Matlab 2007b and CUDA Can't compile CUDA example with Matlab
If I compile an example with Visual C++ Express from the SDK I don’t have any problems, I can run it…
Now, I’m trying to use the CUDA plugin for Matlab ith Matlab2007b and Visual C++2005 Express edition, I can compile a mex file with no problem, but I can’t compile the example :
nvmex -f nvmexopts.bat Szeta.cu -IC:\cuda\include -LC:\cuda\lib -lcufft -lcudart
The result is
Szeta.cu
"C:\Program Files\Microsoft Visual Studio 8\VC\INCLUDE\crtdefs.h", line 472: error:
          invalid combination of type specifiers
  typedef unsigned short wchar_t;
"c:\cuda\include\common_functions.h", line 55: warning: dllexport/dllimport
          conflict with "clock" (declared at line 176 of "C:\Program
          Files\Microsoft Visual Studio 8\VC\INCLUDE\time.h");
          dllimport/dllexport dropped
  extern __declspec(__host__) __declspec(__device__) clock_t clock(void);
1 error detected in the compilation of "C:\DOCUME~1\JEAN-B~1\LOCALS~1\Temp/tmpxft_00000f00_00000000-5.ii".
 F:\MATLAB~1\BIN\NVMEX.PL: Error: Compile of 'Szeta.cu' failed.
I don’t know this kind of error…
Does anybody have an idea ?
Thanks,
JB
Have you downloaded the new Matlab plugin for 1.1?
The nvmexopts.bat is slightly different.
Yes I’m using v1.1
@echo off
rem MSVC80OPTS.BAT
rem
rem    Compile and link options used for building MEX-files
rem    using the Microsoft Visual C++ compiler version 8.0
rem
rem    $Revision: 1.1.10.2 $  $Date: 2006/06/23 19:04:53 $
rem
rem ********************************************************************
rem General parameters
set MATLAB=%MATLAB%
set VS80COMNTOOLS=%VS80COMNTOOLS%
set VSINSTALLDIR=C:\Program Files\Microsoft Visual Studio 8
set VCINSTALLDIR=%VSINSTALLDIR%\VC
set PATH=%VCINSTALLDIR%\BIN\;%VCINSTALLDIR%\PlatformSDK\bin;%VSINSTALLDIR%\Common7\IDE;%VSINSTALLDIR%\SDK\v2.0\bin;%VSINSTALLDIR%\Common7\Tools;%VSINSTALLDIR%\Common7\Tools\bin;%VCINSTALLDIR%\VCPackages;%MATLAB_BIN%;%PATH%
set INCLUDE=%VCINSTALLDIR%\ATLMFC\INCLUDE;%VCINSTALLDIR%\INCLUDE;%VCINSTALLDIR%\PlatformSDK\INCLUDE;%VSINSTALLDIR%\SDK\v2.0\include;%INCLUDE%
set LIB=%VCINSTALLDIR%\ATLMFC\LIB;%VCINSTALLDIR%\LIB;%VCINSTALLDIR%\PlatformSDK\lib;%VSINSTALLDIR%\SDK\v2.0\lib;%MATLAB%\extern\lib\win32;%LIB%
set MW_TARGET_ARCH=win32
rem Compiler parameters
set COMPILER=nvcc
set COMPFLAGS=-c -Xcompiler "/c /Zp8 /GR /W3 /EHsc- /Zc:wchar_t- /DMATLAB_MEX_FILE /nologo"
set OPTIMFLAGS=-Xcompiler "/MD /O2 /Oy- /DNDEBUG"
set DEBUGFLAGS=-Xcompiler "/MD /Zi /Fd"%OUTDIR%%MEX_NAME%%MEX_EXT%.pdb"
set NAME_OBJECT=-o
rem Linker parameters
set LIBLOC=%MATLAB%\extern\lib\win32\microsoft
set LINKER=link
rem set LINKER=nvcc
set LINKFLAGS=/dll /export:%ENTRYPOINT% /MAP /LIBPATH:"%LIBLOC%" libmx.lib libmex.lib libmat.lib /implib:%LIB_NAME%.x /MACHINE:X86 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib
set LINKOPTIMFLAGS=
set LINKDEBUGFLAGS=/DEBUG /PDB:"%OUTDIR%%MEX_NAME%%MEX_EXT%.pdb"
set LINK_FILE=
set LINK_LIB=
set NAME_OUTPUT=/out:"%OUTDIR%%MEX_NAME%%MEX_EXT%"
set RSP_FILE_INDICATOR=@
rem Resource compiler parameters
set RC_COMPILER=rc /fo "%OUTDIR%mexversion.res"
set RC_LINKER=
set POSTLINK_CMDS=del "%OUTDIR%%MEX_NAME%.map"
set POSTLINK_CMDS1=del %LIB_NAME%.x
set POSTLINK_CMDS2=mt -outputresource:"%OUTDIR%%MEX_NAME%%MEX_EXT%";2 -manifest "%OUTDIR%%MEX_NAME%%MEX_EXT%.manifest"
set POSTLINK_CMDS3=del "%OUTDIR%%MEX_NAME%%MEX_EXT%.manifest"
Thanks for your rapid answer,
JB
I see, the package updated is missing the new nvmexopts.bat needed for 1.1.
