cradee
November 3, 2010, 8:39am
1
Hi!
I have some trouble with compiling simple cuda progrsmm from SDK on my system and don’t now what i shud do with this. Nvidia device - GeForce 9500GT
My system satisfies Minimum Software Requirements from README for dev driver:
Software Element Installed on system
Linux kernel 2.4.32
Kernel modutils 2.4.25
binutils 2.17.50.0.6-14
GNU make 3.81
gcc 2.95.4
All needed paths exported in ~/.bashrc:
[user@MCBC ~]# echo $LD_LIBRARY_PATH
:/usr/local/cula/lib:/usr/local/cuda/lib\
[user@MCBC ~]# echo $PATH
...:/usr/local/cuda/bin
Information about installed dev driver:
NVRM version: NVIDIA UNIX x86 Kernel Module 260.19.12 Fri Oct 8 13:22:24 PDT 2010
I’m trying o compile exemple from sdk called VectorAdd.cu
[user@MCBC ~]# nvcc vectorAdd.cu
and i catch
cpp0: cuda_runtime.h: ??? ?????? ????? ??? ????????
Please help. Where to dig?
p.s.: sorry for my english
cradee
2
Hi!
Linux kernel 2.4.32
GNU make 3.81
gcc 2.95.4
and i catch
vectorAdd.cu uses
#include <cutil_inline.h>
you need to include path /NVIDIA_GPU_Computing_SDK/C/common/inc
suppose you install SDK at your home directory, then
nvcc -c -I~/NVIDIA_GPU_Computing_SDK/C/common/inc vectorAdd.cu
then link with /NVIDIA_GPU_Computing_SDK/C/lib/libcutil.a
gcc vectorAdd.o -L~/NVIDIA_GPU_Computing_SDK/C/lib -lcutil
vectorAdd.cu uses
cradee
November 3, 2010, 9:01am
5
thanks, but did not help… similarly i have:
cradee
6
can you compile SDK?
I apologize that you need full path, try
nvcc -c -I/usr/local/cuda/include -I[your home directory]/NVIDIA_GPU_Computing_SDK/C/common/inc -arch=sm_10 vectorAdd.cu
cradee
November 3, 2010, 10:26am
9
did not compiles:
[user@MCBC ~]# cd NVIDIA_GPU_Computing_SDK/C/
[user@MCBC C]# make
make[1]: Entering directory `/user/NVIDIA_GPU_Computing_SDK/C/common'
In file included from src/bank_checker.cpp:15:
../common/inc/bank_checker.h:22: limits: ??? ?????? ????? ??? ????????
make[1]: *** [obj/i386/release/bank_checker.cpp.o] Error 1
make[1]: Leaving directory `/user/NVIDIA_GPU_Computing_SDK/C/common'
make: *** [lib/libcutil.so] Error 2
2
[user@MCBC C]# nvcc -c -I/usr/local/cuda/include -I/user/NVIDIA_GPU_Computing_SDK/C/common/inc -arch=sm_10 /user/NVIDIA_GPU_Computing_SDK/C/src/vectorAdd/vectorAdd.cu
cradee
10
did not compiles:
[user@MCBC C]# make
2
LSChien
November 3, 2010, 1:07pm
11
It seems that gcc 2.95.4 does not work when compiling SDK.
I modify vectorAdd.cu as attached file. I remove all macro, so you don’t need to include NVIDIA_GPU_Computing_SDK/C/common/inc
try this vectorAdd.cu by
nvcc -arch=sm_11 -c vectorAdd.cu
g++ vectorAdd.o -L/usr/local/cuda/lib64 -lcudart
If this works, then you may consider upgrading your gcc
LSChien
12
cradee
November 3, 2010, 2:48pm
13
I tried this, but problem still here
[user@MCBC ~]# nvcc -arch=sm_11 -c vectorAdd.cu
cradee
14
LSChien
November 4, 2010, 12:39am
15
something wrong with nvcc.
we can do simple test, edit a file named main.cu
// main.cu
__global__ void foo( int *x, int *y )
y[threadIdx.x] = x[threadIdx.x] ;
nvcc -ptx -arch=sm_11 main.cu
it should work because foo is a simple copy kernel.
If it does not work, then you should check version of nvcc
nvcc --version
According to backward compatible, new driver would work on old toolkit, so you don’t need to update toolkit.
However I would suggest that you install cuda 3.2
LSChien
16
// main.cu
nvcc --version
cradee
November 8, 2010, 5:17am
17
Same problem(((
[user@MCBC ~]# nvcc --version
Copyright (c) 2005-2010 NVIDIA Corporation
Built on Thu_Sep__9_22:17:49_PDT_2010
Cuda compilation tools, release 3.2, V0.2.1221
I installed the latest version of driver from Nvidia devzone… somfing like 260.19.12
cradee
18
Same problem(((
cradee
November 8, 2010, 5:22am
19
Now I see that laid out a new driver version 260.19.14. Try it and tell later…
cradee
20
