I use VS2017 to manage CMake projects. However, CUDA debugger cannot be used.
I can’t click “Start CUDA Debugging” in the menu.
CMakeSettings.txt
"name": "x64-Debug",
"generator": "Ninja",
"configurationType": "Debug",
"inheritEnvironments": [
"msvc_x64_x64"
"buildRoot": "${workspaceRoot}\debug",
"installRoot": "${env.USERPROFILE}\CMakeBuilds\${workspaceHash}\install\${name}",
"cmakeCommandArgs": "",
"buildCommandArgs": "-v",
"ctestCommandArgs": ""
CMakeLists.txt
cmake_minimum_required (VERSION 3.8)
project(neural_network LANGUAGES CUDA CXX)
# find cuda
find_package(CUDA)
include_directories(${CUDA_INCLUDE_DIRS})
set(CMAKE_CUDA_FLAGS "${CMAKE_CUDA_FLAGS} -gencode arch=compute_61,code=sm_61")
if(CMAKE_COMPILER_IS_GNUCXX)
set(CMAKE_CUDA_FLAGS "${CMAKE_CUDA_FLAGS} -std=c++14")
endif()
if (MSVC)
# warning
set(CMAKE_CUDA_FLAGS "${CMAKE_CUDA_FLAGS} -Xcompiler=\"/wd 4819\"")
# static runtime
# set(CompilerFlags
# CMAKE_CXX_FLAGS
# CMAKE_CXX_FLAGS_DEBUG
# CMAKE_CXX_FLAGS_RELEASE
# foreach(CompilerFlag ${CompilerFlags})
# string(REPLACE "/MD" "/MT" ${CompilerFlag} "${${CompilerFlag}}")
# endforeach()
endif()
# add cuda source
file(GLOB HEADERS ${CMAKE_CURRENT_SOURCE_DIR}/src/cuda/*.cuh)
file(GLOB SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/src/cuda/*.cu)
file(GLOB PYBIND11_SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/src/python/*.cpp)
source_group("Include" FILES ${HEADERS})
source_group("Source" FILES ${SOURCES} ${PYBIND11_SOURCES})
include_directories(${CMAKE_CURRENT_SOURCE_DIR}/src/cuda)
# add cuda library
add_library(cu STATIC ${SOURCES})
target_link_libraries(cu PUBLIC cuda)
# option
option(WRAP_LIB "wrap library" OFF)
option(UNIT_TEST "unit test" ON)
# wrap library
if(WRAP_LIB)
# find pybind11
add_subdirectory(${CMAKE_CURRENT_SOURCE_DIR}/third_parts/pybind11)
include_directories(${PYBIND11_INCLUDE_DIR})
set(PYBIND11_CPP_STANDARD "-std=c++14")
endif()
pybind11_add_module(neural_network SHARED ${PYBIND11_SOURCES})
target_link_libraries(neural_network PUBLIC cu)
endif()
# unit test
if(UNIT_TEST)
# find google test
add_subdirectory(${CMAKE_CURRENT_SOURCE_DIR}/third_parts/googletest)
set(TEST_DIR ${CMAKE_CURRENT_SOURCE_DIR}/test/cuda)
file(GLOB TEST_SRCS ${TEST_DIR}/*.cu)
add_executable(unit_tests ${TEST_SRCS})
target_include_directories(unit_tests PRIVATE ${TEST_DIR})
target_link_libraries(unit_tests gtest_main cu)
add_test(NAME unit_tests COMMAND unit_tests)
endif()
