Hello guys,
I tried to build a TensorRT engine for DLA from the following ONNX model with trtexec but it failed. Is there a solution?
Model:
https://digital-standard.com/threedpose/models/Resnet34_3inputs_448x448_20200609.onnx
Machine:
Jetson Xavier NX DevKit with JetPack 4.4
Command:
/usr/src/tensorrt/bin/trtexec --onnx=Resnet34_3inputs_448x448_20200609.onnx --explicitBatch --batch=1 --workspace=4096 --saveEngine=test.engine --fp16 --useDLACore=0 --allowGPUFallback
Error:
&&&& RUNNING TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=Resnet34_3inputs_448x448_20200609.onnx --explicitBatch --batch=1 --workspace=4096 --saveEngine=test.engine --fp16 --useDLACore=0 --allowGPUFallback
[07/31/2020-12:31:08] [I] === Model Options ===
[07/31/2020-12:31:08] [I] Format: ONNX
[07/31/2020-12:31:08] [I] Model: Resnet34_3inputs_448x448_20200609.onnx
[07/31/2020-12:31:08] [I] Output:
[07/31/2020-12:31:08] [I] === Build Options ===
[07/31/2020-12:31:08] [I] Max batch: explicit
[07/31/2020-12:31:08] [I] Workspace: 4096 MB
[07/31/2020-12:31:08] [I] minTiming: 1
[07/31/2020-12:31:08] [I] avgTiming: 8
[07/31/2020-12:31:08] [I] Precision: FP32+FP16
[07/31/2020-12:31:08] [I] Calibration:
[07/31/2020-12:31:08] [I] Safe mode: Disabled
[07/31/2020-12:31:08] [I] Save engine: test.engine
[07/31/2020-12:31:08] [I] Load engine:
[07/31/2020-12:31:08] [I] Builder Cache: Enabled
[07/31/2020-12:31:08] [I] NVTX verbosity: 0
[07/31/2020-12:31:08] [I] Inputs format: fp32:CHW
[07/31/2020-12:31:08] [I] Outputs format: fp32:CHW
[07/31/2020-12:31:08] [I] Input build shapes: model
[07/31/2020-12:31:08] [I] Input calibration shapes: model
[07/31/2020-12:31:08] [I] === System Options ===
[07/31/2020-12:31:08] [I] Device: 0
[07/31/2020-12:31:08] [I] DLACore: 0(With GPU fallback)
[07/31/2020-12:31:08] [I] Plugins:
[07/31/2020-12:31:08] [I] === Inference Options ===
[07/31/2020-12:31:08] [I] Batch: Explicit
[07/31/2020-12:31:08] [I] Input inference shapes: model
[07/31/2020-12:31:08] [I] Iterations: 10
[07/31/2020-12:31:08] [I] Duration: 3s (+ 200ms warm up)
[07/31/2020-12:31:08] [I] Sleep time: 0ms
[07/31/2020-12:31:08] [I] Streams: 1
[07/31/2020-12:31:08] [I] ExposeDMA: Disabled
[07/31/2020-12:31:08] [I] Spin-wait: Disabled
[07/31/2020-12:31:08] [I] Multithreading: Disabled
[07/31/2020-12:31:08] [I] CUDA Graph: Disabled
[07/31/2020-12:31:08] [I] Skip inference: Disabled
[07/31/2020-12:31:08] [I] Inputs:
[07/31/2020-12:31:08] [I] === Reporting Options ===
[07/31/2020-12:31:08] [I] Verbose: Disabled
[07/31/2020-12:31:08] [I] Averages: 10 inferences
[07/31/2020-12:31:08] [I] Percentile: 99
[07/31/2020-12:31:08] [I] Dump output: Disabled
[07/31/2020-12:31:08] [I] Profile: Disabled
[07/31/2020-12:31:08] [I] Export timing to JSON file:
[07/31/2020-12:31:08] [I] Export output to JSON file:
[07/31/2020-12:31:08] [I] Export profile to JSON file:
Input filename: Resnet34_3inputs_448x448_20200609.onnx
ONNX IR version: 0.0.4
Opset version: 9
Producer name: pytorch
Producer version: 1.3
Domain:
Model version: 0
Doc string:
[07/31/2020-12:31:11] [W] [TRT] onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[07/31/2020-12:31:13] [W] [TRT] Internal DLA error for layer (Unnamed Layer* 154) [Convolution]. Switching to GPU fallback.
[07/31/2020-12:31:13] [W] [TRT] Internal DLA error for layer (Unnamed Layer* 160) [Convolution]. Switching to GPU fallback.
