RNN model use tensorflow API:tf.contrib.cudnn_rnn.CudnnLSTM create bidirection rnn。from the docs, I think it’s support this API. (https://docs.nvidia.com/deeplearning/sdk/tensorrt-developer-guide/index.html#working_with_tf_rnn)
But I don’t know how to set parameters.
Does anyone know how to solve it? Or is there an example for BiRNN?
Here is my env:
- Linux version: Ubuntu 18.04
- GPU: GTX745
- Nvidia driver version: 430.26
- CUDA version: 10.1
- CUDNN version: 7
- TensorRT version: 5.1.5.0
- python3.6
#!/usr/bin python
# -*- coding: utf-8 -*-
import numpy as np
import tensorrt as trt
import common
from tensorflow.python import pywrap_tensorflow
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
class ModelData(object):
INPUT_NAME = "x"
INPUT_SHAPE = (48, 1, 32, 256)
OUTPUT_NAME = "output"
OUTPUT_SIZE = 355
DTYPE = trt.float32
def populate_network(network, weights):
# cnn
input_tensor = network.add_input(name=ModelData.INPUT_NAME, dtype=ModelData.DTYPE, shape=ModelData.INPUT_SHAPE)
scale1 = network.add_scale(input=input_tensor, mode=trt.ScaleMode.UNIFORM)
conv1_w = weights['conv1/weights']
conv1_b = weights['conv1/BatchNorm/beta']
conv1 = network.add_convolution(input=scale1.get_output(0), num_output_maps=64, kernel_shape=(3, 3), kernel=conv1_w, bias=conv1_b)
conv1.padding_mode = trt.PaddingMode.SAME_UPPER
print(scale1.get_output(0).shape, conv1.get_output(0).shape)
scale2 = network.add_scale(input=conv1.get_output(0), mode=trt.ScaleMode.UNIFORM)
conv2_w = weights['conv2/weights']
conv2_b = weights['conv2/BatchNorm/beta']
conv2 = network.add_convolution(input=scale2.get_output(0), num_output_maps=64, kernel_shape=(3, 3), kernel=conv2_w,
bias=conv2_b)
conv2.padding_mode = trt.PaddingMode.SAME_UPPER
pool1 = network.add_pooling(input=conv2.get_output(0), type=trt.PoolingType.MAX, window_size=[2, 2])
pool1.stride = (2, 2)
pool1.padding_mode = trt.PaddingMode.SAME_UPPER
scale3 = network.add_scale(input=pool1.get_output(0), mode=trt.ScaleMode.UNIFORM)
conv3_w = weights['conv3/weights']
conv3_b = weights['conv3/BatchNorm/beta']
conv3 = network.add_convolution(input=scale3.get_output(0), num_output_maps=128, kernel_shape=(3, 3), kernel=conv3_w,
bias=conv3_b)
conv3.padding_mode = trt.PaddingMode.SAME_UPPER
scale4 = network.add_scale(input=conv3.get_output(0), mode=trt.ScaleMode.UNIFORM)
conv4_w = weights['conv4/weights']
conv4_b = weights['conv4/BatchNorm/beta']
conv4 = network.add_convolution(input=scale4.get_output(0), num_output_maps=128, kernel_shape=(3, 3), kernel=conv4_w,
bias=conv4_b)
conv4.padding_mode = trt.PaddingMode.SAME_UPPER
pool2 = network.add_pooling(input=conv4.get_output(0), type=trt.PoolingType.MAX, window_size=(2, 2))
pool2.stride = (2, 1)
pool2.padding_mode = trt.PaddingMode.SAME_UPPER
scale5 = network.add_scale(input=pool2.get_output(0), mode=trt.ScaleMode.UNIFORM)
conv5_w = weights['conv5/weights']
conv5_b = weights['conv5/BatchNorm/beta']
conv5 = network.add_convolution(input=scale5.get_output(0), num_output_maps=256, kernel_shape=(3, 3), kernel=conv5_w,
bias=conv5_b)
conv5.padding_mode = trt.PaddingMode.SAME_UPPER
scale6 = network.add_scale(input=conv5.get_output(0), mode=trt.ScaleMode.UNIFORM)
conv6_w = weights['conv6/weights']
conv6_b = weights['conv6/BatchNorm/beta']
conv6 = network.add_convolution(input=scale6.get_output(0), num_output_maps=256, kernel_shape=(3, 3), kernel=conv6_w,
