IMPORTANT NOTE
Because of the new support for cross-compilation, the library locations on Linux have changed. 32-bit libraries are located by default at /usr/local/cuda/lib and 64-bit libraries are located by default at /usr/local/cuda/lib64. This is a change from 2.2 and will necessitate changing /etc/ld.so.conf or LD_LIBRARY_PATH.
The CUDA Toolkit and SDK v2.3 are now released and available to all developers.
A brief overview of features–there are a lot:
[*] The CUFFT Library now supports double-precision transforms and includes significant performance improvements for single-precision transforms as well. See the CUDA Toolkit release notes for details.
[*] The CUDA-GDB hardware debugger and CUDA Visual Profiler are now included in the CUDA Toolkit installer, and the CUDA-GDB debugger is now available for all supported Linux distros. (see below)
[*] Each GPU in an SLI group is now enumerated individually, so compute applications can now take advantage of multi-GPU performance even when SLI is enabled for graphics.
[*] The 64-bit versions of the CUDA Toolkit now support compiling 32-bit applications. Please note that the installation location of the libraries has changed, so developers on 64-bit Linux must update their LD_LIBRARY_PATH to contain either /usr/local/cuda/lib or /usr/local/cuda/lib64.
[*] New support for fp16 <-> fp32 conversion intrinsics allows storage of data in fp16 format with computation in fp32. Use of fp16 format is ideal for applications that require higher numerical range than 16-bit integer but less precision than fp32 and reduces memory space and bandwidth consumption.
[*] The CUDA SDK has been updated to include:
[*] A new pitchLinearTexure code sample that shows how to efficiently texture from pitch linear memory.
[*] A new PTXJIT code sample illustrating how to use cuModuleLoadDataEx() to load PTX source from memory instead of loading a file.
[*] Two new code samples for Windows, showing how to use the NVCUVID library to decode MPEG-2, VC-1, and H.264 content and pass frames to OpenGL or Direct3D for display.
[*] Updated code samples showing how to properly align CUDA kernel function parameters so the same code works on both x32 and x64 systems.
[*] The Visual Profiler includes several enhancements:
[*] All memory transfer API calls are now reported
[*] Support for profiling multiple contexts per GPU
[*] Synchronized clocks for requested start time on the CPU and start/end times on the GPU for all kernel launches and memory transfers
[*] Global memory load and store efficiency metrics for GPUs with compute capability 1.2 and higher
[*] The CUDA Driver for MacOS is now packaged separately from the CUDA Toolkit.
[*] Support for major Linux distros, MacOS X, and Windows:
[*]MacOS X 10.5.6 and later (32-bit)
[*]Windows XP/Vista/7 with Visual Studio 8 (VC2005 SP1) and 9 (VC2008)
[*]Fedora 10, RHEL 4.7 & 5.3, SLED 10.2 & 11.0, OpenSUSE 11.1, and Ubuntu 8.10 & 9.04
Notes for MacOS developers
[*] The cudadriver_2.3.1_macos.pkg driver is for use with Quadro FX 4800 and GeForce GTX 285.
[*] The cudadriver_2.3.1_macos.pkg driver may also be used with any NVIDIA GPU on SnowLeopard.
[*] Use the cudadriver_2.3.0_macos.pkg driver for MacOS X 10.5.6 and later (pre-SnowLeoard) with all other GPUs.
Download Links
Mac developers: use the packages in this post.
CUDA Visual Profiler 1.3 for OS X
CUDA Toolkit 2.3 for Fedora 10 - 32-bit
CUDA Toolkit 2.3 for RHEL 4.7 - 32-bit
CUDA Toolkit 2.3 for RHEL 5.3 - 32-bit
CUDA Toolkit 2.3 for SLED 10.2 - 32-bit
CUDA Toolkit 2.3 for SLED 11.0 - 32-bit
CUDA Toolkit 2.3 for SuSE 11.1 - 32-bit
CUDA Toolkit 2.3 for Ubuntu 8.10 - 32-bit
CUDA Toolkit 2.3 for Ubuntu 9.04 - 32-bit
CUDA Toolkit 2.3 for Fedora 10 - 64-bit
CUDA Toolkit 2.3 for RHEL 4.7 - 64-bit
CUDA Toolkit 2.3 for RHEL 5.3 - 64-bit
CUDA Toolkit 2.3 for SLED 10.2 - 64-bit
CUDA Toolkit 2.3 for SLED 11.0 - 64-bit
CUDA Toolkit 2.3 for SuSE 11.1 - 64-bit
CUDA Toolkit 2.3 for Ubuntu 8.10 - 64-bit
CUDA Toolkit 2.3 for Ubuntu 9.04 - 64-bit
CUDA Toolkit 2.3 for Windows - 32-bit
CUDA Toolkit 2.3 for Windows - 64-bit
CUDA Visual Profiler 2.3 Readme
CUDA Visual Profiler for OS X 1.3
CUDA Toolkit 2.3 Release Notes for Linux
CUDA Toolkit 2.3 Release Notes for OS X
CUDA Toolkit 2.3 Release Notes for Windows
CUDA C Best Practices Guide 2.3
CUDA SDK 2.3 Release Notes for Linux
