As the title said, can we convert cv::Mat to NvBuffer? If we can, could you please give me some examples? Thanks a lot!
You may try converting your cv::Mat into a NvBuffer supported fromat mat such as BGRx or RGBA and use Raw2NvBuffer.
I can’t provide an example, but you may have a look to nvvidconv sources for further details.
Thanks for your reply! And I tried with what you mentioned. However, the image became some strips and lines after converting back to cv::mat. Could you please have a look at my code below to see if I did something wrong? Thanks!
cv::Mat bgrImg = cv::imread(imagePath, cv::IMREAD_GRAYSCALE);
cv::Mat continuousRGBA;
cv::cvtColor(bgrImg, continuousRGBA, cv::COLOR_GRAY2RGBA);
unsigned char *data = continuousRGBA.data;
// cv::cvtColor(continuousRGBA, image, cv::COLOR_RGBA2GRAY, 1); // it works normally here
int dmaFd;
if (!createNvBuffer(bgrImg.cols, bgrImg.rows, &dmaFd)) {
throw std::runtime_error("Failed to create resize NvBuffer");
int res = Raw2NvBuffer(data, 0, bgrImg.cols, bgrImg.rows, dmaFd);
if (res == 0) {
std::cout<<"it works well "<<dmaFd<<std::endl;
cv::Mat image = convertNvBufferToCvMat(dmaFd);
Quickly tried the following code, seems working but I didn’t further check byte ordering:
#include <opencv2/opencv.hpp>
#include <nvbuf_utils.h>
int main() {
/* Read image from file */
cv::Mat bgrMat = cv::imread("test.png");
/* Convert it into 32 bits pixels such as BGRA */
cv::Mat bgraMat;
cv::cvtColor(bgrMat, bgraMat, cv::COLOR_BGR2BGRA);
/* Display input and wait for key press */
cv::imshow("Input to BGRA", bgraMat);
cv::waitKey(-1);
/* Create a NvBuffer for same size with format ARGB32 */
int dmaFd;
NvBufferCreateParams params = {
.width = bgraMat.cols,
.height = bgraMat.rows,
.payloadType = NvBufferPayload_SurfArray,
.memsize = (4 * bgraMat.cols * bgraMat.rows),
.colorFormat = NvBufferColorFormat_ARGB32,
.nvbuf_tag = NvBufferTag_NONE
if (NvBufferCreateEx(&dmaFd, ¶ms)) {
std::cerr << "Create buffer failed\n";
return(-1);
/* Copy cpu buffer into NVMM */
if (Raw2NvBuffer(bgraMat.data, 0, bgraMat.cols, bgraMat.rows, dmaFd)) {
std::cerr << "Raw2NvBuffer failed\n";
return(-2);
/* Do some NvBuffer processing here.. */
/* Copy NvBuffer back into system memory */
cv::Mat bgraMat2(bgraMat.rows, bgraMat.cols, CV_8UC4);
if (NvBuffer2Raw(dmaFd, 0, bgraMat2.cols, bgraMat2.rows, bgraMat2.data)) {
std::cerr << "NvBuffer2Raw failed\n";
return(-3);
NvBufferDestroy(dmaFd);
cv::imshow("BGRA read back", bgraMat2);
cv::waitKey(-1);
return 0;
You may try this as a starting point and report further issues.
Thanks a bunch! It works! Seems like I used wrong NvBufferColorFormat.