I will post the modified version later on the forum and update the whole package.
OK, thank you very much !
JB
This nvmexopts.bat will fix the error.
The compiler flags need an additional -D_WCHAR_T_DEFINED
@echo off
rem MSVC80OPTS.BAT
rem
rem
rem
set MATLAB=%MATLAB%
set COMPILER=nvcc
set COMPFLAGS=-c -D_WCHAR_T_DEFINED -Xcompiler "/c /Zp8 /GR /W3 /EHsc- /Zc:wchar_t- /DMATLAB_MEX_FILE /nologo"
set OPTIMFLAGS=-D_WCHAR_T_DEFINED -Xcompiler "/MD /O2 /Oy- /DNDEBUG"
set DEBUGFLAGS=-D_WCHAR_T_DEFINED -Xcompiler "/MD /Zi /Fd"%OUTDIR%%MEX_NAME%%MEX_EXT%.pdb"
set NAME_OBJECT=-o
set LINKER=link
rem set LINKER=nvcc
set LINKOPTIMFLAGS=
set LINK_FILE=
set LINK_LIB=
set RC_LINKER=
Thank you very much, all it’s OK !
The package on the web is now up to date.
I have a similar problem with Matlab R2007b and plugin 1.1…
I can correctly execute the code mentioned below:
…but when I try to compile CUDA code like the one in the example:
I receive this message:
I’ve already done the setup of “nvmex” choosing M$ Visual Studio 8 but I always receive the same message. I don’t know how to use the plugin with Matlab. I don’t understand if compiling those programs is mandatory or I just need to replace fft2 and ifft2 files in mathlab with the ones i just created :D
On the pc I have:
CUDA SDK 1.1
CUDA 1.1 Toolkit
Microsoft Visual Studio 8 Express
Microsoft Platform SDK for Windows Server 2003 R2
Matlab R2007b
Hi. I need helpppzzz.
I have a promblem too ;(
A have on PC:
WIN XP x32. ( ver 5.1.2600 Build 2600 SP2)
MATLAB Version 7.2.0.232 (R2006a)
instalated
cude Matlab_CUDA-1.1a.zip - 192.684BYTE
NVIDIA_CUDA_Toolkit_1.1_x86
NVIDIA_CUDA_SDK_1.1_x86
Visual Studio 8 (2005) ver 14.00.50727.42 for x86
problems:
1#
in Matlab
Undefined subroutine &main::mexCatdir called at C:\MATLAB\R2006a\bin\nvmex.pl line 1373.
??? Error using ==> nvmex
Unable to complete successfully. External Media
mex fft2_cuda.c -IC:\CUDA\include -LC:\CUDA\lib -lcudart -lcufft
  • no error
    BUT :
    if try execute it than
   Segmentation violation detected at Tue Jan 08 23:38:03 2008
Configuration:
MATLAB Ver
Register State:
EAX = 00000000 EBX = 033db880
ECX = 00d18ffc EDX = 01296c0f
ESI = 00010000 EDI = 0129959f
EBP = 00d0e004 ES
etc
if mex mulMV.c -IC:\CUDA\include -LC:\CUDA\lib -lcublas
when from module mulMV.c
called cublasInit();
when try execute it (mulMV)
Error:
?? Invalid MEX-file ‘C:\MATLAB\R2006a\work\CUDAC\mulMV.mexw32’: C:\MATLAB\R2006a\work\CUDAC\mulMV.mexw32 its not programm for Win32.