[07/31/2020-12:31:13] [W] [TRT] Internal DLA error for layer (Unnamed Layer* 165) [Convolution]. Switching to GPU fallback.
[07/31/2020-12:31:13] [W] [TRT] Internal DLA error for layer (Unnamed Layer* 171) [Convolution]. Switching to GPU fallback.
[07/31/2020-12:31:13] [W] [TRT] Internal DLA error for layer (Unnamed Layer* 177) [Convolution]. Switching to GPU fallback.
[07/31/2020-12:31:13] [W] [TRT] Internal DLA error for layer (Unnamed Layer* 186) [Convolution]. Switching to GPU fallback.
[07/31/2020-12:31:14] [W] [TRT] Internal DLA error for layer (Unnamed Layer* 186) [Convolution]. Switching to GPU fallback.
[07/31/2020-12:31:14] [I] [TRT]
[07/31/2020-12:31:14] [I] [TRT] --------------- Layers running on DLA:
[07/31/2020-12:31:14] [I] [TRT] {(Unnamed Layer* 0) [Convolution],(Unnamed Layer* 1) [Scale],(Unnamed Layer* 2) [Activation],(Unnamed Layer* 3) [Pooling],(Unnamed Layer* 4) [Convolution],(Unnamed Layer* 5) [Scale],(Unnamed Layer* 6) [Activation],(Unnamed Layer* 7) [Pooling],(Unnamed Layer* 8) [Convolution],(Unnamed Layer* 9) [Scale],(Unnamed Layer* 10) [Activation],(Unnamed Layer* 11) [Pooling],(Unnamed Layer* 12) [ElementWise],(Unnamed Layer* 13) [Concatenation],(Unnamed Layer* 14) [Convolution],(Unnamed Layer* 15) [Scale],(Unnamed Layer* 16) [Activation],(Unnamed Layer* 17) [Convolution],(Unnamed Layer* 18) [Scale],(Unnamed Layer* 19) [Activation],(Unnamed Layer* 20) [Convolution],(Unnamed Layer* 21) [Scale],(Unnamed Layer* 22) [Activation],(Unnamed Layer* 23) [Convolution],(Unnamed Layer* 24) [Scale],(Unnamed Layer* 25) [ElementWise],(Unnamed Layer* 26) [Activation],(Unnamed Layer* 27) [Convolution],(Unnamed Layer* 28) [Scale],(Unnamed Layer* 29) [Activation],(Unnamed Layer* 30) [Convolution],(Unnamed Layer* 31) [Scale],(Unnamed Layer* 32) [ElementWise],(Unnamed Layer* 33) [Activation],(Unnamed Layer* 34) [Convolution],(Unnamed Layer* 35) [Scale],(Unnamed Layer* 36) [Activation],(Unnamed Layer* 37) [Convolution],(Unnamed Layer* 38) [Scale],(Unnamed Layer* 39) [ElementWise],(Unnamed Layer* 40) [Activation],(Unnamed Layer* 41) [ElementWise],(Unnamed Layer* 42) [Convolution],(Unnamed Layer* 43) [Scale],(Unnamed Layer* 44) [Activation],(Unnamed Layer* 45) [Convolution],(Unnamed Layer* 46) [Scale],(Unnamed Layer* 47) [Convolution],(Unnamed Layer* 48) [Scale],(Unnamed Layer* 49) [ElementWise],(Unnamed Layer* 50) [Activation],(Unnamed Layer* 51) [Convolution],(Unnamed Layer* 52) [Scale],(Unnamed Layer* 53) [Activation],(Unnamed Layer* 54) [Convolution],(Unnamed Layer* 55) [Scale],(Unnamed Layer* 56) [ElementWise],(Unnamed Layer* 57) [Activation],(Unnamed Layer* 58) [Convolution],(Unnamed Layer* 59) [Scale],(Unnamed Layer* 60) [Activation],(Unnamed Layer* 61) [Convolution],(Unnamed Layer* 62) [Scale],(Unnamed Layer* 63) [ElementWise],(Unnamed Layer* 64) [Activation],(Unnamed Layer* 65) [Convolution],(Unnamed Layer* 66) [Scale],(Unnamed Layer* 67) [Activation],(Unnamed Layer* 68) [Convolution],(Unnamed Layer* 69) [Scale],(Unnamed Layer* 70) [ElementWise],(Unnamed Layer* 71) [Activation],(Unnamed Layer* 72) [Convolution],(Unnamed Layer* 73) [Scale],(Unnamed Layer* 74) [Activation],(Unnamed Layer* 75) [Convolution],(Unnamed Layer* 76) [Scale],(Unnamed Layer* 77) [Convolution],(Unnamed Layer* 78) [Scale],(Unnamed Layer* 79) [ElementWise],(Unnamed Layer* 80) [Activation],(Unnamed Layer* 81) [Convolution],(Unnamed Layer* 82) [Scale],(Unnamed Layer* 83) [Activation],(Unnamed Layer* 84) [Convolution],(Unnamed Layer* 85) [Scale],(Unnamed Layer* 86) [ElementWise],(Unnamed Layer* 87) [Activation],(Unnamed