I’m trying to build the code sample found here: code-samples/posts/cmake at master · robertmaynard/code-samples · GitHub but it doesn’t build.
I’m using the following configuration: CUDA 11.4.2_471.41_win10, CMake 3.21.3, Visual Studio 16.11.5
and I get the following output from Visual Studio when I try to build the project:
Rebuild started...
1>------ Rebuild All started: Project: ZERO_CHECK, Configuration: Debug x64 ------
1>Build started 10/20/2021 8:08:58 AM.
1>Target InitializeBuildStatus:
1> Creating "x64\Debug\ZERO_CHECK\ZERO_CHECK.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
1>Target CustomBuild:
1> Checking Build System
1>Target FinalizeBuildStatus:
1> Deleting file "x64\Debug\ZERO_CHECK\ZERO_CHECK.tlog\unsuccessfulbuild".
1> Touching "x64\Debug\ZERO_CHECK\ZERO_CHECK.tlog\ZERO_CHECK.lastbuildstate".
1>
1>Build succeeded.
1> 0 Warning(s)
1> 0 Error(s)
1>
1>Time Elapsed 00:00:00.16
2>------ Rebuild All started: Project: particles, Configuration: Debug x64 ------
2>Build started 10/20/2021 8:08:58 AM.
2>Target CudaClean:
2>Target ResolveProjectReferences:
2>Target InitializeBuildStatus:
2> Touching "particles.dir\Debug\particles.tlog\unsuccessfulbuild".
2>Target CustomBuild:
2> Building Custom Rule C:/Users/<username>/Documents/Github/code-samples/posts/cmake/CMakeLists.txt
2>Target CudaBuild:
2> Target CudaBuildCore:
2> Compiling CUDA source file ..\particle.cu...
2> Compiling CUDA source file ..\v3.cu...
2>
2> C:\Users\<username>\Documents\Github\code-samples\posts\cmake\build>"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\bin\nvcc.exe" -gencode=arch=compute_52,code=\"sm_52,compute_52\" --use-local-env -ccbin "C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\VC\Tools\MSVC\14.28.29910\bin\HostX64\x64" -x cu -rdc=true -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\include" --keep-dir x64\Debug -maxrregcount=0 --ptxas-options=-v --machine 64 --compile -cudart static -std=c++14 -Xcompiler="/EHsc -Zi -Ob0" -g -D_WINDOWS -D"CMAKE_INTDIR=\"Debug\"" -DWIN32 -D_WINDOWS -D"CMAKE_INTDIR=\"Debug\"" -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /Fd"C:\Users\<username>\Documents\Github\code-samples\posts\cmake\build\Debug\particles.pdb" /FS /Zi /RTC1 /MDd /GR" -o particles.dir\Debug\particle.obj "C:\Users\<username>\Documents\Github\code-samples\posts\cmake\particle.cu"
2>
2> C:\Users\<username>\Documents\Github\code-samples\posts\cmake\build>"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\bin\nvcc.exe" -gencode=arch=compute_52,code=\"sm_52,compute_52\" --use-local-env -ccbin "C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\VC\Tools\MSVC\14.28.29910\bin\HostX64\x64" -x cu -rdc=true -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\include" --keep-dir x64\Debug -maxrregcount=0 --ptxas-options=-v --machine 64 --compile -cudart static -std=c++14 -Xcompiler="/EHsc -Zi -Ob0" -g -D_WINDOWS -D"CMAKE_INTDIR=\"Debug\"" -DWIN32 -D_WINDOWS -D"CMAKE_INTDIR=\"Debug\"" -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /Fd"C:\Users\<username>\Documents\Github\code-samples\posts\cmake\build\Debug\particles.pdb" /FS /Zi /RTC1 /MDd /GR" -o particles.dir\Debug\v3.obj "C:\Users\<username>\Documents\Github\code-samples\posts\cmake\v3.cu"
2> nvcc fatal : A single input file is required for a non-link phase when an outputfile is specified
2> C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\MSBuild\Microsoft\VC\v160\BuildCustomizations\CUDA 11.4.targets(785,9): error MSB3721: The command ""C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\bin\nvcc.exe" -gencode=arch=compute_52,code=\"sm_52,compute_52\" --use-local-env -ccbin "C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\VC\Tools\MSVC\14.28.29910\bin\HostX64\x64" -x cu -rdc=true -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\include" --keep-dir x64\Debug -maxrregcount=0 --ptxas-options=-v --machine 64 --compile -cudart static -std=c++14 -Xcompiler="/EHsc -Zi -Ob0" -g -D_WINDOWS -D"CMAKE_INTDIR=\"Debug\"" -DWIN32 -D_WINDOWS -D"CMAKE_INTDIR=\"Debug\"" -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /Fd"C:\Users\<username>\Documents\Github\code-samples\posts\cmake\build\Debug\particles.pdb" /FS /Zi /RTC1 /MDd /GR" -o particles.dir\Debug\particle.obj "C:\Users\<username>\Documents\Github\code-samples\posts\cmake\particle.cu"" exited with code 1.