Thanks all.
i get strange errors trying to compile the fft example
mex -f mexgcc.bat fft2_cuda.c -IC:\SDK\Nvidia\Cuda\include -LC:\SDK\nvidia\CUDA\lib -lcudart -lcufft
C:\temp\Local\mex_DC5DCE97-41D2-44A6-70A5-5633ACD9B3A3\fft2_cuda.obj:fft2_cuda.c:(.text+0x7a7): undefined reference to _cudaMalloc' C:\temp\Local\mex_DC5DCE97-41D2-44A6-70A5-5633ACD9B3A3\fft2_cuda.obj:fft2_cuda.c:(.text+0x7c3): undefined reference to _cudaMemcpy’
C:\temp\Local\mex_DC5DCE97-41D2-44A6-70A5-5633ACD9B3A3\fft2_cuda.obj:fft2_cuda.c:(.text+0x834): undefined reference to _cudaMemcpy' C:\temp\Local\mex_DC5DCE97-41D2-44A6-70A5-5633ACD9B3A3\fft2_cuda.obj:fft2_cuda.c:(.text+0x9ec): undefined reference to _cudaFree’
collect2: ld returned 1 exit status
C:\PROGFILE\R18B\BIN\MEX.PL: Error: Link of ‘fft2_cuda.mexw32’ failed.
latest nvidia sdk, tools, lib, everything blah, blah, blah, VS2k8 Exp, cygwin, Mingw, R2007b
i can compile/mex anything with mingw, inbuilt matlab compiler lcc, and vstudio2k8
when i grep through cuda.h i see references to cuMemAlloc but nothing to cudaMalloc?
have you an updated include file?
When I try. Ececute somedemo fft2_cuda.
Output
   Segmentation violation detected at Wed Jan 09 13:35:17 2008
Configuration:
MATLAB Version: 7.2.0.232 (R2006a)
MATLAB License: 161051
Operating System: Microsoft Windows XP
Window System: Version 5.1 (Build 2600: Service Pack 2)
Processor ID: x86 Family 15 Model 8 Stepping 2, AuthenticAMD
Virtual Machine: Java 1.5.0 with Sun Microsystems Inc. Java HotSpot™ Client VM mixed mode
Default Charset: windows-1251
Register State:
EAX = 00d0e7ec EBX = 033daac0
ECX = 00d0e808 EDX = 00000000
ESI = 00d0e79c EDI = 00d0e638
EBP = 00d0e008 ESP = 00d0dffc
EIP = 00000000 FLG = 00010202
Stack Trace:
[0] libmx.dll:_mxGetM(0x00d0e79c, 0x00d
etc.
Help :blink:
When I use mex file where
status = cublasInit ();
status = cublasGetError ();
if (status != CUBLAS_STATUS_SUCCESS) {
mexPrintf(“CUBLAS: error \n”);
} else {
mexPrintf(“CUBLAS: OK \n”);
exit(0);
compilation is OK. But execute output
CUBLAS: error \n
??? My Video Cart is GeForce 6100
Thanks all
Your card does not support CUDA.
You need a G8x based card.
who are you responding to? thx
i have a 7300GT
I was responding to DS.Will, but it applies to you too. You cannot run CUDA on a 7300GT.
how do you get to be a hardware alpha/beta tester? we’re going to be doing image processing with a Red One camera which throws out 4k compressed frames and 2k uncompressed data. i’d like to see what kind of cutting edge stuff you got.
Thank you.
i reinstalled XP.
reinstalled Matlab 2007b ( work with only this version )
reinstalled Visual Studio 8
now nvmex works
and i bay GeForce 8800
i could run all the fft code using mex
mex fft2_cuda.c -ID:\Programming\CUDA\include -LD:\Programming\CUDA\lib -lcudart -lcufft
mex fft2_cuda_sp_dp.c -ID:\Programming\CUDA\include -LD:\Programming\CUDA\lib -lcudart -lcufft
mex ifft2_cuda.c -ID:\Programming\CUDA\include -LD:\Programming\CUDA\lib -lcudart -lcufft
and i cud run successfull the following code also
which Szeta
C:\Documents and Settings\CUDA\Desktop\CUDA\Szeta.m
tic; FS_2Dturb(128,1,1,1); toc;
CFL =
0.1017
Gsqav =
1.1995
Elapsed time is 8.506012 seconds.
