You should change path in file that is compiled with nvcc,
right-click on file(for example template.cu ), Properties → Configuration Properties → Custom Build Step → Command Line →
“$(CUDA_BIN_PATH)\nvcc.exe” -ccbin “$(VCInstallDir)bin” -c -DWIN32 -D_CONSOLE -D_MBCS -Xcompiler /EHsc,/W3,/nologo,/O2,/Zi,/MT -I"$(CUDA_INC_PATH)" -I./ -I…/…/common/inc -o $(ConfigurationName)$(InputName).obj $(InputFileName)
