TensorRT inference result of one image don't keep the same in high qps
Description
Hi all,
now I use tensorRT as a server and serval clients send request to do inference. The result is correct when I only use one client, but when I use 3 or more client to do inference, the result of input1 will get random error and return result of input2.
The reason of above is memory copy in host and cuda ,so I add thread lock in inference, result becomes correct but cost more time in model inference
The code with random error
    def infer(self, data):
        Real inference process.
        :param model:   Model objects
        :param data:    Preprocessed data
        :return:
            output
        stream = self.stream
        context = self.context
        engine = self.engine
        host_inputs = self.host_inputs
        cuda_inputs = self.cuda_inputs
        host_outputs = self.host_outputs
        cuda_outputs = self.cuda_outputs
        bindings = self.bindings
        batch_input_image = np.empty(shape=[self.batch_size, 3, 224, 224])
        for i, img in enumerate(data):
            input_ndarray = self.preprocess(img)
            np.copyto(batch_input_image[i], input_ndarray)
        batch_input_image = np.ascontiguousarray(batch_input_image)
        # with lock:
        # Push to device
        self.ctx.push()
        # Copy data to input memory buffer
        np.copyto(host_inputs[0], batch_input_image.ravel())
        # Transfer input data to the GPU.
        # cuda.memcpy_htod_async(self._input.device, self._input.host, self._stream)
        cuda.memcpy_htod_async(cuda_inputs[0], host_inputs[0], stream)
        # Run inference.
        context.execute_async_v2(bindings=bindings, stream_handle=stream.handle)
        # context.execute_async(batch_size=self.batch_size, bindings=bindings, stream_handle=stream.handle)
        # Transfer predictions back from the GPU.
        cuda.memcpy_dtoh_async(host_outputs[0], cuda_outputs[0], stream)
        # Synchronize the stream
        stream.synchronize()
        # Pop the device
        self.ctx.pop()
        output = host_outputs[0].reshape((1,256))
        return output
and code with correct result but run slow
    lock = threading.Lock()
        :return:
            output
        with lock:
            # Push to device
            self.ctx.push()
            # Run inference.
            # Pop the device
            self.ctx.pop()
            return output
Environment
TensorRT Version: 7.0.0.11
GPU Type: P4
Nvidia Driver Version:
CUDA Version: 9.0.176
CUDNN Version: 7.5.1
Operating System + Version:
Python Version (if applicable): 3.5.2
PyTorch Version (if applicable): 1.1.0
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
  • Exact steps/commands to build your repro
  • Exact steps/commands to run your repro
  • Full traceback of errors encountered
Please refer to the following samples and make sure your inference function is correct.
We recommend you please use the latest TensorRT version 8.4 GA.
Also as you deal with multi-threading and multiple clients, we recommend you to please the Triton server for the TensorRT model deployment.
Thank you.