bias=conv6_b)
conv6.padding_mode = trt.PaddingMode.SAME_UPPER
pool3 = network.add_pooling(input=conv6.get_output(0), type=trt.PoolingType.MAX, window_size=(2, 2))
pool3.stride = (2, 1)
pool3.padding_mode = trt.PaddingMode.SAME_UPPER
scale7 = network.add_scale(input=pool3.get_output(0), mode=trt.ScaleMode.UNIFORM)
conv7_w = weights['conv7/weights']
conv7_b = weights['conv7/BatchNorm/beta']
conv7 = network.add_convolution(input=scale7.get_output(0), num_output_maps=512, kernel_shape=(3, 3), kernel=conv7_w,
bias=conv7_b)
conv7.padding_mode = trt.PaddingMode.SAME_UPPER
scale8 = network.add_scale(input=conv7.get_output(0), mode=trt.ScaleMode.UNIFORM)
conv8_w = weights['conv8/weights']
conv8_b = weights['conv8/BatchNorm/beta']
conv8 = network.add_convolution(input=scale8.get_output(0), num_output_maps=512, kernel_shape=(3, 3), kernel=conv8_w,
bias=conv8_b)
conv8.padding_mode = trt.PaddingMode.SAME_UPPER
print(scale8.get_output(0).shape, conv8_w.shape, conv8_b.shape, conv8.get_output(0).shape)
scale9 = network.add_scale(input=conv8.get_output(0), mode=trt.ScaleMode.UNIFORM)
pool4_w = weights['pool4/weights']
pool4_b = weights['pool4/BatchNorm/beta']
pool4 = network.add_convolution(input=scale9.get_output(0), num_output_maps=512, kernel_shape=(4, 3), kernel=pool4_w,
bias=pool4_b)
pool4.padding_mode = trt.PaddingMode.SAME_UPPER
pool5 = network.add_pooling(input=pool4.get_output(0), type=trt.PoolingType.MAX, window_size=(2, 2))
pool5.stride = (2, 1)
pool5.padding_mode = trt.PaddingMode.SAME_UPPER
feat = network.add_shuffle(input=pool5.get_output(0))
feat.first_transpose = (0, 2, 3, 1)
feat.reshape_dims = (feat.get_output(0).shape[0], -1, feat.get_output(0).shape[-1])
feat = network.add_shuffle(input=feat.get_output(0))
feat.first_transpose = (1, 0, 2)
# rnn
rnn = network.add_rnn_v2(input=feat.get_output(0), layer_count=2, hidden_size=256, max_seq_length=48,
op=trt.RNNOperation.LSTM)
rnn.input_mode = trt.RNNInputMode.SKIP
rnn.direction = trt.RNNDirection.BIDIRECTION
rnn0_fw_w = weights['rnn/stack_bidirectional_rnn/cell_0/bidirectional_rnn/fw/cudnn_compatible_lstm_cell/kernel']
rnn0_fw_b = weights['rnn/stack_bidirectional_rnn/cell_0/bidirectional_rnn/fw/cudnn_compatible_lstm_cell/bias']
rnn0_bw_w = weights['rnn/stack_bidirectional_rnn/cell_0/bidirectional_rnn/bw/cudnn_compatible_lstm_cell/kernel']
rnn0_bw_b = weights['rnn/stack_bidirectional_rnn/cell_0/bidirectional_rnn/bw/cudnn_compatible_lstm_cell/bias']
rnn1_fw_w = weights['rnn/stack_bidirectional_rnn/cell_1/bidirectional_rnn/fw/cudnn_compatible_lstm_cell/kernel']
rnn1_fw_b = weights['rnn/stack_bidirectional_rnn/cell_1/bidirectional_rnn/fw/cudnn_compatible_lstm_cell/bias']
rnn1_bw_w = weights['rnn/stack_bidirectional_rnn/cell_1/bidirectional_rnn/bw/cudnn_compatible_lstm_cell/kernel']
rnn1_bw_b = weights['rnn/stack_bidirectional_rnn/cell_1/bidirectional_rnn/bw/cudnn_compatible_lstm_cell/bias']
gate_order = [trt.RNNGateType.INPUT, trt.RNNGateType.CELL, trt.RNNGateType.FORGET, trt.RNNGateType.OUTPUT]
num_gates = len(gate_order)
for i in range(num_gates*2):
flag = True
if i >= num_gates:
flag = False
rnn.set_weights_for_gate(layer_index=0, gate=gate_order[i % num_gates], is_w=flag, weights=rnn0_fw_w)
rnn.set_bias_for_gate(layer_index=0, gate=gate_order[i % num_gates], is_w=flag, bias=rnn0_fw_b)
rnn.set_weights_for_gate(layer_index=0, gate=gate_order[i % num_gates], is_w=flag, weights=rnn0_bw_w)
