I have used tensorrt to inference my net,
as:
with open(“my.engine”, “rb”) as f, trt.Runtime(TRT_LOGGER) as runtime:
engine = runtime.deserialize_cuda_engine(f.read())
# Build a TensorRT engine.
#with build_engine_onnx(onnx_model_file) as engine:
# Allocate buffers and create a CUDA stream.
h_input, d_input, h_output, d_output, stream = self.allocate_buffers(engine)
# Contexts are used to perform inference.
with engine.create_execution_context() as context:
# do inference
when I do this in the main thread,it works well.
but when I start a Child thread to do this, it return a error as:
Exception in thread Thread-1:
File “/usr/lib/python3.6/threading.py”, line 916, in _bootstrap_inner
self.run()
File “/usr/lib/python3.6/threading.py”, line 864, in run
self._target(*self._args, **self._kwargs)
File “resnet50_trt.py”, line 149, in prediction
File “resnet50_trt.py”, line 56, in allocate_buffers
h_input = cuda.pagelocked_empty(trt.volume((INPUT_SIZE,3,224,224)), dtype=trt.nptype(ModelData.DTYPE))
pycuda._driver.LogicError: explicit_context_dependent failed: invalid device context - no currently active context?
same of the code:
import pycuda.driver as cuda
# Allocate host and device buffers, and create a stream.
def allocate_buffers(self,engine):
# Determine dimensions and create page-locked memory buffers (i.e. won't be swapped to disk) to hold host inputs/outputs.
h_output = cuda.pagelocked_empty(trt.volume((INPUT_SIZE,8)), dtype=trt.nptype(ModelData.DTYPE))
# Allocate device memory for inputs and outputs.
d_input = cuda.mem_alloc(h_input.nbytes)
d_output = cuda.mem_alloc(h_output.nbytes)
# Create a stream in which to copy inputs/outputs and run inference.
stream = cuda.Stream()
return h_input, d_input, h_output, d_output, stream
the error seem happend at Allocate host and device buffers.
So,Is the tensorRT can’t use in child thread?