Layer* 88) [Convolution],(Unnamed Layer* 89) [Scale],(Unnamed Layer* 90) [Activation],(Unnamed Layer* 91) [Convolution],(Unnamed Layer* 92) [Scale],(Unnamed Layer* 93) [ElementWise],(Unnamed Layer* 94) [Activation],(Unnamed Layer* 95) [Convolution],(Unnamed Layer* 96) [Scale],(Unnamed Layer* 97) [Activation],(Unnamed Layer* 98) [Convolution],(Unnamed Layer* 99) [Scale],(Unnamed Layer* 100) [ElementWise],(Unnamed Layer* 101) [Activation],(Unnamed Layer* 102) [Convolution],(Unnamed Layer* 103) [Scale],(Unnamed Layer* 104) [Activation],(Unnamed Layer* 105) [Convolution],(Unnamed Layer* 106) [Scale],(Unnamed Layer* 107) [ElementWise],(Unnamed Layer* 108) [Activation],(Unnamed Layer* 109) [Convolution],(Unnamed Layer* 110) [Scale],(Unnamed Layer* 111) [Activation],(Unnamed Layer* 112) [Convolution],(Unnamed Layer* 113) [Scale],(Unnamed Layer* 114) [ElementWise],(Unnamed Layer* 115) [Activation],(Unnamed Layer* 116) [Convolution],(Unnamed Layer* 117) [Scale],(Unnamed Layer* 118) [Activation],(Unnamed Layer* 119) [Convolution],(Unnamed Layer* 120) [Scale],(Unnamed Layer* 121) [Convolution],(Unnamed Layer* 122) [Scale],(Unnamed Layer* 123) [ElementWise],(Unnamed Layer* 124) [Activation],(Unnamed Layer* 125) [Convolution],(Unnamed Layer* 126) [Scale],(Unnamed Layer* 127) [Activation],(Unnamed Layer* 128) [Convolution],(Unnamed Layer* 129) [Scale],(Unnamed Layer* 130) [ElementWise],(Unnamed Layer* 131) [Activation],(Unnamed Layer* 132) [Convolution],(Unnamed Layer* 133) [Scale],(Unnamed Layer* 134) [Activation],(Unnamed Layer* 135) [Convolution],(Unnamed Layer* 136) [Scale],(Unnamed Layer* 137) [ElementWise],(Unnamed Layer* 138) [Activation],(Unnamed Layer* 139) [Convolution],(Unnamed Layer* 140) [Scale],(Unnamed Layer* 141) [Activation],(Unnamed Layer* 142) [Convolution],(Unnamed Layer* 143) [Scale],(Unnamed Layer* 144) [Activation],(Unnamed Layer* 145) [Deconvolution],(Unnamed Layer* 146) [Scale],(Unnamed Layer* 147) [Activation],(Unnamed Layer* 148) [Convolution],(Unnamed Layer* 149) [Scale],(Unnamed Layer* 150) [Activation],(Unnamed Layer* 151) [Convolution],(Unnamed Layer* 152) [Scale],(Unnamed Layer* 153) [Activation]}, {(Unnamed Layer* 155) [Scale],(Unnamed Layer* 156) [Activation],(Unnamed Layer* 157) [Convolution],(Unnamed Layer* 158) [Scale],(Unnamed Layer* 159) [Activation]}, {(Unnamed Layer* 161) [Scale],(Unnamed Layer* 162) [Activation],(Unnamed Layer* 163) [Convolution],(Unnamed Layer* 164) [Activation]}, {(Unnamed Layer* 166) [Scale],(Unnamed Layer* 167) [Activation],(Unnamed Layer* 168) [Convolution],(Unnamed Layer* 169) [Scale],(Unnamed Layer* 170) [Activation]}, {(Unnamed Layer* 172) [Scale],(Unnamed Layer* 173) [Activation],(Unnamed Layer* 174) [Convolution],(Unnamed Layer* 175) [Scale],(Unnamed Layer* 176) [Activation]}, {(Unnamed Layer* 178) [Scale],(Unnamed Layer* 179) [Activation],(Unnamed Layer* 180) [Convolution],(Unnamed Layer* 181) [Scale],(Unnamed Layer* 182) [Activation],(Unnamed Layer* 183) [Scale],(Unnamed Layer* 184) [Activation],(Unnamed Layer* 185) [Concatenation]}, {(Unnamed Layer* 187) [Scale],(Unnamed Layer* 188) [Activation],(Unnamed Layer* 189) [Convolution],(Unnamed Layer* 190) [Activation]},
[07/31/2020-12:31:14] [I] [TRT] --------------- Layers running on GPU:
[07/31/2020-12:31:14] [I] [TRT] (Unnamed Layer* 154) [Convolution], (Unnamed Layer* 160) [Convolution], (Unnamed Layer* 165) [Convolution], (Unnamed Layer* 171) [Convolution], (Unnamed Layer* 177) [Convolution], (Unnamed Layer* 186) [Convolution],
[07/31/2020-12:31:18] [W] [TRT] DLA Node compilation Failed.