2> Done building target "CudaBuildCore" in project "particles.vcxproj" -- FAILED.
2>
2> Done building project "particles.vcxproj" -- FAILED.
2> C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\MSBuild\Microsoft\VC\v160\BuildCustomizations\CUDA 11.4.targets(785,9): error MSB3721: The command ""C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\bin\nvcc.exe" -gencode=arch=compute_52,code=\"sm_52,compute_52\" --use-local-env -ccbin "C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\VC\Tools\MSVC\14.28.29910\bin\HostX64\x64" -x cu -rdc=true -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\include" --keep-dir x64\Debug -maxrregcount=0 --ptxas-options=-v --machine 64 --compile -cudart static -std=c++14 -Xcompiler="/EHsc -Zi -Ob0" -g -D_WINDOWS -D"CMAKE_INTDIR=\"Debug\"" -DWIN32 -D_WINDOWS -D"CMAKE_INTDIR=\"Debug\"" -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /Fd"C:\Users\<username>\Documents\Github\code-samples\posts\cmake\build\Debug\particles.pdb" /FS /Zi /RTC1 /MDd /GR" -o particles.dir\Debug\v3.obj "C:\Users\<username>\Documents\Github\code-samples\posts\cmake\v3.cu"" exited with code 1.
2>
2>
2>Build FAILED.
2>
2>C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\MSBuild\Microsoft\VC\v160\BuildCustomizations\CUDA 11.4.targets(785,9): error MSB3721: The command ""C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\bin\nvcc.exe" -gencode=arch=compute_52,code=\"sm_52,compute_52\" --use-local-env -ccbin "C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\VC\Tools\MSVC\14.28.29910\bin\HostX64\x64" -x cu -rdc=true -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\include" --keep-dir x64\Debug -maxrregcount=0 --ptxas-options=-v --machine 64 --compile -cudart static -std=c++14 -Xcompiler="/EHsc -Zi -Ob0" -g -D_WINDOWS -D"CMAKE_INTDIR=\"Debug\"" -DWIN32 -D_WINDOWS -D"CMAKE_INTDIR=\"Debug\"" -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /Fd"C:\Users\<username>\Documents\Github\code-samples\posts\cmake\build\Debug\particles.pdb" /FS /Zi /RTC1 /MDd /GR" -o particles.dir\Debug\particle.obj "C:\Users\<username>\Documents\Github\code-samples\posts\cmake\particle.cu"" exited with code 1.
2>C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\MSBuild\Microsoft\VC\v160\BuildCustomizations\CUDA 11.4.targets(785,9): error MSB3721: The command ""C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\bin\nvcc.exe" -gencode=arch=compute_52,code=\"sm_52,compute_52\" --use-local-env -ccbin "C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\VC\Tools\MSVC\14.28.29910\bin\HostX64\x64" -x cu -rdc=true -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\include" --keep-dir x64\Debug -maxrregcount=0 --ptxas-options=-v --machine 64 --compile -cudart static -std=c++14 -Xcompiler="/EHsc -Zi -Ob0" -g -D_WINDOWS -D"CMAKE_INTDIR=\"Debug\"" -DWIN32 -D_WINDOWS -D"CMAKE_INTDIR=\"Debug\"" -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /Fd"C:\Users\<username>\Documents\Github\code-samples\posts\cmake\build\Debug\particles.pdb" /FS /Zi /RTC1 /MDd /GR" -o particles.dir\Debug\v3.obj "C:\Users\<username>\Documents\Github\code-samples\posts\cmake\v3.cu"" exited with code 1.
2> 0 Warning(s)
2> 2 Error(s)
2>
2>Time Elapsed 00:00:02.98
3>------ Rebuild All started: Project: particle_test, Configuration: Debug x64 ------
3>Build started 10/20/2021 8:09:01 AM.
3>Target CudaClean:
3>Target ResolveProjectReferences:
3>Target InitializeBuildStatus:
3> Touching "particle_test.dir\Debug\particle_test.tlog\unsuccessfulbuild".
3>Target CustomBuild:
3> Building Custom Rule C:/Users/<username>/Documents/Github/code-samples/posts/cmake/CMakeLists.txt
3>Target CudaBuild:
3> Target CudaBuildCore:
3> Compiling CUDA source file ..\test.cu...
