QMake build script for CUDA
To complement the CMake scripts posted by Abe, here is a small script to use qmake to generate CUDA projects on both linux and windows (where it can generate Visual Studio projects):
#  CUDA
win32 {
  INCLUDEPATH += $(CUDA_INC_DIR)
  QMAKE_LIBDIR += $(CUDA_LIB_DIR)
  LIBS += -lcudart
 cuda.output = $$OBJECTS_DIR/${QMAKE_FILE_BASE}_cuda.obj
  cuda.commands = $(CUDA_BIN_DIR)/nvcc.exe -c -Xcompiler $$join(QMAKE_CXXFLAGS,",") $$join(INCLUDEPATH,'" -I "','-I "','"') ${QMAKE_FILE_NAME} -o ${QMAKE_FILE_OUT}
unix {
  # auto-detect CUDA path
  CUDA_DIR = $$system(which nvcc | sed 's,/bin/nvcc$,,')
  INCLUDEPATH += $$CUDA_DIR/include
  QMAKE_LIBDIR += $$CUDA_DIR/lib
  LIBS += -lcudart
 cuda.output = ${OBJECTS_DIR}${QMAKE_FILE_BASE}_cuda.obj
  cuda.commands = nvcc -c -Xcompiler $$join(QMAKE_CXXFLAGS,",") $$join(INCLUDEPATH,'" -I "','-I "','"') ${QMAKE_FILE_NAME} -o ${QMAKE_FILE_OUT}
  cuda.depends = nvcc -M -Xcompiler $$join(QMAKE_CXXFLAGS,",") $$join(INCLUDEPATH,'" -I "','-I "','"') ${QMAKE_FILE_NAME} | sed "s,^.*: ,," | sed "s,^ *,," | tr -d '\\n'
cuda.input = CUDA_SOURCES
QMAKE_EXTRA_UNIX_COMPILERS += cuda
You can add this in you .pro files and then you just have to specify the CUDA source files in CUDA_SOURCES variable. I tested it on both windows and linux. On windows it works fine for generating Makefile but requires a change in qmake to generate VS projects. I have to package and submit the required patch to Trolltech…
Edit: missing code in unix part
For me the dependencies work better using
 cuda.dependcy_type = TYPE_C
  cuda.depend_command = nvcc -M -Xcompiler $$join(QMAKE_CXXFLAGS,",") $$join(INCLUDEPATH,'" -I "','-I "','"') ${QMAKE_FILE_NAME} | sed "s,^.*: ,," | sed "s,^ *,," | tr -d '\\n'
instead of the [font=“Courier”]cuda.depends[/font] variable.
But thanks for the initial post. It helped me a lot External Image
Thanks for the great head start!
But I have a questen, which I was unable to get answered by google.
Maybe one of your guys could help me with that.
Is is possible to add another configuration like ‘debug’ or ‘release’ to the project by using qmake? I’d like to have a special Device-Emu-Config, just like in the SDK-Examples.
How would I accomplish that?
hi all,
sorry for the newbie question, but I’m having hard time incorporating the above code into my qmake file. Can someone please post a complete qmake file using, for example, the matrixMul project in the 1.1 SDK? I’m using ubuntu 7.10 with SDK 1.1, 8800GTS.
Thank you very much,
I also made small integration example CUDA+Qt.
Please check full code here: http://sourceforge.net/projects/cuda-z/
Here is my fragment of qmake’s pro-file.
TEMPLATE = app
QT = gui core
CONFIG += qt release warn_on
#CONFIG += console
FORMS = ui/czdialog.ui
HEADERS = \
	src/version.h \
	src/czdialog.h \
	src/cudainfo.h
SOURCES = src/czdialog.cpp \
	src/main.cpp
RESOURCES = res/cuda-z.qrc
win32:RC_FILE += res/cuda-z.rc
CUSOURCES = src/cudainfo.cu
unix:LIBS += -lcuda
win32:LIBS += \
	$(CUDA_LIB_PATH)\cuda.lib \
	$(CUDA_LIB_PATH)\cudart.lib
# Cuda extra-compiler for handling files specified in the CUSOURCES variable
QMAKE_CUC = $(CUDA_BIN_PATH)/nvcc.exe
	cu.name = Cuda ${QMAKE_FILE_IN}
	cu.input = CUSOURCES
	cu.CONFIG += no_link
	cu.variable_out = OBJECTS
	isEmpty(QMAKE_CUC) {
  win32:QMAKE_CUC = $(CUDA_BIN_PATH)/nvcc.exe
  else:QMAKE_CUC = nvcc
	isEmpty(CU_DIR):CU_DIR = .
