Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libpython3.6-dev : Depends: libpython3.6-stdlib (= 3.6.5-3) but 3.6.9-1~18.04ubuntu1.4 is to be installed
Depends: libpython3.6 (= 3.6.5-3) but 3.6.9-1~18.04ubuntu1.4 is to be installed
E: Unable to correct problems, you have held broken packages.
Hi @vision-hobbist1995, I’m unsure what would cause this error, whether it be some Ubuntu apt upgrade, PPA repo that you have installed, or otherwise. Is this on a typical JetPack install with Ubuntu 18.04? Under normal circumstances, you should be able to just run sudo apt-get install python3-dev
Alternatively, if your system configuration is messed up, you can also backup your files and re-flash your SD card to get it back into a known working state.
Hi dusty,
sorry for late reply.
I have re-flashed sd card with newest image for jetson nano 2GB version. Problem still occur.
Here is output when I install python3-dev
python3-dev : Depends: python3 (= 3.6.5-3) but 3.6.7-1~18.04 is to be installed
Depends: libpython3-dev (= 3.6.5-3) but it is not going to be installed
Depends: python3.6-dev (>= 3.6.5-2~) but it is not going to be installed