rnn.set_bias_for_gate(layer_index=0, gate=gate_order[i % num_gates], is_w=flag, bias=rnn0_bw_b)
rnn.set_weights_for_gate(layer_index=1, gate=gate_order[i % num_gates], is_w=flag, weights=rnn1_fw_w)
rnn.set_bias_for_gate(layer_index=1, gate=gate_order[i % num_gates], is_w=flag, bias=rnn1_fw_b)
rnn.set_weights_for_gate(layer_index=1, gate=gate_order[i % num_gates], is_w=flag, weights=rnn1_bw_w)
rnn.set_bias_for_gate(layer_index=1, gate=gate_order[i % num_gates], is_w=flag, bias=rnn1_bw_b)
print('rnn shape', rnn.get_output(0).shape)
fc_w = weights['rnn/logits/kernel']
fc_b = weights['rnn/logits/bias']
feat = network.add_shuffle(input=rnn.get_output(0))
feat.reshape_dims = (rnn.get_output(0).shape[0], rnn.get_output(0).shape[1], 1, 1, rnn.get_output(0).shape[-1])
print('feat', feat.get_output(0).shape)
fc = network.add_fully_connected(input=feat.get_output(0), num_outputs=355, kernel=fc_w, bias=fc_b)
print('fc', fc.get_output(0).shape)
activate = network.add_activation(input=fc.get_output(0), type=trt.ActivationType.RELU)
print('activate', activate.get_output(0).shape)
feat = network.add_shuffle(input=activate.get_output(0))
feat.reshape_dims = (activate.get_output(0).shape[0], activate.get_output(0).shape[1], activate.get_output(0).shape[2])
print('output', feat.get_output(0).shape)
feat.get_output(0).name = ModelData.OUTPUT_NAME
network.mark_output(tensor=feat.get_output(0))
def get_weights(mod_path='../0912/fix.ckpt'):
print('run')
reader = pywrap_tensorflow.NewCheckpointReader(mod_path)
var_to_shape_map = reader.get_variable_to_shape_map()
weights = {}
for key, value in var_to_shape_map.items():
# print('tensor_name: ', key, value)
# print(reader.get_tensor(key))
weights[key] = reader.get_tensor(key)
# print(type(reader.get_tensor(key)))
return weights
def build_engine(weights):
with trt.Builder(TRT_LOGGER) as builder, builder.create_network() as network:
builder.max_workspace_size = common.GiB(1)
builder.max_batch_size = 1
# Populate the network using weights.
print('network', network)
# Build and return an engine.
engine = builder.build_cuda_engine(network)
print('engine', engine)
return builder.build_cuda_engine(network)
def get_engine(engine_file_path, weights):
try:
with open(engine_file_path, "rb") as f, trt.Runtime(TRT_LOGGER) as runtime:
# Note that we have to provide the plugin factory when deserializing an engine built with an IPlugin or IPluginExt.
return runtime.deserialize_cuda_engine(serialized_engine=f.read(), plugin_factory=None)
except Exception as e:
# Fallback to building an engine if the engine cannot be loaded for any reason.
engine = build_engine(weights)
# with open(engine_file_path, "wb") as f:
# f.write(engine.serialize())
return engine
def main():
weights = get_weights()
print('success')
engine_file_path = 'crnn.engine'
with get_engine(engine_file_path, weights) as engine:
# Build an engine, allocate buffers and create a stream.
inputs, outputs, bindings, stream = common.allocate_buffers(engine)
with engine.create_execution_context() as context:
[output] = common.do_inference(context, bindings=bindings, inputs=inputs, outputs=outputs, stream=stream)
# pred = np.argmax(output)
print('success')
if __name__ == '__main__':
main()
this is my pb file:
https://drive.google.com/file/d/15Qnyg99Yyj-PhbZHkzVbMQ3KcqVk2d08/view?usp=sharing