[07/31/2020-12:31:18] [E] [TRT] Try increasing the workspace size with IBuilderConfig::setMaxWorkspaceSize() if using IBuilder::buildEngineWithConfig, or IBuilder::setMaxWorkspaceSize() if using IBuilder::buildCudaEngine.
[07/31/2020-12:31:18] [E] [TRT] ../builder/tacticOptimizer.cpp (1715) - TRTInternal Error in computeCosts: 0 (Could not find any implementation for node {(Unnamed Layer* 0) [Convolution],(Unnamed Layer* 1) [Scale],(Unnamed Layer* 2) [Activation],(Unnamed Layer* 3) [Pooling],(Unnamed Layer* 4) [Convolution],(Unnamed Layer* 5) [Scale],(Unnamed Layer* 6) [Activation],(Unnamed Layer* 7) [Pooling],(Unnamed Layer* 8) [Convolution],(Unnamed Layer* 9) [Scale],(Unnamed Layer* 10) [Activation],(Unnamed Layer* 11) [Pooling],(Unnamed Layer* 12) [ElementWise],(Unnamed Layer* 13) [Concatenation],(Unnamed Layer* 14) [Convolution],(Unnamed Layer* 15) [Scale],(Unnamed Layer* 16) [Activation],(Unnamed Layer* 17) [Convolution],(Unnamed Layer* 18) [Scale],(Unnamed Layer* 19) [Activation],(Unnamed Layer* 20) [Convolution],(Unnamed Layer* 21) [Scale],(Unnamed Layer* 22) [Activation],(Unnamed Layer* 23) [Convolution],(Unnamed Layer* 24) [Scale],(Unnamed Layer* 25) [ElementWise],(Unnamed Layer* 26) [Activation],(Unnamed Layer* 27) [Convolution],(Unnamed Layer* 28) [Scale],(Unnamed Layer* 29) [Activation],(Unnamed Layer* 30) [Convolution],(Unnamed Layer* 31) [Scale],(Unnamed Layer* 32) [ElementWise],(Unnamed Layer* 33) [Activation],(Unnamed Layer* 34) [Convolution],(Unnamed Layer* 35) [Scale],(Unnamed Layer* 36) [Activation],(Unnamed Layer* 37) [Convolution],(Unnamed Layer* 38) [Scale],(Unnamed Layer* 39) [ElementWise],(Unnamed Layer* 40) [Activation],(Unnamed Layer* 41) [ElementWise],(Unnamed Layer* 42) [Convolution],(Unnamed Layer* 43) [Scale],(Unnamed Layer* 44) [Activation],(Unnamed Layer* 45) [Convolution],(Unnamed Layer* 46) [Scale],(Unnamed Layer* 47) [Convolution],(Unnamed Layer* 48) [Scale],(Unnamed Layer* 49) [ElementWise],(Unnamed Layer* 50) [Activation],(Unnamed Layer* 51) [Convolution],(Unnamed Layer* 52) [Scale],(Unnamed Layer* 53) [Activation],(Unnamed Layer* 54) [Convolution],(Unnamed Layer* 55) [Scale],(Unnamed Layer* 56) [ElementWise],(Unnamed Layer* 57) [Activation],(Unnamed Layer* 58) [Convolution],(Unnamed Layer* 59) [Scale],(Unnamed Layer* 60) [Activation],(Unnamed Layer* 61) [Convolution],(Unnamed Layer* 62) [Scale],(Unnamed Layer* 63) [ElementWise],(Unnamed Layer* 64) [Activation],(Unnamed Layer* 65) [Convolution],(Unnamed Layer* 66) [Scale],(Unnamed Layer* 67) [Activation],(Unnamed Layer* 68) [Convolution],(Unnamed Layer* 69) [Scale],(Unnamed Layer* 70) [ElementWise],(Unnamed Layer* 71) [Activation],(Unnamed Layer* 72) [Convolution],(Unnamed Layer* 73) [Scale],(Unnamed Layer* 74) [Activation],(Unnamed Layer* 75) [Convolution],(Unnamed Layer* 76) [Scale],(Unnamed Layer* 77) [Convolution],(Unnamed