CUDA 11.6.0 with gcc 11.2.1 fails to process system headers included by <functional>
subj; When I try to build any trivial program that includes <functional> nvcc fails:
$ cat >test.cu <<EOF
#include <functional>
int main(void) { }
EOF
$ nvcc test.cu
/usr/lib/gcc/x86_64-pc-linux-gnu/11.2.1/include/g++-v11/bits/std_function.h:435:145: ошибка: packs параметров не расширены с «...»:
  435 |         function(_Functor&& __f)
/usr/lib/gcc/x86_64-pc-linux-gnu/11.2.1/include/g++-v11/bits/std_function.h:435:145: замечание:         «_ArgTypes»
/usr/lib/gcc/x86_64-pc-linux-gnu/11.2.1/include/g++-v11/bits/std_function.h:530:146: ошибка: packs параметров не расширены с «...»:
  530 |         operator=(_Functor&& __f)
/usr/lib/gcc/x86_64-pc-linux-gnu/11.2.1/include/g++-v11/bits/std_function.h:530:146: замечание:         «_ArgTypes»
Though it works fine with gcc-10.3.0:
$ nvcc --compiler-bindir "/usr/x86_64-pc-linux-gnu/gcc-bin/10.3.0" test.cu
My Cuda and gcc versions:
$ nvcc --version
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Fri_Dec_17_18:16:03_PST_2021
Cuda compilation tools, release 11.6, V11.6.55
Build cuda_11.6.r11.6/compiler.30794723_0
$ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-pc-linux-gnu/11.2.1/lto-wrapper
Target: x86_64-pc-linux-gnu
Configured with: /var/tmp/portage/sys-devel/gcc-11.2.1_p20220115/work/gcc-11-20220115/configure --host=x86_64-pc-linux-gnu --build=x86_64-pc-linux-gnu --prefix=/usr --bindir=/usr/x86_64-pc-linux-gnu/gcc-bin/11.2.1 --includedir=/usr/lib/gcc/x86_64-pc-linux-gnu/11.2.1/include --datadir=/usr/share/gcc-data/x86_64-pc-linux-gnu/11.2.1 --mandir=/usr/share/gcc-data/x86_64-pc-linux-gnu/11.2.1/man --infodir=/usr/share/gcc-data/x86_64-pc-linux-gnu/11.2.1/info --with-gxx-include-dir=/usr/lib/gcc/x86_64-pc-linux-gnu/11.2.1/include/g++-v11 --with-python-dir=/share/gcc-data/x86_64-pc-linux-gnu/11.2.1/python --enable-languages=c,c++,fortran --enable-obsolete --enable-secureplt --disable-werror --with-system-zlib --enable-nls --without-included-gettext --disable-libunwind-exceptions --enable-checking=release --with-bugurl=https://bugs.gentoo.org/ --with-pkgversion='Gentoo 11.2.1_p20220115 p4' --disable-esp --enable-libstdcxx-time --with-build-config=bootstrap-lto --disable-libstdcxx-pch --enable-shared --enable-threads=posix --enable-__cxa_atexit --enable-clocale=gnu --enable-multilib --with-multilib-list=m32,m64 --disable-fixed-point --enable-targets=all --enable-libgomp --disable-libssp --disable-libada --disable-cet --disable-systemtap --disable-valgrind-annotations --disable-vtable-verify --disable-libvtv --with-zstd --enable-lto --with-isl --disable-isl-version-check --enable-default-pie --enable-default-ssp
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 11.2.1 20220115 (Gentoo 11.2.1_p20220115 p4)
nvcc -v output:
$ nvcc -v test.cu
#$ _NVVM_BRANCH_=nvvm
#$ _SPACE_=
#$ _CUDART_=cudart
#$ _HERE_=/opt/cuda/bin
#$ _THERE_=/opt/cuda/bin
#$ _TARGET_SIZE_=
#$ _TARGET_DIR_=
#$ _TARGET_DIR_=targets/x86_64-linux
#$ TOP=/opt/cuda/bin/..
