I was playing around with a sample project (template) provided with CUDA SDK.
It could be compiled and run w/o any problems in its original location. But it gave the following error when I copied the project to another location.
MyVectorAdd.cu(48) : fatal error C1083: Cannot open include file: ‘cutil_inline.h’: No such file or directory
Any idea?
cutil_inline.h is located somewhere within the common subdirectory (common/inc, maybe?), so you’re breaking that path.
thanks for your response.
I found where cutil_inline.h is
C:\ProgramData\NVIDIA Corporation\NVIDIA CUDA SDK\common\inc
and put the path into Configuration Properties → C/C++ → General:->Additional Include Directories
but still doesn’t work
The original path in the command line for compiling is
-I…/…/common/inc
Now I changed to
-I“$(NVSDKCUDA_ROOT)\common\incâ€
it works now
But it’s ridiculous, I did everything exactly according to official document “Creating Your Own CUDA Program” in CUDA_SDK_release_notes_windows.txt (CUDA SDK 2.2)
No one test them before releasing???
lulach
July 20, 2009, 9:30am
5
I now encountered the same problem.
However, I am unable to edit the command line options which are greyed out. This is the case for all the SDK samples.
I’m using SDK 2.2 WinXP VS2005
Did you have the same problem? And if so, how did you get around it?
Thanks in advance.
-I…/…/common/inc
Now I changed to
it works now
Thanks alot for spelling this out. It helped me eliminate a few errors.
kemu
January 22, 2010, 3:18pm
7
Thanks in advance.
i had the same problem
u should add the “…\common\inc” direcotry into the additional include directories under CUDA BUild Rule, which u have embeded in MS Visual Studio.
Pooty
June 25, 2013, 4:15pm
8
The location of cutil_inline.h was, for me, in the hidden folder ProgramData and as follow :
C:\ProgramData\NVIDIA Corporation\NVIDIA GPU Computing SDK 4.2\C\common\inc
I fixed the C1083 issue doing this :
Right click on your project (vs8) > Properties
Custom build step
Command line > adding this : -I"C:\ProgramData\NVIDIA Corporation\NVIDIA GPU Computing SDK 4.2\C\common\inc"
Hope this can help you…