Layer* 78) [Scale],(Unnamed Layer* 79) [ElementWise],(Unnamed Layer* 80) [Activation],(Unnamed Layer* 81) [Convolution],(Unnamed Layer* 82) [Scale],(Unnamed Layer* 83) [Activation],(Unnamed Layer* 84) [Convolution],(Unnamed Layer* 85) [Scale],(Unnamed Layer* 86) [ElementWise],(Unnamed Layer* 87) [Activation],(Unnamed Layer* 88) [Convolution],(Unnamed Layer* 89) [Scale],(Unnamed Layer* 90) [Activation],(Unnamed Layer* 91) [Convolution],(Unnamed Layer* 92) [Scale],(Unnamed Layer* 93) [ElementWise],(Unnamed Layer* 94) [Activation],(Unnamed Layer* 95) [Convolution],(Unnamed Layer* 96) [Scale],(Unnamed Layer* 97) [Activation],(Unnamed Layer* 98) [Convolution],(Unnamed Layer* 99) [Scale],(Unnamed Layer* 100) [ElementWise],(Unnamed Layer* 101) [Activation],(Unnamed Layer* 102) [Convolution],(Unnamed Layer* 103) [Scale],(Unnamed Layer* 104) [Activation],(Unnamed Layer* 105) [Convolution],(Unnamed Layer* 106) [Scale],(Unnamed Layer* 107) [ElementWise],(Unnamed Layer* 108) [Activation],(Unnamed Layer* 109) [Convolution],(Unnamed Layer* 110) [Scale],(Unnamed Layer* 111) [Activation],(Unnamed Layer* 112) [Convolution],(Unnamed Layer* 113) [Scale],(Unnamed Layer* 114) [ElementWise],(Unnamed Layer* 115) [Activation],(Unnamed Layer* 116) [Convolution],(Unnamed Layer* 117) [Scale],(Unnamed Layer* 118) [Activation],(Unnamed Layer* 119) [Convolution],(Unnamed Layer* 120) [Scale],(Unnamed Layer* 121) [Convolution],(Unnamed Layer* 122) [Scale],(Unnamed Layer* 123) [ElementWise],(Unnamed Layer* 124) [Activation],(Unnamed Layer* 125) [Convolution],(Unnamed Layer* 126) [Scale],(Unnamed Layer* 127) [Activation],(Unnamed Layer* 128) [Convolution],(Unnamed Layer* 129) [Scale],(Unnamed Layer* 130) [ElementWise],(Unnamed Layer* 131) [Activation],(Unnamed Layer* 132) [Convolution],(Unnamed Layer* 133) [Scale],(Unnamed Layer* 134) [Activation],(Unnamed Layer* 135) [Convolution],(Unnamed Layer* 136) [Scale],(Unnamed Layer* 137) [ElementWise],(Unnamed Layer* 138) [Activation],(Unnamed Layer* 139) [Convolution],(Unnamed Layer* 140) [Scale],(Unnamed Layer* 141) [Activation],(Unnamed Layer* 142) [Convolution],(Unnamed Layer* 143) [Scale],(Unnamed Layer* 144) [Activation],(Unnamed Layer* 145) [Deconvolution],(Unnamed Layer* 146) [Scale],(Unnamed Layer* 147) [Activation],(Unnamed Layer* 148) [Convolution],(Unnamed Layer* 149) [Scale],(Unnamed Layer* 150) [Activation],(Unnamed Layer* 151) [Convolution],(Unnamed Layer* 152) [Scale],(Unnamed Layer* 153) [Activation]}.)
[07/31/2020-12:31:19] [E] [TRT] ../builder/tacticOptimizer.cpp (1715) - TRTInternal Error in computeCosts: 0 ()
[07/31/2020-12:31:19] [E] Engine creation failed
[07/31/2020-12:31:19] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=Resnet34_3inputs_448x448_20200609.onnx --explicitBatch --batch=1 --workspace=4096 --saveEngine=test.engine --fp16 --useDLACore=0 --allowGPUFallback
