Hello!
I have MSI GS75 laptop with GTX 1660TI and i7-9750H CPU.
I used optimus-manager to manage in which mode the laptop loaded and be able to switch from power-saving (intel only) mode to performance (Nvidia). For power management I used bbswitch and it is worked.
Now I want to configure power management for dGPU using this instruction: Chapter 22. PCI-Express Runtime D3 (RTD3) Power Management
But it seems to mee that dGPU doesn’t switch off while I don’t use it: there are a special led indicator in the laptop and it shows that dGPU powered on.
Also please note that I deleted bbswitch before configuring native power management
$ cat /lib/udev/rules.d/80-nvidia-pm.rules
# Remove NVIDIA USB xHCI Host Controller devices, if present
ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c0330", ATTR{remove}="1"
# Remove NVIDIA USB Type-C UCSI devices, if present
ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c8000", ATTR{remove}="1"
# Remove NVIDIA Audio devices, if present
ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x040300", ATTR{remove}="1"
# Enable runtime PM for NVIDIA VGA/3D controller devices on driver bind
ACTION=="bind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030000", TEST=="power/control", ATTR{power/control}="auto"
ACTION=="bind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030200", TEST=="power/control", ATTR{power/control}="auto"
# Disable runtime PM for NVIDIA VGA/3D controller devices on driver unbind
ACTION=="unbind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030000", TEST=="power/control", ATTR{power/control}="on"
ACTION=="unbind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030200", TEST=="power/control", ATTR{power/control}="on"
$ cat /etc/modprobe.d/nvidia.conf
options nvidia "NVreg_DynamicPowerManagement=0x02"
$ uname -a
Linux anton-arch 5.6.4-arch1-1 #1 SMP PREEMPT Mon, 13 Apr 2020 12:21:19 +0000 x86_64 GNU/Linux
How could I employ native power management ?
Please let me know if you need more information.
nvidia-bug-report.log (3.5 MB)