	isEmpty(QMAKE_CPP_MOD_CU):QMAKE_CPP_MOD_CU =
	isEmpty(QMAKE_EXT_CPP_CU):QMAKE_EXT_CPP_CU = .cu
	INCLUDEPATH += $(CUDA_INC_PATH)
	QMAKE_CUFLAGS += $$QMAKE_CXXFLAGS $$QMAKE_CXXFLAGS_RELEASE $$QMAKE_CXXFLAGS_RTTI_ON $$QMAKE_CXXFLAGS_WARN_ON $$QMAKE_CXXFLAGS_STL_ON
	QMAKE_CUEXTRAFLAGS += -Xcompiler $$join(QMAKE_CUFLAGS, ",")
	QMAKE_CUEXTRAFLAGS += $(DEFINES) $(INCPATH) $$join(QMAKE_COMPILER_DEFINES, " -D", -D)
	QMAKE_CUEXTRAFLAGS += -c
	cu.commands = $$QMAKE_CUC $$QMAKE_CUEXTRAFLAGS -o $$OBJECTS_DIR/$${QMAKE_CPP_MOD_CU}${QMAKE_FILE_BASE}$${QMAKE_EXT_OBJ} ${QMAKE_FILE_NAME}$$escape_expand(\n\t)
	cu.output = $$OBJECTS_DIR/$${QMAKE_CPP_MOD_CU}${QMAKE_FILE_BASE}$${QMAKE_EXT_OBJ}
	silent:cu.commands = @echo nvcc ${QMAKE_FILE_IN} && $$cu.commands
	QMAKE_EXTRA_COMPILERS += cu
	build_pass|isEmpty(BUILDS):cuclean.depends = compiler_cu_clean
	else:cuclean.CONFIG += recursive
	QMAKE_EXTRA_TARGETS += cuclean
Tested with VS2005 and Qt 4.4.0.
I can’t test it in linux yet…
WBR,
AG
   I am also using Qt to develop cuda code, but I can not debug my .cu code. I can step into .cu file, but I can not step into the cuda kernels. I also tried run cuda-gdb in terminal, but I can not step into the cuda kernels either. What do I need to change for my .pro file? Thank you very much.
Best,
Wu
[codebox]
Path to opencv install
OPENCV_DIR = /usr/local/opencv
Path to cuda SDK install
CUDA_SDK = /home/wu/NVIDIA_GPU_Computing_SDK/C
Path to cuda toolkit install
CUDA_DIR = /usr/local/cuda
#CUDA_DIR = $$system(which nvcc | sed ‘s,/bin/nvcc$,’)
GPU architecture
CUDA_ARCH = sm_13
PROJECT_DIR = $$system(pwd)
config += create_prl
config += link_prl
TEMPLATE = app
target = release_binary
config += release
QMAKE_CXXFLAGS_RELEASE =-O3
DESTDIR = ../bin
LIBS += -lcudart -lcutil
LIBS += -lGLEW -lGL -lGLU
LIBS += -lcxcore -lcv -lhighgui -lcvaux -lml
RESOURCES += ressources.qrc
OBJECTS_DIR = $$PROJECT_DIR/Obj
NVCCFLAGS = --compile --host-compilation 'C++' \
        --compiler-options -fno-strict-aliasing -use_fast_math
DEPENDPATH += $$PROJECT_DIR/Gui
DEPENDPATH += $$PROJECT_DIR/Motion
DEPENDPATH += $$PROJECT_DIR/Cuda
DEPENDPATH += $$PROJECT_DIR/Core
DEPENDPATH += $$PROJECT_DIR/Media
DEPENDPATH += $$PROJECT_DIR/OpenGL
INCLUDEPATH += $$PROJECT_DIR/Gui
INCLUDEPATH += $$PROJECT_DIR/Motion
INCLUDEPATH += $$PROJECT_DIR/Cuda