3>
3> C:\Users\<username>\Documents\Github\code-samples\posts\cmake\build>"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\bin\nvcc.exe" -gencode=arch=compute_52,code=\"sm_52,compute_52\" --use-local-env -ccbin "C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\VC\Tools\MSVC\14.28.29910\bin\HostX64\x64" -x cu -rdc=true -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\include" --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -std=c++14 -Xcompiler="/EHsc -Zi -Ob0" -g -D_WINDOWS -D"CMAKE_INTDIR=\"Debug\"" -DWIN32 -D_WINDOWS -D"CMAKE_INTDIR=\"Debug\"" -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /Fdparticle_test.dir\Debug\vc142.pdb /FS /Zi /RTC1 /MDd /GR" -o particle_test.dir\Debug\test.obj "C:\Users\<username>\Documents\Github\code-samples\posts\cmake\test.cu"
3> test.cu
3>Target GetReferencedVCProjectsInfo:
3> Target GetReferencedVCProjectsInfo:
3>Target CudaLink:
3> C:\Users\<username>\Documents\Github\code-samples\posts\cmake\build>"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\bin\nvcc.exe" -dlink -o particle_test.dir\Debug\particle_test.device-link.obj -Xcompiler "/EHsc /W3 /nologo /Od /Fdparticle_test.dir\Debug\vc142.pdb /Zi /RTC1 /MDd /GR" -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\bin/crt" -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\lib\x64" Debug\particles.lib cudadevrt.lib cudart_static.lib kernel32.lib user32.lib gdi32.lib winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib advapi32.lib -forward-unknown-to-host-compiler -Wno-deprecated-gpu-targets -gencode=arch=compute_52,code=sm_52 --machine 64 particle_test.dir\Debug\test.obj
3> nvlink fatal : Could not open input file 'debug/particles.lib'
3> particles.lib
3> cudadevrt.lib
3> cudart_static.lib
3> kernel32.lib
3> user32.lib
3> gdi32.lib
3> winspool.lib
3> shell32.lib
3> ole32.lib
3> oleaut32.lib
3> uuid.lib
3> comdlg32.lib
3> advapi32.lib
3> test.obj
3> C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\MSBuild\Microsoft\VC\v160\BuildCustomizations\CUDA 11.4.targets(874,9): error MSB3721: The command ""C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\bin\nvcc.exe" -dlink -o particle_test.dir\Debug\particle_test.device-link.obj -Xcompiler "/EHsc /W3 /nologo /Od /Fdparticle_test.dir\Debug\vc142.pdb /Zi /RTC1 /MDd /GR" -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\bin/crt" -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\lib\x64" Debug\particles.lib cudadevrt.lib cudart_static.lib kernel32.lib user32.lib gdi32.lib winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib advapi32.lib -forward-unknown-to-host-compiler -Wno-deprecated-gpu-targets -gencode=arch=compute_52,code=sm_52 --machine 64 particle_test.dir\Debug\test.obj" exited with code 1.
3>Done building target "CudaLink" in project "particle_test.vcxproj" -- FAILED.
3>
3>Done building project "particle_test.vcxproj" -- FAILED.
3>
3>Build FAILED.
3>
3>C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\MSBuild\Microsoft\VC\v160\BuildCustomizations\CUDA 11.4.targets(874,9): error MSB3721: The command ""C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\bin\nvcc.exe" -dlink -o particle_test.dir\Debug\particle_test.device-link.obj -Xcompiler "/EHsc /W3 /nologo /Od /Fdparticle_test.dir\Debug\vc142.pdb /Zi /RTC1 /MDd /GR" -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\bin/crt" -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\lib\x64" Debug\particles.lib cudadevrt.lib cudart_static.lib kernel32.lib user32.lib gdi32.lib winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib advapi32.lib -forward-unknown-to-host-compiler -Wno-deprecated-gpu-targets -gencode=arch=compute_52,code=sm_52 --machine 64 particle_test.dir\Debug\test.obj" exited with code 1.
3> 0 Warning(s)
3> 1 Error(s)
3>
3>Time Elapsed 00:00:05.74
4>------ Rebuild All started: Project: ALL_BUILD, Configuration: Debug x64 ------
4>Build started 10/20/2021 8:09:07 AM.
4>Target ResolveProjectReferences:
4>Target PrepareForBuild:
4> Creating directory "x64\Debug\ALL_BUILD\ALL_BUILD.tlog\".
4>Target InitializeBuildStatus:
4> Creating "x64\Debug\ALL_BUILD\ALL_BUILD.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
4>Target CustomBuild:
4> Building Custom Rule C:/Users/<username>/Documents/Github/code-samples/posts/cmake/CMakeLists.txt
4>Target GetReferencedVCProjectsInfo:
4>Target FinalizeBuildStatus:
4> Deleting file "x64\Debug\ALL_BUILD\ALL_BUILD.tlog\unsuccessfulbuild".
4> Touching "x64\Debug\ALL_BUILD\ALL_BUILD.tlog\ALL_BUILD.lastbuildstate".
4>
4>Build succeeded.
4> 0 Warning(s)
4> 0 Error(s)
4>
4>Time Elapsed 00:00:00.16
========== Rebuild All: 2 succeeded, 2 failed, 0 skipped ==========
I have a similar issue with my own project, which is why I turned to a code sample for a sanity check, but it didn’t help my sanity. Am I doing something wrong here? Is this code sample too outdated?