tic; FS_vortex; toc;
ans =
512
Elapsed time is 216.061310 seconds.
but when i try to compile the CUDA source The following error is showing up that it could not open the file kernel32.lib…some body please help me as i am anew bie…
nvmex -f nvmexopts.bat Szeta.cu -ID:\Programming\CUDA\include -LD:\Programming\CUDA\lib -lcufft -lcudart
Szeta.cu
“d:\programming\cuda\include\common_functions.h”, line 55: warning:
dllexport/dllimport conflict with “clock” (declared at line 176 of
“D:\Programming\Microsoft Visual Studio 8\VC\INCLUDE\time.h”);
extern __declspec(host) __declspec(device) clock_t clock(void) ;
tmpxft_0000096c_00000000-3.gpu
tmpxft_0000096c_00000000-7.gpu
tmpxft_0000096c_00000000-3.c
Microsoft ® Incremental Linker Version 8.00.50727.42
Copyright © Microsoft Corporation. All rights reserved.
C:\DOCUME~1\VACLAV~1\LOCALS~1\Temp\mex_6F498E69-70C6-48EE-0A85-415E0C0382C0\Szeta.obj
LINK : fatal error LNK1181: cannot open input file ‘kernel32.lib’
D:\MATHEM~1\MATLAB\R2007B\BIN\NVMEX.PL: Error: Link of ‘Szeta.mexw32’ failed.
??? Error using ==> nvmex at 206
I will be grateful if someone help me out…
I have found the solution (at least for my machine, Matlab 2009a, Visual Studio 2008 (9.0) )
1st: The linker searches for some libraries, such as kernel32.lib, in %MATLAB%\extern\lib\win32\microsoft% (see nvmexopt.bat)
The libraries are in the MSVC SDK path in “C:\Program Files\Microsoft SDKs\Windows\v6.0A\bin”
Copy all the files (*.lib) of the second (MSVC) to the first directory (MATLAB).
2nd: After that I encountered a problem with the mt command in the pre-last line of the nvmexopts.bat file
set POSTLINK_CMDS2=mt … bla bla
replace it with
set POSTLINK_CMDS2=“C:\Program Files\Microsoft SDKs\Windows\v6.0A\bin\mt.exe” … bla bla
3rd: One minor change is the path of the visual studio:
set VSINSTALLDIR=C:\Program Files\Microsoft Visual Studio 9.0
instead of Visual Studio 8.0
Of course, maybe somebody can give a more efficient solution.
I hope it will work for you!
I did what you say and it works, I can compile with Matlab 2007b and Visual Studio 9.0
and I run the exemple to solve the Euler equation and I obtain the same results, therefore, It works.
However, Matlab continues giving me this fail with these warnings:
Writing library for fft2_cuda.mexw32
c:\docume~1\josant~1\config~1\temp\mex_30a60ef5-40e7-4a67-9c81-c4e847b5aec2\fft2_cuda.obj .text: undefined reference to ‘_cudaMalloc@8’
c:\docume~1\josant~1\config~1\temp\mex_30a60ef5-40e7-4a67-9c81-c4e847b5aec2\fft2_cuda.obj .text: undefined reference to ‘_cudaMemcpy@16’
c:\docume~1\josant~1\config~1\temp\mex_30a60ef5-40e7-4a67-9c81-c4e847b5aec2\fft2_cuda.obj .text: undefined reference to ‘_cufftPlan2d@16’
c:\docume~1\josant~1\config~1\temp\mex_30a60ef5-40e7-4a67-9c81-c4e847b5aec2\fft2_cuda.obj .text: undefined reference to ‘_cufftExecC2C@16’
c:\docume~1\josant~1\config~1\temp\mex_30a60ef5-40e7-4a67-9c81-c4e847b5aec2\fft2_cuda.obj .text: undefined reference to ‘_cufftDestroy@4’
c:\docume~1\josant~1\config~1\temp\mex_30a60ef5-40e7-4a67-9c81-c4e847b5aec2\fft2_cuda.obj .text: undefined reference to ‘_cudaFree@4’
C:\ARCHIV~1\MATLAB\R2007B\BIN\MEX.PL: Error: Link of ‘fft2_cuda.mexw32’ failed.
??? Error using ==> mex at 208
Although the fft2_cuda.mex32 is created in any case.
Is it something about the mex file?. About Matlab?
Thank you
