I have some trouble to record a video with IMX708.
I successfully recored the video without displaying the screen by following pipeline.
Now I wanted to be able to see the screen while recording, so I added tee element to separate the tasks and utilized openCV for displaying the screen. However, the pipeline didn’t work (I couldn’t see the screen, and the video wasn’t recorded either). Also the terminal didn’t show any errors. It just stopped.
Strangely, I’ve succeeded in displaying images and recording video simultaneously at IMX219 and IMX477 sensors. Could you give me some advice?
nvbuf_utils: Could not get EGL display connection
GST_ARGUS: NvArgusCameraSrc: Setting ISP Digital Gain Range : 2 2
GST_ARGUS: NvArgusCameraSrc: Setting Gain Range : 16 16
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 4608 x 2592 FR = 14.000001 fps Duration = 71428568 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 500000, max 65487000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 4608 H = 2592
seconds to Run = 0
Frame Rate = 14.000001
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
it looks like display issue according to the failure messages…
please try setup the environment variable, for instance, $ export DISPLAY=:0
you may also execute xrandr to dump all those display supported resolutions for double check.
for example,
$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 477mm x 268mm
1920x1080 60.00*+ 59.94 50.00 29.97
Hi DaneLLL.
I changed my code and got another error message.
"_ValidateEncodeParams: Invalid encode width "
python test.py
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
Camera index = 0
Camera mode = 0
seconds to Run = 0
H264: Profile = 66, Level = 0
tvmrVideoEncoderBitsAvailable_MSENC: ucode ERROR = 16
NvVideoEncTransferOutputBufferToBlock: DoWork failed line# 674
NvVideoEnc: NvVideoEncTransferOutputBufferToBlock TransferBufferToBlock failed Line=685
This is my full code.
def pip_video():
return "nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=(int)4608, height=(int)2592,format=(string)NV12, framerate=(fraction)14/1 ! tee name=t t. ! queue ! nvv4l2h264enc ! h264parse ! matroskamux ! filesink location=test.mp4 t.! queue ! nvvidconv ! video/x-raw, format=(string)I420, width=640, height=480 ! appsink sync=0 ";
def read_cam():
cap = cv2.VideoCapture(pip_video())
if cap.isOpened():
cv2.namedWindow("demo", cv2.WINDOW_AUTOSIZE)
while True:
ret_val, img = cap.read();
img2 = cv2.cvtColor(img, cv2.COLOR_YUV2BGR_I420);
img3 = cv2.resize(img2,(1200,900));
cv2.imshow('demo',img3)
keyCode = cv2.waitKey(10)
# Stop the program on the BS key
if keyCode == 8:
break
else:
print("camera open failed")
cv2.destroyAllWindows()
I am uncertain as to why this error is occurring. This code functioned without issue with the IMX477. (The width and height were adjusted to 4032 and 3040, respectively, to accommodate the IMX477.)
You mean I should change the code "video/x-raw(memory:NVMM), width=(int)4608, height=(int)2592~~ "
to " video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160 "?
But as you know, I cannot use any other options except 4608 x 2592 because the driver doesn’t support other resolutions. In fact, even when I attempt to adjust the resolution to 4k, the camera still operates at 4608 x 2592.
Furthermore, the IMX477, which has a resolution of 4032 x 3040, provided me with a live screen while recording videos even beyond 4K resolution. Additionally, video recording operates smoothly with the IMX708, although it does not provide me with a live screen when using the pipeline below.
I noticed that the video was recorded at 4608 x 2592 resolution when I utilized your recommended code.
I am currently perplexed about what occurred with the hardware encoder. Does the video, originally in NVMM memory at 4608 x 2592 resolution, undergo downscaling to 3840 x 2160 through the hardware encoder? Is there any data loss when going through the hardware encoder? If so, why was my video stored at 4608 x 2592 resolution?
Could you provide an explanation?
Thank you for your assistance.
I understand that downscaling frees us from the constraints of the encoder.
However, I am concerned about potential data loss during the downscaling process.
1. Can you explain the principle behind downscaling? Does it simply resize the image from 4608 x 2592 to 1920 x 1080, or does it crop the image to 1920 x 1080 from the original 4608 x 2592?
If the hardware encoder cannot handle 4608 x 2592 resolution, I would prefer to crop the image to 2592 x 2592 instead of downsizing it. As shown in the image below:
2. Is there a way to crop only the desired portion and input it to the hardware encoder?
Please set the properties of nvvidconv plugin to crop the frame:
left : Pixels to crop at left
flags: readable, writable
Integer. Range: 0 - 2147483647 Default: 0
right : Pixels to crop at right
top : Pixels to crop at top
bottom : Pixels to crop at bottom
