OK, going straight to the point. The Jetson comes with PWM outputs. However when I try to access them, it tells me “Permission Denied”. I’m following The guidelines from http://elinux.org/Jetson/GPIO.
CONFIG_PWM_SYSFS=y
The guidelines says the following
Note: In the L4T kernel, the “soc0” directory component might not be there, and the PWM controller might be named something different like “pwm.0” or “pwm.1”. You might want to just run:
cd /sys
find . –type d –name "pwmchip*"
However. When I try the command line cited above, the Jetsons gives the following
find: './kernel/debug': Permission denied
Any clue about what am I doing wrong? What am I missing?
Did you use root permissions? sudo each command, or “sudo -s” and continue. Files controlling system operation are restricted and not open to every account in the world. Pretty much everything that does something interesting requires sudo for an Ubuntu distribution.
OK. I did what you suggested “sudo -s” and the other command lines. However, it does not give a proper answer. I want to know which are the pins at the GPIO I can assign as PWM.
root@tegra-ubuntu:/sys# find . –type d –name "pwmchip*"
Many of the I/O pins are used by more than one function, with only 1 enabled at a time. Even that article mentions setting up PINMUX and being sure that the GPIO is not taking over that pin. In terms of the actual PWM files in /sys, these are kernel features…those files do not exist unless the kernel feature exists. The article refers to this:
CONFIG_PWM_SYSFS=y
…which is a feature one has to enable and use from a custom compiled kernel. There are several threads on this forum regarding kernel compile and installation. You can practice and try configuring and building kernels with no risk. When satisfied, you can ask more questions on installation options.
Santyago, I am considering purchasing the Jetson K1 motherboard for my HTPC setup: I currently will need it to be able to stream Youtube videos and other Flashplayer videos. Also, i will need it to receive internet through a wireless USB or mini-PCI-e fitting.
How do i get it to stream Youtube? Is it simple install through the Chrome app for Linux?
What wireless device is best to use with-out much trouble shooting? Can be USB or mini-PCI-e
