Compiling appears successful with pgcc 15.9-0. However, am not able to run on the Fiji GPU.
$ pgcc -Minfo -acc -ta=radeon acc_c1.c
main:
36, Generating copyout(r[:n])
Generating copyin(a[:n])
37, Loop is parallelizable
Accelerator kernel generated
Generating Radeon code
37, #pragma acc loop gang, vector(128) /* global dim(0) local dim(0) */
$ ./a.out
Current file: /opt/pgi/linux86-64/2015/examples/OpenACC/samples/acc_c1/acc_c1.c
function: main
line: 36
Current region was compiled for:
AMD Radeon GPU
Available accelerators:
device[1]: Native X86 (CURRENT DEVICE)
The accelerator does not match the profile for which this program was compiled
By default, “-ta=radeon” targets Tahiti platforms. For other Radeons, you need to specify achitecture.
We do support the R9 series, but for the Hawaii processors (-ta=radeon:hawaii). I’m not sure if Hawaii binaries can run on a Fiji processor, but that’s where I’d start.
I tried with (-ta=radeon:hawaii). Unfortunately, the same message (accelerator does not match the profile).
$ pgcc -acc -Minfo -ta=radeon:hawaii acc_c1.c
main:
$ ./a.out
function: main
line: 36
AMD Radeon GPU
Well, after many attempts, was unable to run OpenACC on the R9 380 (Tonga) or the R9 Fury Nano (Fiji) GPUs. Please (please) include support for (-acc -ta=radeon:gcn12 ) or ( -acc -ta=radeon:{tonga|fiji} ). Thank you.
It is amazing seeing the R9 Fury Nano running 2x ~ 2.5x the performance of the R9 285/380 GPU with similar power consumption. I thought about the Radeon HD 7770 (Cape Verde) or the R7 250X (re-branded), but not wanting to purchase another GPU.
Being able to run OpenACC on Radeon GCN 1.2 hardware is a wish for me. It’s what I want for Christmas ( PGI Workstation 15.9.x supporting Radeon Bonaire/Tonga/Fiji ), more than anything, other than continuing to be good to others, love life, and the joy of learning. OpenACC is very cool and not to forget -ta=multicore for folks who have not tried that.
There are so many code names and not sure if OpenACC works on Bonaire. Also, am not sure if one would be able to specify gcn11 or gcn12 in a later release.
GCN 1.1: ( -acc -ta=radeon:gcn11 or -acc -ta=radeon:{bonaire|hawaii} )
GCN 1.2: ( -acc -ta=radeon:gcn12 or -acc -ta=radeon:{tonga|fiji} )
