Cannot install driver when installed NVIDIA A10
I cannot install driver when installed A10. Encounter:
ERROR: Unable to load the kernel module ‘nvidia.ko’. This happens most frequently when this kernel module was built against the wrong or improperly configured kernel sources, with a version of gcc that differs from the one used to
build the target kernel, or if another driver, such as nouveau, is present and prevents the NVIDIA kernel module from obtaining ownership of the NVIDIA GPU(s), or no NVIDIA GPU installed in this system is supported by this
NVIDIA Linux graphics driver release.
     Please see the log entries 'Kernel module load error' and 'Kernel messages' at the end of the file '/var/log/nvidia-installer.log' for more information.
This is /var/log/nvidia-installer.log’s tail:
→ done.
→ Kernel module compilation complete.
ERROR: Unable to load the kernel module ‘nvidia.ko’. This happens most frequently when this kernel module was built against the wrong or improperly configured kernel sources, with a version of gcc that differs from the one used to build the target kernel, or if another driver, such as nouveau, is present and prevents the NVIDIA kernel module from obtaining ownership of the NVIDIA GPU(s), or no NVIDIA GPU installed in this system is supported by this NVIDIA Linux graphics driver release.
Please see the log entries ‘Kernel module load error’ and ‘Kernel messages’ at the end of the file ‘/var/log/nvidia-installer.log’ for more information.
→ Kernel module load error: No such device
→ Kernel messages:
[ 7665.082636] nvidia-nvlink: Unregistered the Nvlink Core, major device number 238
[10820.408086] IPMI message handler: version 39.2
[10820.409217] ipmi device interface
[10820.565097] nvidia-nvlink: Nvlink Core is being initialized, major device number 238
[10820.565339] NVRM: request_mem_region failed for 0M @ 0x0. This can
NVRM: occur when a driver such as rivatv is loaded and claims
NVRM: ownership of the device’s registers.
[10820.565343] nvidia: probe of 0000:02:00.0 failed with error -1
[10820.565350] NVRM: The NVIDIA probe routine failed for 1 device(s).
[10820.565351] NVRM: None of the NVIDIA devices were initialized.
[10820.565476] nvidia-nvlink: Unregistered the Nvlink Core, major device number 238
[12068.778334] igb 0000:06:00.0 enp6s0: igb: enp6s0 NIC Link is Down
[12073.465768] igb 0000:06:00.0 enp6s0: igb: enp6s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[12082.496313] igb 0000:06:00.0 enp6s0: igb: enp6s0 NIC Link is Down
[12099.757666] igb 0000:06:00.0 enp6s0: igb: enp6s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[12659.308008] IPMI message handler: version 39.2
[12659.308996] ipmi device interface
[12659.461775] nvidia-nvlink: Nvlink Core is being initialized, major device number 238
[12659.462062] NVRM: request_mem_region failed for 0M @ 0x0. This can
[12659.462068] nvidia: probe of 0000:02:00.0 failed with error -1
[12659.462079] NVRM: The NVIDIA probe routine failed for 1 device(s).
[12659.462080] NVRM: None of the NVIDIA devices were initialized.
[12659.462174] nvidia-nvlink: Unregistered the Nvlink Core, major device number 238
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
But I can installed driver when I replace the card with Tesla T4, with the same computer and the same driver file:
NVIDIA-Linux-x86_64-460.73.01.run. On this driver’s download page, it says this driver can support NVIDIA A10 .
My environment is CentOS 7.
