Tried a few pipelines to play this file. Plays ok with “ffplay -flags2 showall” Any help using the HW decoding would be great, Can’t seem to get the pipe to play.
[STREAM]
index=0
codec_name=h264
codec_long_name=H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
profile=High
codec_type=video
codec_time_base=6/359
codec_tag_string=[0][0][0][0]
codec_tag=0x0000
width=1920
height=1080
coded_width=1920
coded_height=1088
has_b_frames=0
sample_aspect_ratio=N/A
display_aspect_ratio=N/A
pix_fmt=yuv420p
DaneLLL
September 23, 2020, 6:52am
3
You may try jetsom_multimedia_api decoding sample:
nvidia@nvidia-desktop:/usr/src/jetson_multimedia_api/samples/00_video_decode$ ./video_decode H264 /home/nvidia/test.264
No luck. This works but I was wanting it on the GPU process.
gst-launch-1.0 filesrc location=main.h264 ! h264parse ! avdec_h264 ! xvimagesink
DaneLLL
September 24, 2020, 1:49am
5
Would like to clarify that there is individual hardware decoder on Jetson platforms, so hardware decoding is not done on GPU.
Yes, Using a Jetson Nano. But haven’t had luck with it. Will PM you a link to the file if you want to try it or possibly troubleshoot it.
DaneLLL
September 24, 2020, 4:53am
7
Please try
$ gst-launch-1.0 filesrc location= MainCam_2020-8-17_19-20-1.h264 ! h264parse ! nvv4l2decoder enable-frame-type-reporting=1 ! nvoverlaysink
This is same as
gstreamer
no yuv output
gst-launch-1.0 filesrc location=gdr.m300.h264 ! h264parse ! nvv4l2decoder ! fakesink dump=true
change nvv4l2decoder to avdec_h264, then yuv output
gst-launch-1.0 filesrc location=gdr.m300.h264 ! h264parse ! avdec_h264 ! fakesink dump=true
cannot play
./video_decode H264 gdr.m300.h264
can play
./video_decode H264 --report-input-metadata gdr.m300.h264
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is PREROLLING ...
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
NvMMLiteNVMEDIADecSetAttribute:: Error status reporting set to 1
FrameType = P
nActiveRefFrames = 0
Frame 0
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
FrameType = P
nActiveRefFrames = 1
Frame 1
FrameType = P
Frame 2
FrameType = P
Frame 3
FrameType = P
Frame 4
Frame 894
FrameType = P
Frame 895
Got EOS from element "pipeline0".
Execution ended after 0:00:29.866772674
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
DaneLLL
September 24, 2020, 6:41am
9
You should see video playback. No?
DaneLLL
September 25, 2020, 1:35am
11
We can see video playback in running the gstreamer pipeline. A bit strange you cannot see it. The log looks OK. Maybe you can do clean re-flash and try again.
Will try, Thanks for the help.
s.n.3
September 7, 2021, 4:47am
14
I have similar issue.
I’d like to use the gstreamer.
My file can be played, but it’s a little laggy.
My pipeline is as follows.
gst-launch-1.0 filesrc location=/home/nvidia/test264.h264 ! h264parse ! nvv4l2decoder enable-frame-type-reporting=1 ! nvvidconv output-buffers=20 ! ‘vid
eo/x-raw(memory:NVMM), format=RGBA, width=1920, height=1080, framerate=30/1’ ! queue ! nvoverlaysink
The log at that time is as follows.
What should I do ?
Setting pipeline to PAUSED …
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
FrameType = I
(IDR)
Frame 0
FrameType = P
Frame 1
NVMEDIA: NVMEDIABufferProcessing: 1096: Consume the extra signalling for EOS
FrameType = I
(IDR)
Frame 12
FrameType = P
Frame 13
FrameType = I
(IDR)
Frame 24
FrameType = P
Frame 25
FrameType = I
(IDR)
Frame 36
FrameType = P
Frame 37
kayccc
September 15, 2021, 3:20am
15
Hi s.n.3 ,
Please help to open a new topic. Thanks
