Cannot Run RXPbench on Host
I am trying to run RXPbench on a linux machine and compare the result with running RXPbench on a Bluefield-2 DPU with REgex acceleration. Due to some reasons, the linux machine does not have a Bluefield DPU and is only equipped with a mellanox NIC(shown below).
a1:00.0 Ethernet controller: Mellanox Technologies MT28908 Family [ConnectX-6]
After installing the latest doca-tools and latest mlx5 driver on the linux machine, I tried RXPbench but the output shows failure:
user@linux:~$ sudo rxpbench -D "-l5,6 -n 1 -a a1:00.0" --input-mode text_file -f ./data.txt -d hs -R ./rules.hs -c 1 -s 10 -l 2048 > log
EAL: Detected 64 lcore(s)
EAL: Detected 8 NUMA nodes
EAL: Detected static linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode 'VA'
EAL: Probing VFIO support...
EAL: VFIO support initialized
EAL: Probe PCI driver: mlx5_pci (15b3:101b) device: 0000:a1:00.0 (socket 6)
set_mempolicy: Invalid argument
mlx5_common: Failed to initialize global MR share cache.
EAL: Requested device 0000:a1:00.0 cannot be used
EAL: Bus (pci) probe failed.
EAL: Device is not probed
// The rest parts are output from RXPbench
I am confused about two points:
  1. Why does EAL initialization fail?
  2. Does RXPbench only work with Bluefield-2? I assume that it can work on a host without a Bluefield-2 as long as you do not use REgex acceleration and use Hyperscan on the host.
I have confirmed that it is due to DPDK initilization problem of my host machine.
Excuse me, what is the solution to this situation
