The CUDA Toolkit 3.0 Beta is now available.
Highlights for this release include:
CUDA Driver / Runtime Buffer Interoperability, which allows applications using the CUDA Driver API to also use libraries implemented using the CUDA C Runtime.
A new, separate version of the CUDA C Runtime (CUDART) for debugging in emulation-mode.
C++ Class Inheritance and Template Inheritance support for increased programmer productivity
A new unified interoperability API for Direct3D and OpenGL, with support for:
OpenGL texture interop
Direct3D 11 interop support
cuda-gdb hardware debugging support for applications that use the CUDA Driver API
New CUDA Memory Checker reports misalignment and out of bounds errors, available as a debugging mode within cuda-gdb and also as a stand-alone utility.
CUDA Toolkit libraries are now versioned, enabling applications to require a specific version, support multiple versions explicitly, etc.
CUDA C/C++ kernels are now compiled to standard ELF format
Support for all the OpenCL features in the latest R195.39 beta driver:
Double Precision
OpenGL Interoperability, for interactive high performance visualization
Query for Compute Capability, so you can target optimizations for GPU architectures (cl_nv_device_attribute_query)
Ability to control compiler optimization settings, etc. via support for NVIDIA Compiler Flags (cl_nv_compiler_options)
OpenCL Images support, for better/faster image filtering
32-bit Atomics for fast, convenient data manipulation
Byte Addressable Stores, for faster video/image processing and compression algorithms
Support for the latest OpenCL spec revision 48 and latest official Khronos OpenCL headers as of 11/1/2009
Early support for the Fermi architecture, including:
Native 64-bit GPU support
Multiple Copy Engine support
ECC reporting
Concurrent Kernel Execution
Fermi HW debugging support in cuda-gdb
For more information on general purpose computing features of the Fermi architecture, see: www.nvidia.com/fermi.
Windows developers should be sure to sign up for the Nexus (codename) beta program, and test drive the integrated support for GPU hardware debugging, profiling, and platform trace/analysis features at: www.nvidia.com/nexus
Please review the errata document for important notes about using this beta release.
Special Notice for MacOS X Developers
Use the cudadriver_3.0.0-beta1_macos.pkg driver with all NVIDIA GPUs except Quadro FX 4800 and GeForce GTX 285 on MacOS X 10.5.6 and later (pre-SnowLeoard)
Use cudadriver_3.0.1-beta1_macos.pkg driver with Quadro FX 4800 and GeForce GTX 285 on MacOS X 10.5.6 and later (pre-SnowLeoard).
Use cudadriver_3.0.1-beta1_macos.pkg driver with all NVIDIA GPUs on MacOS X 10.6 SnowLeopard and later.
Downloads
3.0.1 for GT200 Leopard and Snow Leopard
CUDA Toolkit for Fedora 10 32-bit
CUDA Toolkit for RHEL 4.8 32-bit
CUDA Toolkit for RHEL 5.3 32-bit
CUDA Toolkit for SLED 11.0 32-bit
CUDA Toolkit for SuSE 11.1 32-bit
CUDA Toolkit for Ubuntu 9.04 32-bit
CUDA Toolkit for Fedora 10 64-bit
CUDA Toolkit for RHEL 4.8 64-bit
CUDA Toolkit for RHEL 5.3 64-bit
CUDA Toolkit for SLED 11.0 64-bit
CUDA Toolkit for SuSE 11.1 64-bit
CUDA Toolkit for Ubuntu 9.04 64-bit
CUDA Toolkit for Windows 32-bit
CUDA Toolkit for Windows 64-bit
CUDA Profiler 3.0 Beta Release Notes for Linux
CUDA Profiler 3.0 Beta Release Notes for OS X
CUDA Profiler 3.0 Beta Release Notes for Windows
CUDA Toolkit Release Notes for Linux
CUDA Toolkit Release Notes for OS X
