Cannot open Gstreamer Pipeline with OpenCV on Jetson Nano
I’m trying to use tracker algorithms of OpenCV which is coming from UDP port. Following pipeline is working good on two different PC and Raspberry Pi 4 but I can’t open it on Jetson Nano.
VideoCapture video("udpsrc port=5600 ! application/x-rtp,payload=96,encoding-name=H264 ! rtpjitterbuffer mode=1 ! rtph264depay ! h264parse ! decodebin ! videoconvert ! appsink emit-signals=true sync=false max-buffers=1 drop=true", CAP_GSTREAMER);
I’m getting following output when I execute the code.
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
FYI, I connected Jetson Nano to directly Monitor via HDMI output.
Please try gst-launch-1.0 command:
$ gst-launch-1.0 udpsrc port=5600 ! application/x-rtp,payload=96,encoding-name=H264 ! rtpjitterbuffer mode=1 ! rtph264depay ! h264parse ! decodebin ! videoconvert ! video/x-raw,format=BGR ! fakesink
If the gst-launch command works, it should also work fine in OpenCV code.
Thanks for answer,
Unfortunately it doesn’t work. The command that you advised gives this output continuously:
Additional debug info:
gstbasetransform.c(1415): gst_base_transform_reconfigure (): /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter2:
not negotiated
WARNING: from element /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter2: not negotiated
Also, I found command which is running without problem. I got advice by https://github.com/patrickelectric
udpsrc port=5600 ! application/x-rtp,payload=96,encoding-name=H264 ! rtpjitterbuffer mode=1 ! rtph264depay ! h264parse ! decodebin ! videoconvert ! autovideosink emit-signals=true sync=false max-buffers=1 drop=true
https://user-images.githubusercontent.com/44507545/74029500-db976480-49bd-11ea-8ee6-766f1303127c.jpg
But also there is problem with this command, because it is just opening without border and windows. I am not able click anything. When I run command. I just switched with Alt+Tab shortcut and closed command from terminal without seeing it. You can see on the screenshot.
Also yeah gstreamer work with command but it’s strange. I don’t get why Jetson Nano switch blocking mode when it starts. I think it’s related to strange start.
Please check if software decoder works:
udpsrc port=5600 ! application/x-rtp,payload=96,encoding-name=H264 ! rtpjitterbuffer mode=1 ! rtph264depay ! h264parse ! avdec_h264 ! xvimagesink sync=false
If software decoder works, please then try hardware decoder:
udpsrc port=5600 ! application/x-rtp,payload=96,encoding-name=H264 ! rtpjitterbuffer mode=1 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvoverlaysink sync=false
I’m able to run gstreamer with software decoder:
gst-launch-1.0 udpsrc port=5600 ! application/x-rtp,payload=96,encoding-name=H264 ! rtpjitterbuffer mode=1 ! rtph264depay ! h264parse ! avdec_h264 ! xvimagesink sync=false
Also second gstreamer with hardware decoder works well with some warnings:
gst-launch-1.0 udpsrc port=5600 ! application/x-rtp,payload=96,encoding-name=H264 ! rtpjitterbuffer mode=1 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvoverlaysink sync=false
Output:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Both command works without any problem. But gstreamer in opencv needs “appsink” so I changed code to:
VideoCapture video("udpsrc port=5600 ! application/x-rtp, payload=96, encoding-name=H264 ! rtpjitterbuffer mode=1 ! rtph264depay ! h264parse ! avdec_h264 ! decodebin ! videoconvert ! appsink max-buffers=2 drop=true emit-signals=true sync=false", CAP_GSTREAMER);
I think problem was related to decoder option. “avdec_h264” option works while nvv4l2decoder doesn’t work.
But there is a problem with this pipeline, it makes too lag. Udp video has very latency while other functions of opencv works without delay. Delay is increasing time by time. I think problem is between “sink” and “decoder”. At least now I can receive video. I’m working to resolve this problem.
Thanks for helping @DaneLLL :)
After resolve this problem I’ll share guide about integration gazebo sim and jetson nano on github.
EDIT: Ubuntu-Desktop PC runs without latency or problem with this pipeline :/ How can I accelerate video decoding on Jetson Nano?
You may try something like:
VideoCapture video("udpsrc port=5600 ! application/x-rtp, payload=96, encoding-name=H264 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! video/x-raw, format=BGRx ! videoconvert ! video/x-raw, format=BGR ! appsink", CAP_GSTREAMER);
If not working you may also try adding queue between udpsrc and rtph264depay.