INCLUDEPATH += $$PROJECT_DIR/Media
INCLUDEPATH += $$PROJECT_DIR/Core
INCLUDEPATH += $$PROJECT_DIR/OpenGL
QT += opengl
QMAKE_LIBDIR += $$CUDA_DIR/lib64
INCLUDEPATH += $$CUDA_SDK/common/inc/
QMAKE_LIBDIR += $$CUDA_SDK/lib
QMAKE_LIBDIR += $$CUDA_SDK/common/lib
INCLUDEPATH += $$OPENCV_DIR/include
QMAKE_LIBDIR += $$OPENCV_DIR/lib
Input
FORMS += paramsFolki.ui
HEADERS += LIVA.hpp
HEADERS += Logger.hpp
HEADERS += Singleton.hpp
HEADERS += mainwindows.h
HEADERS += paramsFolki.hpp
HEADERS += LiGL2Dwidget.hpp
HEADERS += MediaPlayer.hpp
HEADERS += LkCvWidget.hpp
HEADERS += FolkiOpticalFlow.hpp
HEADERS += OpticalFlow.hpp
HEADERS += endianness.h
HEADERS += FlotRender.hpp
HEADERS += GestionBuffer.hpp
SOURCES += main.cpp
SOURCES += paramsFolki.cpp
SOURCES += LiGL2Dwidget.cpp
SOURCES += MediaPlayer.cpp
SOURCES += LkCvWidget.cpp
SOURCES += FolkiOpticalFlow.cpp
SOURCES += OpticalFlow.cpp
SOURCES += endianness.c
SOURCES += FlotRender.cpp
CUDA_SOURCES += ConvolutionSeparable.cu
CUDA_SOURCES += ConvolutionSeparableFlat.cu
CUDA_SOURCES += ConvolutionSeparableU.cu
CUDA_SOURCES += ConvolutionSeparableFlatU.cu
CUDA_SOURCES += DeriveGradient.cu
CUDA_SOURCES += FolkiOpticalFlowKernels.cu
CUDA_SOURCES += PyramidBurt.cu
CUDA_SOURCES += PyramidHaar.cu
CUDA_SOURCES += DivRot.cu
CUDA_SOURCES += RenderGL.cu
CUDA_SOURCES += Morpho.cu
CUDA_SOURCES += Reduction.cu
CUDA_SOURCES += Propage.cu
HEADERS += ConvolutionSeparableFlat.hpp
HEADERS += ConvolutionSeparable.hpp
HEADERS += ConvolutionSeparableFlatU.hpp
HEADERS += ConvolutionSeparableU.hpp
HEADERS += DeriveGradient.hpp
HEADERS += FolkiOpticalFlowKernels.hpp
HEADERS += LiCuda.hpp
HEADERS += PyramidBurt.hpp
HEADERS += PyramidHaar.hpp
HEADERS += DivRot.hpp
HEADERS += RenderGL.hpp
HEADERS += Morpho.hpp
HEADERS += Reduction.hpp
HEADERS += Propage.hpp
CUDA_INC = $$join(INCLUDEPATH,’ -I’,‘-I’,’ ')
cuda.commands = $$CUDA_DIR/bin/nvcc -g -G -arch=$$CUDA_ARCH -c $$NVCCFLAGS $$CUDA_INC $$LIBS ${QMAKE_FILE_NAME} -o ${QMAKE_FILE_OUT}
cuda.depend_command = $$CUDA_DIR/bin/nvcc -g -G -M $$CUDA_INC $$NVCCFLAGS ${QMAKE_FILE_NAME} |sed “s,^.*:,”|sed “s,^ *,” | tr -d ‘\\n’
Qt+= network[/codebox]
I have a little problem.
I am using Qt Creator 2010.01 on Windows 7 and want to combine Qt with CUDA.
I have copied the following into the .pro file and was hoping that it works now.