#$ NVVMIR_LIBRARY_DIR=/opt/cuda/bin/../nvvm/libdevice
#$ LD_LIBRARY_PATH=/opt/cuda/bin/../lib:
#$ PATH=/opt/cuda/bin/../nvvm/bin:/opt/cuda/bin:/home/alexander/perl5/bin:/usr/trinity/14/games:/home/alexander/.cargo/bin:~/.cargo/bin:/usr/i486-pc-linux-gnu/gcc-bin/4.3.2:/usr/lib/llvm/8/bin:/usr/tqt3/bin:/usr/trinity/14/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/opt/bin:/usr/lib/llvm/13/bin:/usr/lib/llvm/12/bin:/usr/lib/llvm/11/bin:/usr/lib/llvm/10/bin:/usr/lib/llvm/9/bin:/opt/nvidia-cg-toolkit/bin:/usr/games/bin:/opt/cuda/bin:/usr/lib64/opencascade/bin
#$ INCLUDES="-I/opt/cuda/bin/../targets/x86_64-linux/include"
#$ LIBRARIES=  "-L/opt/cuda/bin/../targets/x86_64-linux/lib/stubs" "-L/opt/cuda/bin/../targets/x86_64-linux/lib"
#$ CUDAFE_FLAGS=
#$ PTXAS_FLAGS=
#$ gcc -D__CUDA_ARCH__=520 -D__CUDA_ARCH_LIST__=520 -E -x c++  -DCUDA_DOUBLE_MATH_FUNCTIONS -D__CUDACC__ -D__NVCC__  "-I/opt/cuda/bin/../targets/x86_64-linux/include"    -D__CUDACC_VER_MAJOR__=11 -D__CUDACC_VER_MINOR__=6 -D__CUDACC_VER_BUILD__=55 -D__CUDA_API_VER_MAJOR__=11 -D__CUDA_API_VER_MINOR__=6 -D__NVCC_DIAG_PRAGMA_SUPPORT__=1 -include "cuda_runtime.h" -m64 "test.cu" -o "/tmp/tmpxft_00007fce_00000000-9_test.cpp1.ii"
#$ cicc --c++17 --gnu_version=110201 --display_error_number --orig_src_file_name "test.cu" --orig_src_path_name "/tmp/test.cu" --allow_managed   -arch compute_52 -m64 --no-version-ident -ftz=0 -prec_div=1 -prec_sqrt=1 -fmad=1 --include_file_name "tmpxft_00007fce_00000000-3_test.fatbin.c" -tused --gen_module_id_file --module_id_file_name "/tmp/tmpxft_00007fce_00000000-4_test.module_id" --gen_c_file_name "/tmp/tmpxft_00007fce_00000000-6_test.cudafe1.c" --stub_file_name "/tmp/tmpxft_00007fce_00000000-6_test.cudafe1.stub.c" --gen_device_file_name "/tmp/tmpxft_00007fce_00000000-6_test.cudafe1.gpu"  "/tmp/tmpxft_00007fce_00000000-9_test.cpp1.ii" -o "/tmp/tmpxft_00007fce_00000000-6_test.ptx"
#$ ptxas -arch=sm_52 -m64  "/tmp/tmpxft_00007fce_00000000-6_test.ptx"  -o "/tmp/tmpxft_00007fce_00000000-10_test.sm_52.cubin"
#$ fatbinary -64 --cicc-cmdline="-ftz=0 -prec_div=1 -prec_sqrt=1 -fmad=1 " "--image3=kind=elf,sm=52,file=/tmp/tmpxft_00007fce_00000000-10_test.sm_52.cubin" "--image3=kind=ptx,sm=52,file=/tmp/tmpxft_00007fce_00000000-6_test.ptx" --embedded-fatbin="/tmp/tmpxft_00007fce_00000000-3_test.fatbin.c"
#$ rm /tmp/tmpxft_00007fce_00000000-3_test.fatbin
#$ gcc -D__CUDA_ARCH_LIST__=520 -E -x c++ -D__CUDACC__ -D__NVCC__  "-I/opt/cuda/bin/../targets/x86_64-linux/include"    -D__CUDACC_VER_MAJOR__=11 -D__CUDACC_VER_MINOR__=6 -D__CUDACC_VER_BUILD__=55 -D__CUDA_API_VER_MAJOR__=11 -D__CUDA_API_VER_MINOR__=6 -D__NVCC_DIAG_PRAGMA_SUPPORT__=1 -include "cuda_runtime.h" -m64 "test.cu" -o "/tmp/tmpxft_00007fce_00000000-5_test.cpp4.ii"
#$ cudafe++ --c++17 --gnu_version=110201 --display_error_number --orig_src_file_name "test.cu" --orig_src_path_name "/tmp/test.cu" --allow_managed  --m64 --parse_templates --gen_c_file_name "/tmp/tmpxft_00007fce_00000000-6_test.cudafe1.cpp" --stub_file_name "tmpxft_00007fce_00000000-6_test.cudafe1.stub.c" --module_id_file_name "/tmp/tmpxft_00007fce_00000000-4_test.module_id" "/tmp/tmpxft_00007fce_00000000-5_test.cpp4.ii"
#$ gcc -D__CUDA_ARCH__=520 -D__CUDA_ARCH_LIST__=520 -c -x c++  -DCUDA_DOUBLE_MATH_FUNCTIONS "-I/opt/cuda/bin/../targets/x86_64-linux/include"   -m64 "/tmp/tmpxft_00007fce_00000000-6_test.cudafe1.cpp" -o "/tmp/tmpxft_00007fce_00000000-11_test.o"
/usr/lib/gcc/x86_64-pc-linux-gnu/11.2.1/include/g++-v11/bits/std_function.h:435:145: error: parameter packs not expanded with '...':
/usr/lib/gcc/x86_64-pc-linux-gnu/11.2.1/include/g++-v11/bits/std_function.h:435:145: note:         '_ArgTypes'
/usr/lib/gcc/x86_64-pc-linux-gnu/11.2.1/include/g++-v11/bits/std_function.h:530:146: error: parameter packs not expanded with '...':
/usr/lib/gcc/x86_64-pc-linux-gnu/11.2.1/include/g++-v11/bits/std_function.h:530:146: note:         '_ArgTypes'
# --error 0x1 --
CUDA 11.6.1 samples have build issues with gcc 11.2.0 on Ubuntu 21.10, while building fine with gcc 10.3.0. Can be simply solved by adding #include <limits> in these two files:
cuda-samples/Samples/5_Domain_Specific/simpleVulkan/VulkanBaseApp.cpp
cuda-samples/Samples/5_Domain_Specific/simpleVulkanMMAP/VulkanBaseApp.cpp
After this change all samples are built correctly.
Seeing the same issue with std_function.h with CUDA 11.5 and gcc 11.2.0 on Ubuntu 22.04 Jammy Jellyfish, but downgrading gcc for my project is not really an option unfortunately. Any other kind of workaround available?
Looks like the problem is fixed in cuda-11.6.2
