors
The second “nvinfer” or “nvinferserver” instance (Face Detection) can be configured as primary(full-frame) / secondary (operating on primary detected objects). By default it is configured in the secondary mode. To change the second “nvinfer” or “nvinferserver” instance to primary mode, change the macro SECOND_DETECTOR_IS_SECONDARY in the sources to 0.
Is there a way to imitate this using the model_configs Like below or is it only possible with .c files ?
eg.
[property]
gpu-id=0
onnx-file=/models/yolov4.onnx
model-engine-file=/models/yolov4_orin.engine
batch-size=1
gie-unique-id=1
symmetric-padding=0
network-mode=2
process-mode=1
network-type=0
interval=4
# from models.json
net-scale-factor=1
labelfile-path=/labels/cars.txt
cluster-mode=3
offsets=[103.939,116.779,123.68]
[class-attrs-all]
topk=20
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
# from models.json
Now your configuration is correct. This macro controls this variable: process-mode.
  g_object_set (G_OBJECT (secondary_detector), "config-file-path", "secondary_detector_config.txt",
          "unique-id", SECONDARY_DETECTOR_UID, "process-mode", SECOND_DETECTOR_IS_SECONDARY ? 2 : 1, NULL);
In which case the process mode is definitely not working as intended (or more likely I have misunderstood something)
Profile File
[application]
[tiled-display]
enable=1
rows=1
columns=1
width=1024
height=576
gpu-id=0
nvbuf-memory-type=0
# mp4 video source
[source0]
enable=1
type=2
num-sources=1
gpu-id=0
cudadec-memtype=0
source-id=0
camera-width=1024
camera-height=576
# rtsp video source
[source1]
enable=0
type=4
uri=None
cudadec-memtype=0
source-id=0
# rtsp video out
[sink0]
enable=1
type=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=1000000
profile=0
rtsp-port=8556
udp-port=5400
#source-id=0
# mp4 out
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
enc-type=0
codec=1
sync=0
bitrate=1000000
profile=0
output-file=/videos-output/19092023_152222/swiss_leopards.mp4
source-id=0
# on screen display
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
batch-size=1
batched-push-timeout=80000
width=1024
height=576
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
nvbuf-memory-type=0
gie-unique-id=1
config-file=/models_configs/base_detector_primary_copy.txt
[tracker]
enable=1
tracker-width=320
tracker-height=256
gpu-id=0
enable-past-frame=1
[secondary-gie1]
enable=1
gpu-id=0
batch-size=1
nvbuf-memory-type=0
config-file=/models_configs/base_detector_secondary_copy.txt
gie-unique-id=2
[tests]
file-loop=0
[property]
gpu-id=0
batch-size=1
gie-unique-id=1
symmetric-padding=0
network-mode=2
process-mode=1
network-type=0
interval=4
# For VIC Error - debugging
# from models.json
net-scale-factor=1
cluster-mode=3
[class-attrs-all]
topk=20
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
# from models.json
[property]
gpu-id=0
batch-size=1
gie-unique-id=1
symmetric-padding=0
network-mode=2
process-mode=1
network-type=0
interval=4
# from models.json
cluster-mode=2
[class-attrs-all]
topk=20
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
# from models.json
I’ve also added a link to the video so you can see the effect that I am seeing.
Very clearly from 4 - 15 seconds it seems obvious that the secondary SGIE is not acting on the full frame?
Or maybe it is but only inferences that are inside PGIE are being visualised?
Video Example (look 4 - 15 seconds)
No, as long as you have the correct post-processing, it will display. Could you run these two models separately so that we can see the effect of separation?
This is the other way around. As you can see we get no predictions from the custom model, but I’m not suprised if its not getting fullframe
Do you mean this is the result of exchanging sgie and pgie? So your user case is to display the detection results of these two unrelated models? Could you attach the video source?
Yes my user case is to display the outputs of two unrelated models simultaneously
Large column of Swiss military Leopard Tanks on Highway in Switzerland | Pilum 22 - YouTube
We are unable to obtain the source video from the link. If you have the video source, could you message me directly?
You can try this link to a download of it?
Source File
