Stream MKV file using H264 compression and RTP
Using gstreamer on Nvidia Jetson Nano, I want to read from MKV file and encode it as H264 to stream via RTP. I successfully did it with MP4 file this way:
gst-launch-1.0 filesrc location=$file ! decodebin ! videoconvert ! omxh264enc ! video/x-h264, width=1280, height=720, format=I420, stream-format=byte-stream ! rtph264pay ! udpsink host=127.0.0.1 port=5000
But when I wanted to parse MKV, I received errors, so I tried this:
gst-launch-1.0 filesrc location=$file ! matroskademux ! videoconvert ! omxh264enc ! video/x-h264, width=1280, height=720, format=I420, stream-format=byte-stream ! rtph264pay ! udpsink host=127.0.0.1 port=5000
Then I received an error:
./grammar.y(510): gst_parse_no_more_pads ():
/GstPipeline:pipeline0/GstMatroskaDemux:matroskademux0:
failed delayed linking some pad of GstMatroskaDemux named matroskademux0 to some pad of GstVideoConvert named videoconvert0
ERROR: from element /GstPipeline:pipeline0/GstMatroskaDemux:matroskademux0: Internal data stream error.
Additional debug info:
matroska-demux.c(5213): get_matroska_demux_loop (): /GstPipeline:pipeline0/GstMatroskaDemux:matroskademux0:
streaming stopped, reason not-linked (-1)
I then tried removing the videoconvert pipe and go straight to encoding H264, but it didn’t work also.
What is the correct approach pipelining it?
Please refer to this pipeline:
$ gst-launch-1.0 filesrc location=test.mkv ! matroskademux ! h264parse config-interval=1 ! rtph264pay ! udpsink host=127.0.0.1 port=5000
Thank you.
Unfortunately that didn’t help, I still get an error:
nvidia@nvidia-desktop:~$ gst-launch-1.0 filesrc location="/home/nvidia/Videos/10 Incredible 4K (Ultra HD) Videos.mkv" ! matroskademux ! h264parse config-interval=1 ! rtph264pay ! udpsink host=127.0.0.1 port=5000
Setting pipeline to PAUSED …
Pipeline is PREROLLING …
WARNING: from element /GstPipeline:pipeline0/GstMatroskaDemux:matroskademux0: Delayed linking failed.
./grammar.y(510): gst_parse_no_more_pads (): /GstPipeline:pipeline0/GstMatroskaDemux:matroskademux0:
failed delayed linking some pad of GstMatroskaDemux named matroskademux0 to some pad of GstH264Parse named h264parse0
matroska-demux.c(5213): gst_matroska_demux_loop (): /GstPipeline:pipeline0/GstMatroskaDemux:matroskademux0:
ERROR: pipeline doesn’t want to preroll.
Setting pipeline to NULL …
Freeing pipeline …
Please try the files in https://jell.yfish.us/
Not sure but it seems like the failure is specific to 10 Incredible 4K (Ultra HD) Videos.mkv
You’re right, these files adhere to the pipeline you wrote.
Can I please know how to decode it back?
This is what I tried:
gst-launch-1.0 udpsrc port=5000 ! rtph264depay ! omxh264dec ! nveglglessink -e
and also
gst-launch-1.0 udpsrc port=5000 ! rtph264depay ! h264parse ! omxh264dec ! nveglglessink -e
and the error returned was:
Using winsys: x11
Pipeline is live and does not need PREROLL …
Got context from element ā€˜eglglessink0’: gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING …
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0: No RTP format was negotiated.
gstrtpbasedepayload.c(458): gst_rtp_base_depayload_handle_buffer (): /GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0:
Input buffers need to have RTP caps set on them. This is usually achieved by setting the ā€˜caps’ property of the upstream source element (often udpsrc or appsrc), or by putting a capsfilter element before the depayloader and setting the ā€˜caps’ property on that. Also see README\rtp\gst - gstreamer/gst-plugins-good - 'Good' GStreamer plugins (mirrored from https://gitlab.freedesktop.org/gstreamer/gst-plugins-good)
EOS on shutdown enabled – waiting for EOS after Error
Waiting for EOS…
ERROR: from element /GstPipeline:pipeline0/GstUDPSrc:udpsrc0: Internal data stream error.
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstUDPSrc:udpsrc0:
streaming stopped, reason not-negotiated (-4)
This is done from the same Nano, so why is it not working?
Adding some progress - I got rid of the error by including ā€˜caps’ property:
gst-launch-1.0 udpsrc port=5000 caps = ā€œapplication/x-rtp, media=video, clock-rate=90000, payload=96ā€ ! rtph264depay ! omxh264dec ! nvglglessink -e
Then it seems to accept it, shows that pipeline is PLAYING and ending with ā€œNew clock: GstSystemClockā€ line,
but doesn’t show anything on my screen.
So I’m still baffled.
Please try
gst-launch-1.0 udpsrc port=5000 caps = "application/x-rtp, media=video, clock-rate=90000, payload=96" ! rtph264depay ! h264parse ! nvv4l2decoder ! nvoverlaysink
Hi, thanks again for the quick reply.
It thinks it is playing, but nothing is showing on the screen.
After a few seconds a critical error message appears.
Here’s the output:
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
(gst-launch-1.0:7447): GStreamer-CRITICAL **: 08:35:21.321: gst_mini_object_unref: assertion ā€˜mini_object != NULL’ failed
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:12.776136026
Setting pipeline to READY …
Freeing pipeline …
I’m really sorry to trouble you with this.
I really read the Gstreamer user guide and examples and gazillion forum topics, but none seem to produce the result that I’m after.
Perhaps, you could show me the correct pipeline from server to client to play a simple 4k mkv file from jellyfish over rtp/udp?
Would like to get more information about the use-case. Do you put MKV files in Jetson Nano as a server and other devices can connect to Jetson Nano and play the MKV files?
As a first stage, I put the MKV files on the Jetson Nano, and I want to be able to stream them over RTP/UDP and play them using HW decoding on the Nano itself.
Second stage will be to receive the stream from an outside source, like a camera (MIPI), using HW encoding over RTP/UDP to another Jetson Nano on the network, which will decode and play.
It might be better to run a RTSP server on Jetson Nano as on-demand service. Please check steps in
Jetson Nano FAQ
[Q: Is there any example of running RTSP streaming?]
On Jetson Nano you can run:
$ ./test-launch "filesrc location=jellyfish-5-mbps-hd-h264.mkv ! matroskademux ! h264parse config-interval=-1 ! rtph264pay name=pay0 pt=96"
On another device, you can use VLC player or run a gstreamer command to open the link.
Thanks a lot! I appreciate your answers very much!
How can I affect the outgoing stream resolution?
I want to stream 2 types of streams - one of 4K and one of 720p - and test the CPU usage and power consumption while encoding it to H264 over RTSP
test-launch is a test sample and it can only construct one connection. For multiple connections with different resolutions, would need other users to share experience about implementing the use-case.
I managed to stream twice in two different ports. I just don’t know how to change resolution and stream in HW encoding of my choosing…This is so hard, this device is very frustrating.