[codebox]###################################################
CUDA
win32 {
INCLUDEPATH += $(CUDA_INC_PATH) "C:\ProgramData\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\common\inc"
QMAKE_LIBDIR += $(CUDA_LIB_PATH)
LIBS += -lcudart -lcuda
cuda.commands = $(CUDA_BIN_PATH)/nvcc.exe -c -Xcompiler $$join(QMAKE_CXXFLAGS,",") $$join(INCLUDEPATH,'" -I "','-I "','"') ${QMAKE_FILE_NAME} -o ${QMAKE_FILE_OUT}
unix {
CUDA_CC = $$CUDA_DIR/bin/nvcc
#$$system(which nvcc | sed ‘s,/bin/nvcc$,’)
message("nvcc resides in :" $$CUDA_CC)
QMAKE_CXXFLAGS =
macx {
    INCLUDEPATH += /Developer/CUDA/common/inc/
else {
INCLUDEPATH += /usr/local/cudasdk/C/common/inc
LIBS += -lcudart
macx {
    cuda.commands = $$CUDA_CC -c -arch sm_11 $$join(QMAKE_CXXFLAGS,",") $$join(INCLUDEPATH,'" -I "','-I "','"') ${QMAKE_FILE_NAME} -o ${QMAKE_FILE_OUT}
else {
    cuda.commands = $$CUDA_CC -c -arch sm_13 $$join(QMAKE_CXXFLAGS,",") $$join(INCLUDEPATH,'" -I "','-I "','"') ${QMAKE_FILE_NAME} -o ${QMAKE_FILE_OUT}
cuda.depend_command = nvcc -M -Xcompiler $$join(QMAKE_CXXFLAGS,",") $$join(INCLUDEPATH,'" -I "','-I "','"') ${QMAKE_FILE_NAME} | sed "s,^.*: ,," | sed "s,^ *,," | tr -d '\\\n'
#CUDA_SOURCES = cuda_part/mipmap.cu
cuda.input = cuda_part/mipmap.cu
[/codebox]
But unfortunately I get the compiler output only:
[codebox]mingw32-make: Entering directory `D:/Eigene Dateien/Studium/radiosity/CUDA_Matrix_Coar’
C:/Qt/2010.01/mingw/bin/mingw32-make -f Makefile.Debug
mingw32-make[1]: Entering directory `D:/Eigene Dateien/Studium/radiosity/CUDA_Matrix_Coar’
c:\Qt\2010.01\qt\bin\uic.exe host_part\HemicubeMipMapper\MainWindow.ui -o ui_MainWindow.h
g++ -c -g -frtti -fexceptions -mthreads -Wall -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_GUI_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I"c:\Qt\2010.01\qt\include\QtCore" -I"c:\Qt\2010.01\qt\include\QtGui" -I"c:\Qt\2010.01\qt\include" -I"C:\CUDA\include" -I"c:\ProgramData\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\common\inc" -I"c:\Qt\2010.01\qt\include\ActiveQt" -I"debug" -I"." -I"c:\Qt\2010.01\qt\mkspecs\win32-g++" -o debug\main.o host_part\HemicubeMipMapper\main.cpp
g++ -c -g -frtti -fexceptions -mthreads -Wall -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_GUI_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I"c:\Qt\2010.01\qt\include\QtCore" -I"c:\Qt\2010.01\qt\include\QtGui" -I"c:\Qt\2010.01\qt\include" -I"C:\CUDA\include" -I"c:\ProgramData\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\common\inc" -I"c:\Qt\2010.01\qt\include\ActiveQt" -I"debug" -I"." -I"c:\Qt\2010.01\qt\mkspecs\win32-g++" -o debug\MainWindow.o host_part\HemicubeMipMapper\MainWindow.cpp
g++ -c -g -frtti -fexceptions -mthreads -Wall -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_GUI_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I"c:\Qt\2010.01\qt\include\QtCore" -I"c:\Qt\2010.01\qt\include\QtGui" -I"c:\Qt\2010.01\qt\include" -I"C:\CUDA\include" -I"c:\ProgramData\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\common\inc" -I"c:\Qt\2010.01\qt\include\ActiveQt" -I"debug" -I"." -I"c:\Qt\2010.01\qt\mkspecs\win32-g++" -o debug\test_host.o host_part\HemicubeMipMapper\test_host.cpp
In file included from host_part\HemicubeMipMapper/../../cuda_part/mipmap.h:4,
from host_part\HemicubeMipMapper\test_host.cpp:8:
c:\ProgramData\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\common\inc/cutil.h:19: warning: ignoring #pragma warning
host_part\HemicubeMipMapper\test_host.cpp: In member function ‘void MainWindow::test_main(const std::vector<int, std::allocator >&, const std::vector<double, std::allocator >&)’:
host_part\HemicubeMipMapper\test_host.cpp:131: warning: unused variable ‘mem_size_pi’
host_part\HemicubeMipMapper\test_host.cpp:133: warning: unused variable ‘mem_size_p2p’
host_part\HemicubeMipMapper\test_host.cpp:140: warning: unused variable ‘p2p_ptr’
C:/Qt/2010.01/qt/bin\moc.exe -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_GUI_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I"c:\Qt\2010.01\qt\include\QtCore" -I"c:\Qt\2010.01\qt\include\QtGui" -I"c:\Qt\2010.01\qt\include" -I"C:\CUDA\include" -I"c:\ProgramData\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\common\inc" -I"c:\Qt\2010.01\qt\include\ActiveQt" -I"debug" -I"." -I"c:\Qt\2010.01\qt\mkspecs\win32-g++" -D__GNUC__ -DWIN32 host_part\HemicubeMipMapper\MainWindow.h -o debug\moc_MainWindow.cpp
g++ -c -g -frtti -fexceptions -mthreads -Wall -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_GUI_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I"c:\Qt\2010.01\qt\include\QtCore" -I"c:\Qt\2010.01\qt\include\QtGui" -I"c:\Qt\2010.01\qt\include" -I"C:\CUDA\include" -I"c:\ProgramData\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\common\inc" -I"c:\Qt\2010.01\qt\include\ActiveQt" -I"debug" -I"." -I"c:\Qt\2010.01\qt\mkspecs\win32-g++" -o debug\moc_MainWindow.o debug\moc_MainWindow.cpp
g++ -enable-stdcall-fixup -Wl,-enable-auto-import -Wl,-enable-runtime-pseudo-reloc -mthreads -Wl -Wl,-subsystem,windows -o debug\HemicubeMipMapper.exe debug/main.o debug/MainWindow.o debug/test_host.o debug/moc_MainWindow.o -L"C:\CUDA\lib" -L"c:\Qt\2010.01\qt\lib" -lmingw32 -lqtmaind -lcudart -lcuda -lQtGuid4 -lQtCored4
mingw32-make[1]: Leaving directory `D:/Eigene Dateien/Studium/radiosity/CUDA_Matrix_Coar’
mingw32-make: Leaving directory `D:/Eigene Dateien/Studium/radiosity/CUDA_Matrix_Coar’
debug/test_host.o:D:\Eigene Dateien\Studium\radiosity\CUDA_Matrix_Coar/host_part/HemicubeMipMapper/test_host.cpp:148: undefined reference to `Mipmapper::Mipmapper(int*, int*, int, int)’
debug/test_host.o:D:\Eigene Dateien\Studium\radiosity\CUDA_Matrix_Coar/host_part/HemicubeMipMapper/test_host.cpp:149: undefined reference to `Mipmapper::run()’
debug/test_host.o:D:\Eigene Dateien\Studium\radiosity\CUDA_Matrix_Coar/host_part/HemicubeMipMapper/test_host.cpp:152: undefined reference to `Mipmapper::~Mipmapper()’
collect2: ld returned 1 exit status
mingw32-make[1]: *** [debug\HemicubeMipMapper.exe] Error 1
mingw32-make: *** [debug] Error 2[/codebox]
Have you perhaps an idea how I can solve the problem?
Thanks in advance
Hi guys,
I have used this thread to design my own project file, which works fine with CUDA 3.0 but does not with the latest version 3.2.
Please see this thread for more details: http://forums.nvidia.com/index.php?showtopic=188501
Does someone know what is wrong pleeeeease? :)
Regards,
Martin Peniak
hello!I have runned a program on windows 7 used QT according to your codes,but it did not work.
notice :i used cuda 4.0RC
erro!!:
[/cuda_file_cuda.obj] Erro 1
      no such file
so i think the erro may result from the code
